Question about Refrigerators
Freezer doesn't seem cold enough, took over 24 hours to make ice cubes!!! Small fan at the back of the freezer doesn't seem to work regularly, fridge seems ok
  • 1,344 Answers
If the fan in the refrigerator (evaporator fan) isn't working properly your machine isn't going to be as cold as it should be and your ice maker won't work properly as well. This is due to the fact that the ice maker has a sensor in it and it won't produce ice unless the sensor tells it is lower than 10 degrees F. A rule of thumb is if the condensor fan motor is running, which is the fan located by the compressor, than the evaporator fan should be running as well. Now, with that said, there evap fan is tied into what they call a bi-metal thermostat. Depending on the brand these sometimes go bad causing the fan not to run, but that wil cause it not to work at all. If its working intermitantly, than chances are the fan motor is bad.
Posted on Nov 08, 2010
I have a Britannia nabraska side by side fridge freezer. All of a sudden the freezer compartment is not cold enough as though the door had been left open - but 24 hours later has not got colder
You may have a bad thermostat or you could just be frosted over inside. You'll need to look behind the back panel in the freezer for syntoms if unplugging to defrost doesn't work.
Mar 23, 2015 | Refrigerators
I have a Frigidaire Gallery refrigerator. The freezer is not cooling enough to keep frozen. It is blowing cold air and the refrigerator part seems to be working.
If your freezer is cold then you may have a defrost cycle issue. There are typically three components for the defrost cycle. Heater bar, thermostat and timer. If the defrost system fails ice starts to build up in the back of the freezer until it prevents cold air from getting into the fridge. When I took off the back panel inside my freezer it was a block of ice. You can melt the ice with a hair dryer and order new parts.
Mar 13, 2014 | Refrigerators
Freezer side not cold enough, similar temperature as Refrigerator side
It could be many things. My first guess would be the defrost. The coil that gets cold in your freezer builds ice on it and the only way to get the ice off is to run a heater near the coil long enough for the ice to melt. All freezers have something built in to defrost and domestic are typically just an electric heater on a timer. When your freezer stops working again, you may want to pull open the panel of your freezer and see if your coil (a heat exchanger that probably looks a lot like your car radiator) is covered in ice. If it is, it could be the timer or the actual heater that is bad.
Nov 12, 2013 | Refrigerators
GSL22JFRE BS Freezer OK but not Fridge ??
Clean the condenser grille, rear and under unit
Apr 24, 2012 | GE GSL22JFR Side by Side Refrigerator
Fridge not getting cold...but freezer is working
the fridge gets its cold air from the freezer fan blowing it through small air passages between the freezer and fridge. when you adjust the temperature in the fridge you are increasing/decreasing the amount of air being let into the fridge. Two common problems that could cause the freezer to freeze but not the fridge getting cool is the freezer coil is frooze like a ice cube blocking the air going to the fridge or freezer fan is not working could be bad or froze up due to too much ice. If fan works after manually defrosting problem could be in the auto defrost mechanism. If fan don't work after manual defrost replace fan. Manual defrost by putting a pot of very hot water in freezer with door closed change water foten until defrosted.
Jan 02, 2012 | Westinghouse Avalon Refrigerators
I have a sharp fridge SJ-P49N-SL. A recent power outtage in the area lasted 8 hours. When the power came back on, the fridge seemed to be ok. But, after 5-6 hours of operation, the freezer is not cold...
Checked Freezer Fan is working. Also checked defrost Fuse in freezer.
To checked freezer fan is working or not open freezer door press Door Switch and checked Cold air is coming from duct or not.
Aug 10, 2011 | Sharp Refrigerators
Fridge & Freezer won't get cold, but air is blowing
Is the compressor in the lower back working. You may short of gas . have it regassed
Sep 07, 2009 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Fridge and freezer not getting cold
  • You have 2 fans Make sure your top fan is working ,its located inside the freezers back wall. If it is working the vent from the freezer down to the refrigerator may be blocked.With out a fan you have no circulation .Also if you can move everything out unplug it turn it off w/ doors open 12 to 24 hrs this will free up any clogged tubes. Good luck.
    Len West
Feb 19, 2009 | Amana 22.6 cu. ft. Side-By-Side...
Fridge running constantly and ice maker wont work
sound like it is low on freon ,,,, if so it runs all the time trying to get cold enough to shut down and it wont make ice ,,,, 1st check to make sure the fan inside is blowing, make sure the temp in freezer part is atleast +5 or below if it hasn't cooled right front the start then thats why they got rid of it ,,,,, leaking freon and it cost to much to repair that problem / larry
Nov 29, 2008 | Refrigerators
Freezer works great, as it should, but fridge is only keeping items room temp. I have the setting at the coldest setting: #7. What is wrong?
Here's what I did, I defrosted! I found out that the fridge temp is monitored and maintained by the freezer. Because we had a power outage one night, my freezer thawed while we all slept and then when power came back on, freezer re-froze but this cause an ice build up on the vent on the back wall of the freezer. Well, ice must have been in one (or more) vents, causing blocked air flow in my top half of the refrigerator. I turned the dial in the freezer to "off" which also shuts down power to the fridge half. I then unplugged the refrigerator, hauled all my food items into coolers, opened the freezer door and refrigerator doors and left them open for a little over six hours. I took advantage of this empty fridge and freezer and wiped everything down. After this time frame passed, I plugged the fridge back in, turned the freezer dial to my preferred freezer temp, and wah-lah! Within two hours I had a cold fridge and solid ice cubes in the freezer. I then put all my food items back into their appropriate compartments, and went to work. Bear in mind, a total 24-hour period is needed for the fridge to re-set itself, but still, after two hours the fridge was noticeably cold. Who knew, besides our parents' generation: DEFROST!
Sep 10, 2008 | Maytag MBB1954G Bottom Freezer...
Refrigerators Logo
146 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
