Question about Whirlpool Duet GHW9150P Front Load Washer
I have a Elite HEt3 2002 model. Was getting the F11 and F06 faults. Replaced motor to fix the F06, but now while the washer is pumping out and the drum is NOT spinning we get the F06 after several minutes of the time flashing and resetting and flashing again then the F06 raises its ugly head. All connections are tight, new motor works fine. Did three loads with new motor before the F06 came back. HELP!!
3 Suggested Answers
jsrock516
  • 5911 Answers
SOURCE: Whrirlpool Front Loader Washing Machine AWO3561 - F11 Fault
Try unplugging the washer for at least 30 minutes before assuming you have a failed component. Sometimes you may experience a momentary glitch in the CCU. Unplugging the washer for this duration will often reset the error and return to normal operation. If the error code reappears, and it was just recently replaced, I strongly recommend getting in touch with the repair service you used. Most reputable companies guarantee their parts and labor against defects (some companies as much as 90 days). If this is a repeat failure, it may just be a bad lot of CCU boards and the company should replace it free of charge. I hope this helps you. Let me know if you require additional assistance.
Posted on Sep 13, 2008
jsrock516
  • 5911 Answers
SOURCE: motor will not spin when washer is full. it will
"F6" is a Motor Speed error code. It is commonly attributed to either a broken or slipped drive belt, defective Drive Motor, bad Motor Control Unit (MCU), and/or the interconnecting wiring. The following link explains:
http://www.fixya.com/support/r3608706-f06_error_code
First, remove the back panel of the unit and make sure the drive belt is not broken, or has not slipped off the drum pulley.
Then, remove the top panel of the washer and check all the connector plugs between the Drive Motor, MCU and Central Control Unit (CCU). Check for loose connections and then unplug each connector and plug them back in (one at a time) to ensure they are snug and making good contact. The top panel comes off by removing the three screws that hold it in place in the rear of the washer. With the screws removed, the panel will slide back, then off.
NOTE: You only need to check the connectors that affect the drive motor and MCU circuitry.
The MCU has a tachometer mounted on it. If it is determined to be the cause of the problem, it is considered part of the MCU and cannot be replaced separately. The MCU is not serviceable and will require replacement.
Next, check the motor windings to ensure they are reading the proper resistance. Followed by continuity checks of all the interconnecting wiring between the drive motor, MCU and CCU. You should not need a service manual because each one of these washers comes with a technical data sheet.
For more in depth troubleshooting tips refer to your tech sheet located inside the washer behind the lower toe panel. You will need to locate and remove the screws under the bottom front edge of the toe panel. Once removed, the panel will drop down, then come off. If the tech sheet isn't located directly behind the panel, it will be affixed to one of the interior cabinet walls. The tech sheet includes all error codes, test points, diagnostic procedures and helpful illustrations to assist in troubleshooting and repair of your washer.
Replacement parts (if required) can be purchased at any of the following websites:
searspartrsdirect.com
pcappliancerepair.com
appliancepartspros.com
repairclinic.com
Prices vary between sites, so shop and compare. The first three sites listed also have helpful exploded view parts illustrations to assist you with locating and properly identifying the parts you may need.
If you have any questions, or require additional assistance, please post back and let me know. I hope you find this information helpful.
Posted on Aug 14, 2010
I have a hotpoint ultima wf860 it was all fine then all of a sudden its saying the error code f-18 how can I fix this please as I havent enough money for a newone yet. many thanks x
Hi, The link below is a user manual for a hotpoint ultima wf860 and below that are the error codes, I wish you all the best......CHEERS...
file:///C:/Users/Steve/Desktop/4992cbf9-f956-4127-bdab-caa958e02377.pdf <---"NEED TO COPY AND PASTE"
Hotpoint Washer Error CodesF01 - Electronic circuit board fault
F02 - Motor circuit fault
F03 - Temperature sensing fault
F05 - Waste pipe blockage or pump issue
F06 - Door lock fault
F07 - Electronic circuit board fault / heating circuit fault
F08 - Heater fault
F09 - Software fault
F11 - Pump circuit fault
F12 - Electronic control fault
F13 - Dryer temperature sensing fault (washer dryers only)
F15 - Heater control fault (washing machines and washer dryers)
F16 - Drum lock position sensor fault (top loading machines only)
F18 - Internal data error
F19 - Fan motor or heating fault (washer dryers only)
Apr 01, 2016 | Hotpoint Washing Machines
WHAT MEANS ERROR CODE FOR MY DRYER MACHINE F11?
Communications error.
  • Troubleshooting and Repairing the F11 Error Code in a ... www.youtube.com/watch?v=RXH5MWzZJKM
    • BY SAMURAIREPAIRMAN
    • 6 MIN
    • 121K VIEWS
    • ADDED 2013-10-22
    Video embedded · Troubleshooting and Repairing the F11 Error Code in a ... Troubleshooting the F35 Sud Error Code in the Whirlpool Duet Steam ... Washer Dryer ...
