Question about Mintek Televison & Video
When I turn the player on it starts to load the DVD but stops just after 1 or 2 minutes. Also if I take out the power cord it plays longer but still stops.
  • terry664 Nov 09, 2010
    I tried just the audio and it did the same thing. Started to load and then shuts off.
    I did the lens cleaner as well.
    Still the same. What next sir.
    Sergeant:
  • 252 Answers
You DVD has a laser in it called a laser pickup. This part commonly fails in most DVD players. From the symptoms that you described this is your problem. Sometimes you can clean the laser pickup and it will work. In most cases it wont work no matter what you do it.
Unplugg your DVD player
Take phillips head screwdriver
Unscrew the top from and take it off.
The laser pickup is the center of where thre DVD spins when it is inside your DVD player. It should be a clear or reddish round bead that sits on a plastic slider.
Take some dry toilet tissue and clean the laser very gently.
If this doesn't solve your problem your laser pickup is bad. Even if you can see the laser come on it is still bad. This is a sighn of a more complicated problem caused my the microprocesser.This is an expensive fix either way it goes and by the retail price of a good DVD player at Wal- Mart being around $60. Why would you pay $100. in parts and labor.
Posted on Nov 09, 2010
  • Mintek Master
  • 6,993 Answers
the problem is from the laser (lens) of your player. The laser (lens) is very weak, that's why it's difficult for it to load DVD.
If you insert an Audio CD into the player, you will discover that it will load it without any problem.
Get a laser (lens) cleaner, use it to clean the laser (lens). If that doesn't solve the problem, then you will have to replace the laser (lens) of your player to a brand new one and the problem will be solved.
Good luck.
Posted on Nov 08, 2010
Dvd player stopped working. I put dvd in and it starts turning and says loading and then says no disc & stops turning.
Hi there
Two things can cause the problem you are experiencing,
1.the dvd you are trying to play is bad or
2. the lens of your dvd player is bad
What you should do is to try playing several dvd's to see if they work,if they all do then the particular dvd you are trying to play is bad
If some do not play then the lens is bad ad you should open up the dvd player and clean the lens with a cotton wool dabbed in a little bit of methylated spirit
after cleaning,test the dvd again to see if it plays.
If the problem occurs again,the best solution is to replace the lens of the player because it has become too weak..
Jul 04, 2010 | Audiovox D1718PK Portable DVD Player with...
CAN'T PLAY BLU-RAY DVD ON SAMSUNG DVD BLU RAY PLAYER
I have a Samsung BD-P1600 and was having similiar problem...played thru previews but would not play. Instead of just powering off/on... I pulled the plug on the ac cord out and left it out about 20 minutes and it now works !
May 04, 2010 | Samsung BD-P1500 Blu-Ray Player
DVP-NS30 shows "CANNOT PLAY" message when DVD inserted
Follow this procedure to troubleshoot if the DVD player cannot read or play the inserted disc.
  1. Ensure the inserted disc is compatible with the DVD player.IMPORTANT: Refer to the operating instructions supplied with the product for a list of compatible disc. Manuals are available online in the Manuals/Specs/Warranty section of the Sony® eSupport Web site.
  2. Use a soft cloth to clean the disc.
  3. Examine the disc for any cracks or scratches that might be interfering with playback.
  4. Attempt to play another disc.NOTES:
    • If another disc plays in the DVD player, then the previous disc is faulty.
    • Some recordable discs may not play correctly because of the quality of the recording, the physical condition of the disc, or the characteristics of the recording device or authoring software used.
  5. Remove the disc from the DVD player.
  6. Turn off the DVD player.
  7. Unplug the power cord of the DVD player from the AC outlet.
  8. Let the DVD player remain without power for 1 minute.
  9. Plug the power cord back into the AC outlet.
  10. Turn on the DVD player.
  11. Insert the disc into the DVD player.
  12. Attempt to play the disc.
If still persists, its time for your device to get serviced.
Aug 01, 2009 | Sony DVP-NS57P
Dvd won't play or eject
If you want to get the dvd out
you can try this:
First turn of you dvd player at the mains, Then power it up, But the moment it powers up press the eject button a few times so it doesn't start to load. If it doesn't work the first time try it one more time since you may not get the hang of it at first.
then you dvd should eject.
