Question about Canon PIXMA MP210 Photo All-In-One Printer
At instalation of scanner shows error 2,250,0
HP J3680 Officejet shows scanner error, will not copy or fax
typically this is a software problem. Please check to make sure you have the correct and most up to date driver installed
Jul 21, 2010 | HP J3680 Officejet All In One Printer
Will not transmit to Shop and Scan website when transmit button is pressed . drivers installed from cd provided, new usb lead connected and green light shows on scanner, test scan done from barcode on...
Did you ever get it to transmit the barcodes?
I'm having very much the same problem. Got the error 3 message first, then was told to delete the add on in manage add ons. Now i get an error 2.
Jun 13, 2010 | Opticon OPN 2001 Mobile Data Collector...
Printer problem - HP Photosmart 8150
If the printer cannot print or move any paper, follow these steps to display the Event Log. Otherwise, print the Event Log.
1. Press Menu until INFORMATION MENU appears.
2. Press Item until SHOW EVENT LOG appears. Press Select to show the Event Log.
3. Press - Value + to scroll through the Event Log.
4. Write down the error messages.
If you see a 52.X error then this indicates the following:
0 Laser/Scanner Error
1 Laser/Scanner Startup Error
2 laser/Scanner Rotation Error
ACTION:
1. Press GO. The page containing the error will automatically be reprinted.
2. Turn the printer off, and then turn the printer on.
3. Reseat the cables fort the Laser / Scanner Assembly.
4. Replace the Laser/Scanner Assembly
Sep 21, 2009 | HP Photosmart 8150 InkJet Printer
Cannon MP530 scanner won't scan document it shows error code
hello ! reinstall the machine fax and scanner program cd's may be the installation was not completed or is the machine having issues .
Jul 22, 2009 | Canon PIXMA MP530 All-In-One InkJet...
Copier not working shows a flashing L on display
Sharp AL-1553 code
E7 03 Scanner position error 04 Exposure lamp blown 05 CCD calibration error 12 White level calibration error 14 Main board malfunction 15 Exposure lamp blown L1 00 Scanner position error L3 00 Scanner position error L4 01 Main motor drive overloaded L6 10 Polygon mirror motor not up to speed H2 00 Fusing unit temperature error H3 00 Overheated fusing unit H4 00 The fusing unit doesn't heat up U2 01 Counter error 04 EPROM error CH blinking Dev unit is not properly installed
Nov 18, 2008 | Office Equipment & Supplies
Canon DR 1210 C Communication error
After uninstallin you need to reboot the computer and install as per procedure. this should help.
S. Mohan
Sep 09, 2008 | Canon DR-1210C Scanner
Error code 2806:0000
your scanner soft has problem try to another driver install it try to scan
Jul 10, 2008 | Acer ScanPrisa 640P Flatbed Scanner
Canon PIXMA MP210 Photo All-In-One Printer Logo
102 people viewed this question
old marine
old marine
