Question about HP LaserJet P2015dn Printer
My hp laserjet p2015 printer prints blank pages
  • 300 Answers
SOURCE: Meter read on HP Laser Jet P2015
To print a Configuration page from the printer, press
and hold the Go button for 5 seconds
Posted on May 16, 2008
Nikhil Gedam
  • 87 Answers
SOURCE: Printing problem with HP Laserjet P2015 printer
This can be an issue with one of the faulty sensor across the printer.
Please check if you are able to print from tray 1, e.g. a configuration page.
A config page can be printed by holding the Green Button and releasing it as soon as the Triangle light comes on. This would take approx 5 secs.
If the printer is able to print from tray 1, then it could be an issue with the tray 2 pickup sensor.
Check if the tray 2 pickup sensor ( a black plastic piece to the right of the tray 2 pickup roller) is moving freely (front and back), also check if tray 2 pickup roller is not able to rotate completely.
If the tray 2 sensor is not moving freely and of the pickup roller is rotating completely, then reseat the pickup roller.
Normal use with good media causes wear resulting in the need to periodically clean or replace the pickup roller. Additionally, the use of poor media might require more frequent replacement of the pickup roller. Replacing the pickup roller Complete the following to replace the pickup roller:
CAUTION: Failure to complete this procedure might damage the printer. Unplug the power cord from the printer, and allow the printer to cool.
Figure 1: Unplugging the power cord
mma01_13245_0
2. Open the print cartridge door, and remove the print cartridge.
Figure 2: Removing the print cartridge
mma01_13246_0
3. Remove the main input tray (Tray 2).
Figure 3: Removing the main input tray (tray 2)
mma01_13247_0
4. Open the front automatic two-sided path door (HP LaserJet 1320 series printer only).
Figure 4: Opening automatic two-sided path door
mma01_13248_0
5.Place the printer on the work surface with the front of the printer facing up.
Figure 5: Placement of printer
mma01_13249_0
6. Pull the white tabs outward, and rotate the tabs up.
Figure 6: White tabs
mma01_13250_0
7. Slide the right tab to the right, and leave the tab in this position throughout the procedure.
Figure 7: Right tab movement
mma01_13251_0
8. Slide the pickup roller assembly to the right, and remove the left end cap.
Figure 8: Pickup roller assembly movement
mma01_13252_0
9. Remove the pickup roller.
Figure 9: Pickup roller
mma01_13253_0
10. Insert the left side of the new pickup roller into the left slot (1), and insert the right side (with notches in the shaft) into the right slot (2).
mma01_13254_0
11. Rotate the shaft until the notches engage and the shaft clicks into place. 12.Place the end cap over the shaft on the left side, push the end cap to the right, and rotate the tab downward into position.
Figure 11: Pickup roller end cap
mma01_13255_0
13.Push the right tab to the left, and rotate the tab downward into position. 14.Place the printer on the work surface with the top of the printer facing up. 15.Close the front automatic two-sided path door.
Figure 12: Closed automatic two-sided path door
mma01_13256_0
16.Reinstall the print cartridge, and close the print cartridge door.
Figure 13: Print cartridge
mma01_13257_0
17.Plug the printer in to turn it back on.
Figure 14: Power cord in
mma01_13258_0
Cleaning the pickup roller
Perform the following to clean the pickup roller.
1.Remove the pickup roller as described in steps 1 through 9 of Replacing the pickup roller above.
