Question about Walgreens Cool Mist Humidifier Humidifier
I think I may have left the humidifier running and I'm at work. The water level was pretty low because I had it running all night. Should I be worried?
My humdifier ran out of water and is still plugged in. Is there danger in that?
Posted on Jan 17, 2013
5 Suggested Answers
SOURCE: aprilaire 600 humidier: water continuously runs
sounds like you may have it wired to a continuous power source vs one that shuts off with the furnace. The most common wiring is red to C & white to W
Posted on Jan 13, 2010
JohnSc
  • 21 Answers
SOURCE: runs, but no humidity
These things have a "sponge" appearing part that is located below the tank. Be sure to totally soak that part in water before trying to use the unit. I had one of these about 3 years ago, and the same thing happened to me. I believe the "sponge", which is really a filter, actually wicks the water into the section of the humidifier that sends water vapor out of the top. You must completely soak it to "Prime" the system, so to speak. That is what worked for me.
Posted on Feb 11, 2008
blueextc3221
  • 15935 Answers
SOURCE: humidifier by Hunter
if you are constantly heating the house, your heter element in the furnace is drawing in and drying out the air you are humidifying. Heat the house, and then turn on the humidifier while the heater is not running. Is your humidifier able to do your entire house (whole house) or just a small room unit?
Posted on Dec 26, 2008
  • 4 Answers
SOURCE: Humidity too low
But by putting it in manual mose, you have to shut it sdown every season. With it in auto mode, and an outdoor sensor hooked up, you won't have to mess with it.
Posted on Feb 09, 2009
Why does my machine keeps turning off
This question needs to supply more information than it currently does. Who manufactured your humidifier? Model of your humidifier? Details about when it 'shuts off', such as water level, temperature, etc.
Most humidifiers are designed to shut off when conditions reach an unsafe condition, such as water level too low. Generally this is sensed by some sort of float telling the device to shut off. Another method used is by monitoring the temperature in the device, after all 'humidification' is done by evaporating water into the surrounding air. If the temperature rises above 212 deg f (boiling point of water) it thinks there isn't any water left to add to the air so it shuts off for safety reasons.
The best course of action is to contact the manufacturer directly for details.
Apr 02, 2015 | Humidifiers
I think my humidifier does not work. I switch the control button to outside temperature rating and inside the house the humidity level is 11%, which is to low. What should I check? How do you know that...
On the water line running to the Humidifier there should be a On/Off valve. It may be a saddle type valve. In any event, this is how you can tell if the water to the humidifier is turned ON. Look for either plastic or copper tubing running from a water source to the humidifier.
Feb 23, 2011 | Carrier LBP Humidifier
I don't think our h8908b honeywell humidifier is working. The house seems pretty dry. Kids are complaining of dry noses and throats. I have also been pretty dry nosed. How do I know if it is working? And...
Hello, if there is no water draining out of the humidifier than it is not working, The humidifier should turn on and off with the furnace, The best thing to do is have the humidifier tuned up by changing the water panel, making sure the there is voltage present the the solenoid valve, and making sure the water supply is getting to the solenoid valve. Let me know if you have any further questions I will be glad to assist you.
Feb 07, 2011 | Honeywell HE360A1027 Whole House...
What happens if the humidifier runs out of water? Humidifier is new and working fine. I Does the humidifier shut off automatically when it runs out of water?
The humidifier has a float valve in it much like a toilet tank does. If the water gets to low, the float valve should allow more water to enter the tank automatically. When it reaches the proper level, the float valve stops the water. The water line (either copper or plastic) coming into the humidifier should have a shutoff valve on it. Make sure that it is turned on.
Feb 02, 2011 | Holmes Products HM4600-U 11 Gallon...
Cleaning filter
Link to Manual online:
http://www.crane-usa.com/manuals/HumidifierManual2008.pdf
I don't think you would have to clean it weekly, for me every other week or once a month works, but our water is pretty low on minerals and bacteria.
Feb 26, 2009 | Crane Frog EE-3191 1 Gallon Humidifier
Aprilaire 600 humidity level too low
The max the aprilaire can put out is 45% Rh. Your humidifier may wired up to run only when the heat is on. In some cases this is not enough time to maintain your humidity level your seeking. To correct this, the hum. has to hooked up the hot side of the water supply. And the humidifier has to be hooked up when the fan runs and leave the fan run constantly
Jan 12, 2009 | Aprilaire 600 Humidifier
My humidifier isnt working properly, it is not using any water
Make sure you soak the wic with COLD water and don't ring it out. Make sure when your putting the tank back in that you don't spill any water into the fan vent. If you get even a splash into the vent, it makes that awful loud motor noise. If this happens just let it dry out on it's own(over night). Also try cleaning the wic tray. It tends to get slimmy from the water sitting in it. If you ever see that your tank is empty, wet your wic when you refill it. Make sure you rinse and wet the wic EVERYTIME you refill the tank. The wic dries out fast and can start smelling pretty bad if you don't rine it regularly.
Nov 16, 2008 | Kaz Sesame Street Elmo & Friends...
Runs, but no humidity
Feb 11, 2008 | Honeywell HCM525 Humidifier
Moisture not coming out
i realize this answer is a year old; but, i would guess you didn't let the wick become saturated before running. fill the resevoir with water, then let the humidifier sit idle while the wick is saturating. when it is completely saturated, the refill light will go off. refill the resevoir with additional water, as needed. then you can run the humidifier.
Jan 20, 2008 | Bemis Whole House Digital Humidifier ED11...
Left Tank won't empty
Eureka! Solved my "left bottle not emptying" problem. The problem was not with the bottle but that the top of unit which houses the on/off switch was not seated properly. It takes only a very slight difference in water level for the float to activate the switch, therefore if the top is raised even 1/4" the unit will shut off before the water level is low enough to allow the left bottle to drain.
Feb 26, 2007 | Emerson HDC12 Humidifier
Walgreens Cool Mist Humidifier Humidifier Logo
1,003 people viewed this question
Top Walgreens Humidifiers Experts
Dennis
Rich Brown
Tom Chichester
Are you a Walgreens Humidifier Expert? Answer questions, earn points and help others
