Question about Samsung Televison & Video
My picture curves on both sides of the screen ( left an right). What could the problem be?
    Sergeant:
    Champion:
  • 277 Answers
The lobte is faulty
Posted on Nov 08, 2010
My Sony Projection TV middle of the screen curves down on top and curves up on bottom. Picture looks dubble like 3D, screen looks like concaved. Left side of the screen color is light green and blue, right...
This is a very common failure on Projection sets. Its called a convergence problem.
You may have one or more of the following symptoms.
Screen looks 3D
Colors don't line up
One or more colors can't be adjusted when using the convergence menu.
Screen is bowed or warped.
No Audio / No Video - Makes Chirping Sounds
You can see some examples and find a fix here...
http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Sep 26, 2009 | Sony KP-51WS510 51" Rear Projection...
Faint red lines in a curved arch like pattern
For this problem, what you have to do is here I found this solution: Right below your speakers on the right and left side are tabs. Pull out the tabs and remove the screw on eachside. Once that is done remove the speaker cover and you will see a fiber board cover in the middle of the tv, there will most likley be twist ties holding some wires, to make it easier to work remove the ties. Now remove the screws on the fiber board and pull it off. You should see 3 adjustments on the top for focus, do not touch those. Below the focus adjustments on the bottom is the blue, red, and green adjustments (they should be labeled). All you have to do is turn adjustment screw slightly to the left(or counter clockwise) and it should clear right up. That should do the trick, Hope this is helpful. Please dont forget your rating.
Jan 26, 2008 | Sony KP-51WS500 51" Rear Projection...
50H82 red wavy convergence (stks didn't fix)
If the tin can module you are referring to is the hyper module, it is common to replace all 11 caps because the factory caps ****. Check for bridged solder connections at STK's search the forum at electromaniacs for 50h81 :)
Sep 15, 2009 | Toshiba 57H82 57" Rear Projection...
Toshiba 51h84 "Crooked Picture"
Still the convergece prob.The FL231 fuse near the FBT transformer it dead.The square fuses 3 rectangles fuses.One in the middle.
Aug 09, 2009 | Toshiba 51H84 51" Rear Projection...
Screen has curves
Bad convergence IC's and possibly yoke return resistors located right by the convergence IC's
Craig
May 08, 2009 | Televison & Video
Vertical pinch on left hand side of crt
You mean the picture on the left side is curved out? Or is it restricted to the very top and very bottom?
If you have the curve problem, look in the menu and see if there is a pincushion control and a pin cushion balance. Adjust the balance until both sides curve the same, then adjust the pin cushion control to remove the curve.
If you are only having the problem in the corners, look in the menu for a corner correction control and play around with it to see if it corrects your problem. If the monitor has no OSD (on-screen-display), then it may be too old to have these controls. You may have to open the unit and see if there are any physical adjustments (little potientiometers). You might want to leave this to someone who knows what they are doing since the high voltage circuit can have 25-35 kV. Considering the price of CRT monitors, you might be able to find a new one for under $50.
Jan 22, 2009 | NEC MultiSync XV17 17" CRT Monitor
Help
You need to have the convergence IC's replaced. A repair like this should run you about 300 bucks or so. In most places.
Apr 27, 2008 | Sony KP-46WT500 46" Rear Projection...
Toshiba 43A9UE convergence problem
Check the resistors right next to the Convergence ICs often 1 or 2 of them go oen when the ICs fail.
Feb 09, 2008 | Televison & Video
Mitsubishi VS-60111 picture distorted
how do I manually switch my t.v. from 480i to 1080i on dtv with remote.
Dec 31, 2007 | Mitsubishi VS-70707 70" Rear Projection...
Screen is curved inward on all 4 sides and there is a red, and a blue line that is curved at the top of the screen
This is a convergence problem.. possible deflection problem... you might need a tech to look at it...
Nov 19, 2007 | RCA HD56W66 56" HDTV
Televison & Video Logo
22 people viewed this question
Henry  Thomas
Henry Thomas
