Question about Samsung Color Fixed Security Camera Sod-14c
The connector on the Samsung CCTV equipment is standardized for Samsung but there is no industry standard and each manufacturer appears to use their own proprietary wiring pinout. Samsung uses an RJ12 connector with 6 conductors(an RJ12 is physically identical to an RJ11 except RJ11 only has 4 conductors with the outside 2 not used). The pinout looking at the camera socket with the clip up and the contacts down has the following wire numbers 123456 (if you are looking at the cable remember the order will be reversed) 1 Speaker + 2 Video + 3 GND 4 Speaker - 5 Audio Out/Alarm Out 6 +12VDC
4 Suggested Answers
SOURCE: I have two samsung ssc-12c cameras.
The attached pic should be from page 14 of the SSC17 pdf format owner's manual.
If it doesn't show try this link and look at page 14:
http://www.deals2all.com/product_manuals/Samsung-GVI/SSC17WEB.pdf
Anybody have any clue as to why these companies try to keep all of this so secret ? Forcing me to buy their cables, monitors, etc instead of being able to incorporate what I have is more likely to turn me away from their products altogether.
Posted on Feb 23, 2008
robmcd27
  • 423 Answers
SOURCE: I GOT A SAMSUNG SOD14C , OKAY I WANT IT TO CONNECT
Well, your going to need RJ45.
RJ11 is telephony and has 2 pairs of wires. With that, you could use the Blue/Blue-White for power and the Orange/Orange-White for video. Then your stuck.
RJ45 has 4 twisted pairs.
To find out which has power, use a meter to measure your 24 volts.
Rob
Posted on Mar 09, 2009
  • 3 Answers
SOURCE: Need wiring map for RJ11 conector for Samsung SOD-14C camera
I guess this is an ongoing issue with Samsung cameras. Did anyone EVER figure this one out?
Posted on Mar 31, 2010
I want to know what color wires serve what Purpose in my 1993 kia spectra
they dont necessarily serve any singular purpose each manufacturer will have its own color codes that can even vary by the subcontractor they hired to make the part, usually all the connectors are the same though, if you want to know about the stereo wiring, Crutchfield has excellent bluprints of the wires going to the stereo, navigation, and antitheft wiring and how to bluprints of how to remove door panels and dashboard assemblies, the other wires to engine controls and other equipment will be available at your dealership, but there definatly is no longer any color code standardized in the industry, a green wire could be hot but a red wire is seldom neutral
Jan 02, 2015 | Cars & Trucks
This Samsung AA-PB9NS6B battery maked with Hi-Quality battery cells, which is guaranteed to meet OEM specifications. All Samsung AA-PB9NS6B laptop batteries on sale have passed the strict quality control...
Samsung gets their batteries from a supplier, just as newbattery gets them from their source. The OEM or original equipment manufacturer set the specifications and thus the battery was made accordingly. 30 day warranty is standard and after that, your on your own.
Mar 05, 2014 | Samsung DLP HL-P5663W 56" TV
I do not know what type of cable and hoe to hook to pc
Most modern computers have a Network Interface Card (NIC) that used an industry standard RJ45 network jack (8 wire connection similar to a telephone RJ11 connector)
Most people now have broadband service (Cable Modem or DSL Modem) that has RJ45 connections. you also may have a Router between the computer and the Modem to share that internet connection with other computers. The router will also have RJ45 connections. Routers can also be wireless, and you can connect via 802.11 A/B/G/N wireless connection if your computer has an 802.11 standard wireless card.
So, once you detail the brand and model computer and the type fo network conenction/equipment you have, I can give more detailed answers.
Jul 25, 2011 | Computers & Internet
Line in what is that for
In general:
Line In is the standard name for any generic audio input. Line Out would be for the corresponding output.
It allows a standard for audio equipment manufacturers to use when designing for interconnection.
http://en.wikipedia.org/wiki/Line_level
"Consumer electronic devices concerned with audio (for example Sound cards) often have a connector labeled "line in" and/or "line out". Line out provides an audio signal output and line in receives a signal input. The line in/out connections on a computer sound card are generally unbalanced, with a TRS connector of 6.35 mm (1/4"), 3.5 mm (1/8" miniature) or 2.5 mm (3/32" subminiature). The connections on most other consumer equipment use RCA jacks. In most cases changing the volume setting on the source equipment does not vary the strength of the line out signal."