With dvd players like this, corrupt, copied or really scratched dvds may make your dvd player do this.
Regards
Jul 25, 2009 | NexxTech DP3222 DVD Player
Screen comes on, disk turns, loading starts, and doesnt stop
With the power turned off, open the DVD Player, and then open the top where you load the DVD into the player. Locate the laser lens and notice that the laser is attached to a transport assembly that moves the laser diagonally outward in a slot. 1. Slide this assembly outward to the end of its track. 2. Slide the assembly back inward to the closest inward position. 3. Repeat the process of sliding the assembly outward and then back inward.4. Put in a music CD and let it play all the way through. This helps to calibrate the laser head assembly movement. When the music CD is finished playing. 5. Put in a DVD, and you should have a working unit again This is a factory solution from Mintek that was given to a customer who ask for help with the forever loading disc problems. This solution may work on other models of portable DVD players. Most portable DVD players use this type of transport mechanism. Try this solution it might work for you.
Feb 01, 2009 | Mintek MDP-1770 Portable DVD Player
AVOL 15" TV/DVD
I am not sure but maybe purchase a DVD cleaner kit for the player around $10. USD, and make sure the DVD itself is clean and without scratches. Also, try dvd player on another tv to see if it is OK. Other than that input settings. I do not know of any inherent design problems in the unit. Have you tired their web site?
Jul 29, 2008 | Hitachi 46W500 46 in. TV/DVD Combo
My PDV-705 Portable DVD
Durabrand portable DVD players are no longer supported because the company that made them for Walmart went out of business last Novemeber. You can contact Walmart for a replacement unit.
Jul 29, 2008 | Durabrand PDV-705 Portable DVD Player
The dvr is not interacting with my tv
:: Remote Control Overview
1 POWER Press to power the DVD+VCR on or off.
2 TRK+/- While a tape is playing, press to manually adjust tracking
(i.e., to remove white lines from the screen).
3 0-9 Use to select channels and set menu items.
4 SKIP/F.ADV Press to skip ahead in one-minute increments, up to 5
minutes, during VCR playback. Press to advance one frame at a time in
Pause mode.
5 SHUTTLE <</>> Press the 4 and 6 buttons to scan forward and
backward at variable speeds.
6 MODE/REPEAT Press to set the Play Mode to Random or Programmed
Play. Also press to set the Repeat Mode to Title, Chapter/
Track, or A/B Repeat (DVD only).
7 ZOOM Press to zoom in at 2 or 4 times normal magnification (DVD
only).
8 100+/3D SOUND Press to select cable channels 100 and above.
Also press to activate the 3D Sound feature, which creates the illusion of
surround sound with only two speakers (DVD only).
9 DVD Press to set the remote control to operate the DVD deck.
10 MUTE Press to turn audio on or off.
11 VOL +/- Press to adjust the volume.
12 STOP J Press to stop playback.
13 REW AA In DVD mode, press to skip to the previous track. In VCR
mode, press to rewind the tape. Press and hold to scan backward during
playback.
14 REC F Press once to start recording in the VCR deck. Press repeatedly
to add recording time in 30-minute increments.
15 ARROW KEYS Y/B/A/" Press to navigate in the menu system, see
page 15.
16 SETUP/ENTER Press to display the DVD+VCR menu system and
confirm menu settings.
17 SP/SLP/TITLE Press to set the VCR record speed to SP (Standard
Play) or SLP (Super Long Play). SLP is three times longer than SP. Also
press to display DVD title menus (for discs with multiple titles only)
May 29, 2008 | GoVideo DVR4300 DVD Player/VCR
Player won't load any discs
I don't have a solution at this time. I have the same DVD player and mine stopped working this past weekend. It is doing the same thing as yours. I opened the case and loaded a disc and watched the mechanism. The disc won't spin. if you tap the disc it will start spinning and load and start playing. I thought I had fully fixed it. It will load most times but now the video and audio stutters as if the discs is spinning at varying rates.
Apr 06, 2008 | Sony DVP-NC85H Multi-disc DVD Player
Televison & Video Logo
75 people viewed this question
Top Mintek Televison & Video Experts
Jaime Hernandez
Henry  Thomas
Henry Thomas
Are you a Mintek Televison and Video Expert? Answer questions, earn points and help others