  • Kenmore Elite He3 F11 Error Code - WordPress.com https://hydripinri.files.wordpress.com/2015/10/kenmore-elite-he3... · PDF file Kenmore Elite He3 F11 Error Code circuitboardmedics.com/whirlpool-duet-fdl-ccu-repair/ How to troubleshoot the ... Kenmore F1 Error Code He2 Dryer Problems Amp Solutions
  • Kenmore Washing Machine Error Code F11 - WordPress.com https://meofapitri.files.wordpress.com/2015/07/kenmore-washing... · PDF file Kenmore Washing Machine Error Code F11 what does f11 mean - Kenmore Elite HE3 Washing Machine. The F11 code is from a communication break in the serial link from ...
  • Related searches for ERROR CODE DRYER F11
  • Whirlpool Duet F11 Error Repair ' Circuit Board Medics circuitboardmedics.com/whirlpool-f11-code Whirlpool F11 Error. This is a repair service for the Whirlpool Duet F11 error code on a Whirlpool Duet washer.
  • Bosch Tumble Dryer Fault Code F11 - prapmumbmihe https://prapmumbmihe.files.wordpress.com/2015/08/bosch-tumble... · PDF file Bosch Tumble Dryer Fault Code F11 Bosch Exxcel tumble dryer error code F:09 · Bosch Exxcel WVT. Asciugatrice Bosch Wts86511It: Errore F11 Hello, My dryer ...
  • Whirlpool F11 error code - Appliance Repair Forum forum.appliancepartspros.com > ... > Washer Repair
    • LAST UPDATED: 2014-02-18
    • 6 POSTS
    • FIRST POST: 2012-02-18
    I got an F11 error code on the washer and tried some of the things discussed on the Applianceblog.com site for simiilar duet washers and found a link to this site ...
  • Jan 30, 2016 | Dryers
    What does F06 mean?
    F06 error code indicates a motor tachometer failure on most Kenmore Elite front load washers. There are many different models, so I would need the model number of your washer to be sure.
    This type of problem could be caused by loose wiring connections between the motor and the motor control board. It could also be caused by loose wiring connections between the motor control board and the main machine control board. Other problems that could cause this fault code include:
    A failed drive motor.
    A defective motor control board.
    A failed main machine control board.
    Hope thie helps (remember to rate and comment this answer)
    Jul 02, 2011 | Kenmore Elite 45986 Front Load Washer
    F06 Error Code
    "F06" is a Motor Speed Error. The following link explains:
    http://www.fixya.com/support/r714929-f06_error_whirlpool_duet_kenmore_elite
    Read through the link provided and let me know if you have questions. In most cases this problem is attributed to a tachometer failure on the Motor Control Unit (MCU). If the this is the case, the MCU must be replaced.
    If you require additional assistance, let me know. I hope you find this information helpful.
    Sep 11, 2009 | Kenmore Elite 45986 Front Load Washer
    Kenmore Elite is giving me F06 error. Any
    Aug 31, 2009 | Kenmore Elite 45986 Front Load Washer
    Kenmore HE4T Elite F06 problems
    Given I had purchased the Extended Warranty, Sears replaced the washer. So, we will see how this one works.....
    Jan 04, 2009 | Kenmore 3.8 cu. ft. HE4t Front Load Washer
    Kenmore Elite he3t model 11045972404
    POSSIBLE COMMUNICATION PROBLEM BETWEEN MAIN AND MOTOR CONTROLLER
    Nov 22, 2008 | Kenmore 3.8 cu. ft. HE3 Front Load Washer
    HELP!!
    We've had this problem for about a yr when i finally firgured out how to correct it.
    the problem is that the circuit board is attached to the washer, when it starts to shake it causes the connections to loosen and theats the fault code you get.
    How I fixed this was to suspend the circuit from a bungie strap this will allow the washer to shake all it wants and the circuit board is stable, connections stay tight andwasher works fine, after 6 months not one error code at all
    Aug 24, 2008 | Kenmore Elite 45986 Front Load Washer
    KENMORE HE4T STARTED AS BALANCE AND F11 NOW ITS F06
    ck all the connectors to both boards and motor you may have inadverantly left 1 loose or knocked one off during previous repair
    Aug 16, 2008 | Kenmore 3.8 cu. ft. HE4t Front Load Washer
    I'm getting a F06 error message.
    f06 is a fault in the motor controller assy, located on the bottom left corner behingd the lower acess panel. check the wiring prior to rplacing the board though
    Apr 20, 2008 | Kenmore Elite 45986 Front Load Washer
    Whirlpool Duet GHW9150P Front Load Washer Logo
    35 people viewed this question
    Sal De
    Marvin
    Marvin
    Gerry Harvey
    Gerry Harvey
