Question about PNY 4GB USB 2.0 Flash Drive - Grey/Black
Had plug it in a mac and went back to my hp computer and it was lock
  • 71 Answers
Try reformatting it to FAT32 (which works well with both Mac and Windows):
**THIS WILL DELETE ALL THE DATA ON THE DRIVE**
1. Open Finder
2. Applications 3. On the left column, you should see your thumb drive. Click on it.
4. Click on the "Erase" tab near the top
5. For "Format:" select "FAT32"
6. Click on the "Erase..." button
Posted on Apr 20, 2011
How do I get my MAC to put my printer back online
What version OS X are you using? MACs generally are "plug and play", meaning the computer senses connected devices "automatically". Try disconnecting the printer, restarting your computer, then plug the printer back into it. The Mac ought to sense it connected and print to it normally.
Aug 08, 2014 | HP Office Equipment & Supplies
When I try to print, my printer message says 'printer offline'.I've tried powering it off for about an hour, powering off my router and plugging everything back in and I still get that mes
There appears to be a compatibility problem with the newer Mac OS systems. You have not stated whether the printer has ever worked with your current Mac. Here is a a potential source for a driver:
How can an HP Deskjet 5550 printer be made comp Official Apple Support...
Check to see which driver is being tapped in device manager.
I have also found the following:
https://support.apple.com/en-us/HT201465#HP
I'm presuming you have unticked the offline box in the printer que.
Have you tried uninstalling and reinstalling the software package associated with the printer and Mac?
Here are the HP tips for resolving the issue with the Mac.
https://support.hp.com/us-en/document/c04249334
Unfortunately, HP does not provide a scan doctor for use with Mac systems in this instance.
Dec 02, 2017 | HP DeskJet 5550 InkJet Printer
CAN IT WORK WITH APPLE COMPUTER ?
Here is a list of HP Printers that works with Apple MAC http://www.hp.com/sbso/printing/mac/
if you are wondering if a specific model works with Apple,then kindly provide the model number of
that HP printer and I'll check it up for you.Thank You.
Nov 07, 2010 | HP Office Equipment & Supplies
My printer wont turn on
Dear Sir,
If your computer won't turn on, try each of these steps:
  1. Make sure that the power cord is plugged into a working wall outlet, and that it's properly connected to the power adapter. (To check if the wall socket is working, plug in a lamp or other electrical device.)
  2. Make sure that the power adapter is properly connected to the power port on the back of the computer.
  3. Disconnect all accessories that are plugged into the computer, such as a printer, hub, or iPod.
  4. Reset the computer's PMU, SMC, or PRAM. Refer to the instructions for your model:
  5. Try plugging a different power cord into the computer (if you have a working one available). If the computer starts up, replace the old power cord.
  6. If the computer uses a power adapter, try connecting a different power adapter to the computer (if you have a working one available). If the computer starts up, replace the old power adapter. (Computers that use a power adapter include MacBook, MacBook Pro, iBooks, PowerBooks, Power Mac G4 Cube, and Mac mini.)
  7. If you tried all of the steps above and the computer still won't turn on, contact Apple technical support (1-800-APL-CARE in the U.S.) or take your computer to the nearest Apple Store or Apple Authorized Service Provider (AASP) for diagnosis. If you plan to visit an Apple Retail store, make a reservation at the Genius Bar using
Thanks For Your Time,
May 14, 2010 | HP PSC 1210 All-In-One InkJet Printer
Hp desktop wont start
I think you have more than one problem there. Take it to a local PC repair shop and have them check it out. Five years is a good age for a computer though so you may want to think about buying a new one. Best of the Irish Luck to yer.
Sep 16, 2009 | HP Computers & Internet
I plugged my seagate into my mac OS and backed it up first, then went to my pc running windows xp and tried to locate the seagate drive and couldn't. Can I only use the Seagate on one machine or another?
If you are planning to use the Seagate Hard Drive on a PC and MAC better format it on your MAC Computer thru disc Utility and choose MS-DOS. This should solve the problem.
Mac has the ability to recognize a FAT, NTFS and MAC File System for the hard drive but the PC Computer cannot recognize MAC File System.
Check on your mac the File system of your hard drive.
MAC OS Extended
MAC OS Extended (Journaled)
If this is the file system then you now know that it will not be read by PC.
Also formating it with the use of PC will only result in an NTFS File System, and it can be read by Mac but it is only in a Read Only mode. You cannot copy paste or even erase on the drive having an NTFS on a MAC.
Aug 13, 2009 | Seagate FreeAgent (ST305004FDA1E1-RK) 500...
No up to date print drivers for hp laser jet 3330 for mac os 10.5
Its a huge posibility that the drivers you are currently using is not compatible with the device. There are many reasons for the same:
  • The drivers installed is not compatible with the windows installed on the computer.
  • Incorrect drivers installed.
To avoid this problem, visit the following link and download the drivers for your printer and I am sure you will face no problem.
Note: Make sure you download the drivers based on the operating system installed on your computer (like Windows XP, Vista, etc)
http://h20000.www2.hp.com/bizsupport/TechSupport/DriverDownload.jsp?lang=en&cc=us&prodNameId=66367&prodSeriesId=66359&prodTypeId=18972&taskId=135&swLang=8
Mar 23, 2009 | HP LaserJet 3330 All-In-One Printer
HP Photosmart Printer, Mac won't recognize with USB
Sounds like their is not communications between your printer and computer. Could be a bad USB cable - swap out and see if that fixes it. If not it could be a faulty USB port on the computer or printer. You can check the computer USB port by connecting another device, but there is no way to check the HP's USB port. I would also check printer USB port for dust bunnies! If you're not able to resolve, I think it is time for another printer.
Jan 07, 2009 | HP Photosmart 8050 InkJet Printer
Does HP laserjet 1020 work with Airport Express
I removed any printer configurations for this printer in both my pc and my mac (both usb and wireless). Then I restarted both computers and added the printer via usb again to each. At that point I went back to the extreme configuration and under the printers tab it was finally seeing Hewlett Packard Laserjet 1020. After that, adding via Bonjour went smoothly on both platforms.
Oct 17, 2008 | HP LaserJet 1020 Printer
PNY 4GB USB 2.0 Flash Drive - Grey/Black Logo
41 people viewed this question
Top PNY Electronics - Others Experts
john milligan
Sandy Moore
Sandy Moore
Are you a PNY Electronics - Other Expert? Answer questions, earn points and help others
