Question about Vacuums
Lady Dazey collapsible hair dryer. Hood will not stay up.
Vax c90 p 2 b 200wI have cleaned filters but hoover/suction keeps cutting in and out?Can you help ?
check for a partial blockage in the wand/ hose ( rag-ball--hair ball ) Check that the hose is not collapsing at past kinks.
Jun 11, 2013 | Vacuums
Aerus 5500, cleaning lady pulled too hard on cord wont retract
Fire cleaning lady!
Money saved would be enough to buy a new machine!
Feb 06, 2013 | Miele S514 Solaris Electro Plus Vacuum
Brush is not engaging when vacuuming. If lifted
therre are usually aprings that hold the brush in position or a spacer thaqt turns when you adjust the height. turn the vacuum over and remove the plate covering verything. make sure your unplugged first. it usually takes about 5-6 phillips head screws. look for loose ,broken or missing parts. make the the roller is taken out and is carefully cleaned of all hair etc esp that just at the edge of the roller where it meets the monting devices. the hair and debris often gets stuck there and once removed works much better. also make sure the belt is not stretched and is slipping on the brush. if it is replace it. good luck.carefully reassemle the parts you removed being very aware of what postiotn everything was in when you took it apart. make sure everything has proper clearance and then test your vacuum. if you find broken or missing parts replace them first ofcoarse.
May 14, 2010 | Hoover Tempo Widepath Upright Vacuum -...
Animal vac gets dog hair in the HEPSA filter,
no id try call Dyson
Customer Service - 866-693-9766
Nov 05, 2009 | Dyson DC14 Animal Bagless Upright Cyclonic...
Coils in hose attachment collapsed at top causing hose to collapse and not suction, how do I fix this?
To fix it properly you need to replace the hose. If you are low on cash try going to a thrift store and get a used one. If you put something in the hose to prevent the collapsing it will quickly clog the hose.
Jun 20, 2009 | Bissell Upright Vacuum - The Pet Hair...
My dysom animal long hose collapses
check the hose and be sure it isn't cloged this is what causes a hose to collapses
Jan 24, 2009 | Dyson DC07 Animal Bagless Upright Cyclonic...
Hoover stamvac has hair trapped in it
Hoover makes a neat tool for cleaning the hair and dirt out, its called a "nozzle cleanout tool". You can contact hoover and locate a store near you.
Jan 12, 2009 | Hoover SteamVac F5914-900 SpinScrub...
Vacuums Logo
271 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
