Question about LG LFX25975ST (247 cu ft) Side by Side Bottom Freezer Commercial French Door Refrigerator
I have a lg french door refrigerator-model number--lfx25975st--it doesn't have a manual and I need one to learn about the thermostat controls etc.. tried on-line but so far no luck-anyone know how to download one from the net-thanks
    Sergeant:
    Champion:
  • 277 Answers
Lg product support
Posted on Nov 08, 2010
Changed the filter but water is coming out slow from the water dispenser
Most likely your water flow is restricted by Ice build up within the small reservoir located in the refrigerator section. If that is not a problem then you could have a flow valve that's not opening fully.
Jul 25, 2014 | LG LFX25975ST (247 cu ft) Side by Side...
LFX25975ST water coming out slow
check if the water supply main valve for the unit is fully opened. if it is , check for obstructions in the line. if waterline has no obstructions , find out if water solenoid valve is working fine. with all the mentioned working alright but problem is still present , call a service man .thanks.
Apr 23, 2014 | LG LFX25971ST Bottom Freezer French Door...
LFX25975ST ERROR 1F.
needs longer to defrost water line in the door turn it off again and use a hair dryer on the door
Mar 27, 2012 | LG LFX25975ST (247 cu ft) Side by Side...
A new model from lg french door stainless steel its working for 3 days and stopped suddenly and there is power on the fridge
NOTE: This
is a multi-solution answer since I don't have all the tech from your question to pinpoint your problem
But the solution is in here generically, if you read and study the solutions very,very carefully.
Sounds like the cold control has stuck . Unplug the two wires from the cold control and plug them together. Turn one wire over and plug it into the other. away from the cold control.
The cold control is the knob in the ref that turns it on and off and has numbers on it. (Thermostat)
If it runs then that cold control (Thernostat) is the problem.
If that doesn't work DO THIS:
The relay on the compressor may need replaced
A relay starts the compressor with a higher voltage and then quickly kicks out
Thats what is happening with yours
Its best for a tech to replace The relay but you can do it
Take your model number to your Local Appliance parts store they will have a diagram
showing you how to install the relay. Its called a hard start relay
also try hooking the two wires together on the cold control to route around the cold control.
If you need more help GO HERE:
http://www.applianceaid.com/procedures.html
Thank you for using fixya
Leo Ponder
PLEASE VOTE FOR ME IF THIS WAS HELPFUL
Aug 24, 2011 | LG LFX25960ST Stainless Steel French Door...
It is saying err ff what does this mean
That means the control board is not seeing a feedback signal from the freezer fan. The fan blade may be blocked by frost or ice.
Mar 06, 2011 | LG LFX25960ST Stainless Steel French Door...
LG french door refrigerator, model # FRFD22850TT, light stayed on and food was hot. Hoe do we get the light repaired? Also, frost builds up on Rt. side of freezer even with the door always closed, no...
the door switch control the light. check the switch
defrost thermostat and heat element control frost, check all of them
if u live near madison . wi , i charge u $100 fix the problem . part may be $100
Jan 13, 2011 | LG LRFD22850 Bottom Freezer Refrigerator...
Left veggie drawer freezes everything in it - cauliflower, lettuce, water, carrots, etc. How can this be fixed?
Could it be that the thermister is out of its mount? Sometimes that is all it takes to throw off the control. How about a service manual? LG French door Tech manual. ( not an owners manual )
Nov 25, 2010 | LG LFX25960ST Stainless Steel French Door...
I open the frige and no light or compressor sound. I checked the power source and no issues.... how do i reset the power board control ??
http://appliancedigest.com/index.php?/files/file/135-lfx25960xx-lg-247-ft-french-door-refrigerator-with-ice-in-door-service-manual/ Closes I found.
Nov 15, 2010 | LG LFX25975ST (247 cu ft) Side by Side...
Lights stay on inside Sears (really LG) french door refrigerator
That should be a covered repair. There was a safety bulletin on that. Call Sears and complain. Tech should have known that.
Dec 10, 2009 | LG LRFD25850 French Door Refrigerator
LG LFX25975ST (247 cu ft) Side by Side Bottom Freezer Commercial French Door Refrigerator Logo
199 people viewed this question
Top LG Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a LG Refrigerator Expert? Answer questions, earn points and help others
