Question about Ovens
Microwave door shattered
When I went to use microwave I discovered the inside glass completely shattered while nobody using it. The internal frame was also slightly buckled in one area. It looks as though the entire door needs to be replaced as it will never seal properly again. Where can I get a spare door and is it worth fixing? Have tried microwave which works ok, but may be unsafe to use in this condition.
Inner glass door has shattered on my Neff combi microwave oven (H7860SOGB/02; FD7507). How is it held in place? Appears to be an inner frame holding it in but no obvious screws or fixings. Is it pressure fitted and can I remove it and then refit?
Patrick Mill
  • 833 Answers
This is not a job you should do. Microwaves are dangerous things and can cause injury. An improperly fitted door will leak. A new door, installed and checked out by a technician is needed here The economics are beyond my area.
Posted on Jun 16, 2008
I have a Kuppersbusch microspeed plus (EMWK9600.0M) was in the house when we moved In. whilst using it in microwave mode I heard a bang and the internal glass door has shattered.
The glass will break if the food being heated is not covered and fat/grease heats up to flash point on the glass or there is a cut in the glass or the food banged against the glass or the glass was stressed by an incorrectly fitting door.
A new door is possibly available or glass.
May 17, 2017 | Kuppersbusch Ovens
Microwave door glass replacement
yes u can refit it normally.but do it carefully.need more help regarding this let me know .
Jun 16, 2008 | Ovens
Replace outside glass
You have an expensive Monogram microwave so you can expect the parts to be expensive also. The outer glass assembly by itself ballpark cost is about $160 and requires a complete dis-assembly of the door to replace since the screws are all inside. Then if you go by the book--- the door should be checked for microwave leakage after the repair which requires a special test meter. They also sell a complete door assembly at around $300 that comes completely assembled. You need to compare that cost against the age of your microwave and possibly a new unit which I think is still available. Either way its not a cheap fix.
Apr 11, 2015 | GE ZSC2001FSS Advantium Electric Single...
Oven door glass shattered
What was the weather outside?
Feb 03, 2014 | Miele Ovens
Kuppersbusch microwave door glass replacement
Did you resolve your problem as my inner door just shattered and will need replacing? Do you know why yours broke?
Jan 09, 2012 | Ovens
I need to replace the light bulb in my whirlpool self-cleaning oven but I can not remove the glass cover. How do I remove it?
hello,
Here is a solution to go about the glass bellow
Removing your microwave door allows you to quickly clean out any accumulated food or grease. This also makes it easy to get to all the crumbs and debris around the door hinges. While you have the door off its hinges, examine the plastic panel and glass window for signs of damage. Make sure you install a replacement door that is designed for your brand of microwave to ensure that it will fit correctly.
  • Remove the power cord from the electrical outlet and move your microwave onto a workbench or sturdy table. For cabinet-mounted microwaves, pry off the decorative grills or front panels and remove the mounting screws. You should then be able to slide the microwave out of its mounting bracket.
  • 2 Open the microwave door and remove the glass tray. Use a flathead screwdriver or putty knife to pry off the plastic cover on the inside of the door. Work around the edge of the glass until the cover slips free.
  • 3 Remove the door by pulling the mounting pins out of the hinges at the top and bottom. You may need an assistant to steady the door so you can have both hands free to work with the pins.
  • hope this solution help?
    Thanks for visiting fixya.
    Oct 03, 2010 | Whirlpool 30" Self-Cleaning Freestanding...
    Kitchen Aid microwave door -- outer glass
    Lisa, I do not have a solution, but have the same problem. My KA superba micro has been used about 10 times. While it was off, and while no one was home, the outer glass in the door shattered. I suspect this may be a defect.
    Jun 19, 2009 | KitchenAid Architect Series KEMC308KSS...
    KitchenAid Built-in microwave middle glass shattered
    not a problem, first you can refer to your user manual as to how to remove door, (pg 21) heres a link if you misplaced it.
    http://shared.whirlpoolcorp.com/assets/pdfs/literature/Use%20and%20Care%20Guide%20-%204456573.pdf
    then Ill include this link as well, which is apart breakdown for your GENERAL oven, and i do this so you can see the different panes of glass( ther are 4 of them inthe oven door, each one different so ordering hte right one will be half the battle. http://shared.whirlpoolcorp.com/assets/pdfs/literature/Repair%20Part%20List%20-%208186032.pdf
    the numbers after you model example, kemc308kss** (01,02,03,04) these last 2 digits will also determine which glass you actually have
    http://shared.whirlpoolcorp.com/product_literature/search_results.jsp?searchTerm=kemc308kss&siteCd=WHRCOM
    Once the door is off and you have the correct glass, changing the glass is nothing more then reomving screws from the door frame, layer by layer until you get to the broken pane, not real difficult at all
    Dec 09, 2008 | KitchenAid Architect Series KEMC308KSS...
    Siemens microwave oven HB86k.70b
    I have the same problem, have you found out the cause?
    Regards
    May 04, 2008 | Ovens
    Outer Glass Microwave window shattered after baking popcorn
    doubt anything to do with popcorn. glass like that does sometimes shatter probably a stress fracture. quite often happens with oven doors as well
    Apr 19, 2007 | KitchenAid KEHC379JSS Electric Double Oven
    Ovens Logo
    259 people viewed this question
    Top Ovens Experts
    Dan Webster
    Dan Webster
    ashburton
    Are you an Oven Expert? Answer questions, earn points and help others