2. Dab a lint-free cloth in water, and scrub the roller.
mma01_13259_0
Figure 15: Scrubbing the roller
3. Using a dry, lint-free cloth, wipe the pickup roller to remove loosened dirt. Figure 16: Wiping the pickup roller
mma01_13260_0
4. Allow the pickup roller to dry completely before you reinstall it in the printer (see steps 10 through 17 of Section with a task ).
mma01_13261_0
Figure 17: Reinstalling the pickup roller
Posted on Nov 03, 2008
  • 102 Answers
SOURCE: hp laserjet 1320 printing blank pages
Hi, If you have replaced the toner acrtridge and still the printer is printing blank pages than it please make sure you have removed the maler strip of the toner cartridge if yes than perform engine test page of the printer wherein remove the side panel and there is a small button to press and it print engine test page and that will bypass the formatter if the engine test page is also blanik than it is the issue with transfer roller (Which create the image) Power Supply( Create image on transfer roller) or Laser/Scanner assmbly which creates the laser image on transfer and all these three parts are not customer replacable(Hardware Issue) and customer need to get the printer repaired by HP Authorised Engineer.
Posted on Jul 01, 2009
  • 291 Answers
SOURCE: My HP color laserjet 4500 is printing only blank pages
This is usually the Transfer kit, but if the image drum or one of the power supplies goes bad, that can also give blank pages. The Drum problem for no print is usually a grounding/connection problem. Power Supplies are a complicated repair, but these printers aren't too bad to work on. You can buy good used one's fairly cheap on ebay, though. Should consider going to a later model CLJ if you replace with a used, though.
Posted on Aug 31, 2009
  • 1218 Answers
SOURCE: HP LaserJet 1320 Printer printing blank pages.
Check whether the "print preview" on the screen shows blank too...
Make sure the document you are printing doesn't have blank pages. You may think that it might be one page, it might be two. Somehow you may have inserted a blank page or two.
Running a printer operation check
If you are unable to determine the source of the problem, performing a printer operation check can help you determine whether the problem comes from this product or the computer. get more information from here....... http://answers.yahoo.com/question/index?qid=20100905152100AAMq5Iv
Posted on Sep 08, 2010
HP LaserJet P2015 i can't printing on both side page.
If your printer does not have a duplex unit then the printercannot print double sided pages automatically.
You can print double sided pages but you have to do it one page at a time.
First print Page 1 then place the page back into the paper tray, but turn thepage upside down and the print Page 2.
Then print page 3 on one side then page 4 on the other side and repeat for therest of the document.
I suggest you try a test page first, to get the printing the right way up onboth sides of the page so it reads correctly.http://www.fixya.com/support/r7325259-double_sided_printing_using_single_sided
Jan 04, 2012 | HP LaserJet P2015 Printer
I replaced a hp laserjet p2015 printer with another hp laserjet p2015 printer but it can't print.what's the problem,pls help me
This HP printer is comes with the USB cable. To install the printer software, you need to install the USB driver compatible to your printer and then it will ready to print.
Dec 08, 2010 | HP LaserJet P2015 Printer
HP LaserJet P2015 will not print
Are you able to get a stand alone test page out of the printer? Hold the green button down for 5-6 seconds. It should print out a demo page. That way you can narrow it down to either a problem with the printer or a communication issue with your PC or network. Also, it would be helpful to know what the lights are doing on the printer when you try to print.
Aug 16, 2010 | HP LaserJet P2015 Printer
I could not print with hp laserjet p2015 usinh window vista
hi there,
Is the drivers of P2015 correctly installed on vista? If yes then you have to check your printer USB cable. Try to change it and see the result.
Good luck
Jun 24, 2009 | HP LaserJet P2015 Printer
How to open hp laserjet p2015 in order to service
first you need remove the left and rigth covers dont have screws, only press by the back cover.
after that, you can see the screws for top cover an back cover .
May 14, 2009 | HP LaserJet P2015 Printer
HP p2015 printer has stopped printing
check inside the toner door on the right side. there should be a plastic tab which opens the laser shutter when the door is closed. if this is broken then the lase shutter will not open and will produce blank pages.
Jan 15, 2009 | HP LaserJet P2015 Printer
May 16, 2008 | HP LaserJet P2015dn Printer
HP LaserJet P2015dn Printer Logo
240 people viewed this question
Seeker5211
Seeker5211