Jan 11, 2011 | RCA Electronics - Others
How many instrument and power cables in one cctv
Hi a simple CCTV one camera system is 1 pair of power wires (1 positive 1 negative) and 1 piece of coax cable with BNC connectors at both ends. (usually rg59 but RG6 is better)
Things to be aware of:
Cameras come in both 12v DC OR 24Vac configurations some are capable of both but most models available to consumers run on 12v most professionals choose 24v models.
simple adapters used to convert from regular coax screw type connectors to either an RCA connector or BNC connector are available at Radio shack. If you need more than 1 or 2 its cheaper to get them on ebay.
You can connect a BNC equipped camera to an input on your TV by using one of these adapters. *put an RCA connector on the end and plug it into one of the yellow video inputs on the TV.
Nov 09, 2009 | Samsung DLP HL-P5663W 56" TV
Automotive r134a refrigerant in refrigerator compressor?
it is the same refrigerant however the car industry and the refrigeration industries purity standards ARE NOT the same!! as a rule refrigerant manufactured under the refer standard can be used for auto but not the reverse, you can use it but be forewarned chances are you will be replacing the compressor due to an electrical burn out
Sep 17, 2009 | Refrigerators
What is the difference between DVD+R and DVD-R thanks.
DVD-R and DVD+R are two competing technologies that use different formats. No single company owns either DVD format and both technologies have their advantages. DVD-R/RW was developed by Pioneer. Based on CD-RW technology, it uses a similar pitch of the helix, mark length of the 'burn' for data, and rotation control. DVD-R/RW is supported by the DVD Forum, an industry-wide group of hardware and software developers, and computer peripheral manufacturers. The DVD-R format has been standardized in ECMA-279 by the Forum, but this is a private standard, not an 'industry' ISO standard like the CD-R/RW Red Book or Orange Book standard. DVD+R/RW is also based on CD-RW technology. DVD+R/RW is supported by Sony, Philips, HP, Dell, Ricoh,Yamaha, and others, and has recently been endorsed by Microsoft. DVD+R/RW is not supported by the DVD Forum, but the Forum has no power to set industry standards, so it becomes a market-driven issue.
Check these link for more information:
http://netforbeginners.about.com/cs/multimedia/a/DVD_explained.htm
http://www.build-your-own-computer-tips.com/dvd-drive-differences.html
Good Luck!!!!!!!!!!!!!
Sep 17, 2009 | Electronics - Others
Dvd m/c tells me disk is not readable
There are different formats of DVD's. Not all will play on all DVD players2.gif. I am copying a part of an article that better explains it and will include the link to the whole article so you can read it. If this doesn't make any sense to you please let me know and I will try to explain it more fully for you. Now on to the explanation......
With so many different formats — DVD+R, DVD+RW, DVD-RAM, DVD-R, DVD-RW, DVD-ROM — how do users know which DVD format is compatible with their existing systems, and why are there so many different formats for DVDs? The following information sheds some light on DVD's different flavors, the differences between them and the incompatibility issues that the differing technologies have sprouted.
Why So Many DVD Formats?
The crucial difference among the standards is based on which standards each manufacturer adheres to. Similar to the old VHS/Beta tape wars when VCRs first hit the markets, different manufacturers support different standards. Often called a format war, both the industry and consumers are still waiting to see which format will emerge as the industry standard.
Plus or Minus - What's The Difference?
The different variations on the term DVD (e.g. +R, -R, -ROM, and so on) describe the way data is stored on or written to the disc itself. These are called physical formats.
Here is the link to the full article......
http://www.webopedia.com/DidYouKnow/Hardware_Software/2007/DVDFormatsExplained.asp
Jul 20, 2009 | Samsung DVD-V5500 DVD Player/VCR
Failing to read dvd
yes you could still play them on upgraded hardware but i have a question
are these cd's newer
and if there newer i would like to inform you that cd manufactures have rechanged the cd format to block piracy also in this its make you upgrade your drive to modern equipment standards by the cd manufactures standards once upgrade hardware all your discs will work until they change the format once again
Jun 05, 2008 | Samsung (SHM522CBEWN) CD-RW/DVD-ROM Combo...
Samsung Color Fixed Security Camera Sod-14c Logo
940 people viewed this question
Top Samsung Home Security Experts
Gary Banta
Level 1 Expert
Cesar Quant
Cesar Quant
Colin Stickland
Colin Stickland
Are you a Samsung Home Security Expert? Answer questions, earn points and help others
