Question about HP Photosmart C6180 All-In-One InkJet Printer
I replaced my magnetta printer cartridge, which I bought from target last night. The printer is keep telling me the catride is empty. I put another new one and I am getting the same message. It won't let me print and I know both catridges are full which I can hear the sound of liquid when I shake it slowly. Any advice?
    Director Badge:
    Uploaded 100 video answers.
  • HP Master
  • 685 Answers
I think that printer has the number keypad, right?
Try this:
  1. To reset this printer, make sure the printer is on. Unplug the printer without turning the printer off.
  2. Wait 60 seconds.
  3. Hold down the # and 6 button while plugging the printer back in. Keep holding the # and 6 down while the printer turns on. After a bit, on mine there was a picture of the power symbol that appeared on the printer display.
  4. When the power symbol appears on the printer display, take your fingers off the # and 6 button.
  5. Push the power button to turn the printer off. Push the power button again to turn the printer back on. The printer will take some time to go through some preparation. When the preparation is complete, the printer will recognize that the cartridges are full.
I am an HP employee. I do not represent HP on this site.
Posted on Nov 08, 2010
Displays no yellow toner in the catride even after putting toner
There are electronic chips on the toner cartridge, when the cartridge is used up the chips tells the copier, you replacing the toner does not reset the chip, buy a new one
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
Feb 25, 2014 | Konica Minolta bizhub 250 All-In-One Laser...
Reset canon mx397
simply replace the cazrtridge with an OEM ( original manufacturer supply) cartridge and dispose of the third party cartridge- I haven heard of one instance where cheap ink refills have worked continuosly without destroying the Printer
Jan 16, 2014 | Office Equipment & Supplies
MFC-J430W will not recognize any new magenta cartridge!
When installing the cartridges, it is important that you insert them from left to right with the black cartridge first and the magenta cartridge last. The reason for this is because the magenta cartridge has a clip on top of it that goes into the cartridge door sensor. The clip needs to push the sensor in so the printer is able to function with the cartridge door open. If you insert the magenta cartridge first, the printer will think the cartridge door is closed and you will get a error message for the other missing cartridges.
May 29, 2013 | Brother Office Equipment & Supplies
After I replace my black ink cartridge the message " install cyan..." comes up. I don't know what is cyan is. My printer is a Brother Multi-fuction center mfc-3360 c I am only replacing my...
Possibly at the time of release catrid black ink, color ink catrid position slightly annoyed and thought catrid sofwear printer cyan ink has been removed so that the request to install cyan. But it could also be due cyan ink has run out and ask to be replaced as new. Please check the contents of cyan ink may have run out, if still a full release catrid cyan and black, then attach it again, then go into maintance, and do head celean and do nozzle check or test printing
Aug 23, 2011 | Brother Multi-Function Center MFC-3360c...
Printer keeps telling me that the yellow cart is empty and I have put a new one in
Are you positive it says the yellow cart is empty? Because that brother printer is designed to say that a cartridge is empty whenever ANY of the color cartridges are empty. Usually it doesn't tell you which one is really empty either. So even if you replaced the yellow cartridge and say, the black cartridge is empty, it still won't let you print until you replace that empty black cartridge, nor will you know which of the cartridges is empty unless you pull them out of the printer and manually check the ink levels.
Its pretty much a guessing game with those old brother ink printers.
Hope this helps :)
May 03, 2010 | Brother MFC-5440CN All-In-One InkJet...
I have a lexmark X3650 printer. I have refilled my black in cartridge. (Drilled the hole and refilled). The printer does not detect the refill and keeps telling me the cartridge is empty. Help please!!!
Unfortunately, the cartridge has an indicator that tells the printer what its status is. This doesn't get reset when you refill the cartridge. With some printers, you can use a few other new cartridges and then try the refilled one again. (These printers store the cartridges last used and status; but can't store a long list of "this cartridge was empty".)
I wish I could be of more help.
Mar 04, 2010 | Office Equipment & Supplies
My printer still need to insert the new catride
Is the cartridge original or not ?
If yes, you should ask a warantee to the seller.
if no, you have to reset the chip inside cartridge with a resetter software
according to your printer brand and type
Sep 09, 2009 | Lexmark Z2300 InkJet Printer
No cartridge prompt
try to clean contacts on cartridge and print head with alcohol, if it doesn't help, try to put back your old empty cartridge, if it will prompt only for that new cartridg, you bought, than the new cartridge is probably broken, replace it
Jul 10, 2009 | Brother Multi-Function Center MFC-240C...
False error empty cartridge
slowly off and on the printer for five times without cartridge, printer saves data of cart of last 5 only so next time it reads full ink..
Jun 01, 2009 | HP Photosmart C6280 Printer
HP Photosmart C6180 All-In-One InkJet Printer Logo
61 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
