Question about HP LaserJet 2430dtn Printer
SLOW PRINTING HI, MY PRINTER 2430 LASERJET TAKES AGES TO PRINT, IF L PRINT A NUMBER OF PAGES IT TAKES FOR EVER, HOW CAN L SPEED IT UP? I HAVE JUST HAD A NEW COMPUTER AND BEFORE ON MY OLD ONE IT WAS REALLY QUICK. THANK YOU
  • DOOVEY Jun 16, 2008
    NO, ITS MICROSOFT,IT WAS WORKING FINE ON MY OLD COMPUTER, I REMEBER L CHANGED SOMETHING IN THE SETTINGS TO RUN FASTER BUT BECAUSE IT WAS A COUPLE OF YEARS AGO I CAN REMEBER WHAT!!!! PLEASE HELP PRINTING IS SO SLOW!!!!!!!
  • 197 Answers
Hmmm...sounds like maybe you'll need new drivers? is your new computer vista by chance?
Posted on Jun 16, 2008
Slow printing
Slow printing I have a Laserjet 4200
Jun 26, 2013 | HP LaserJet 4200 Printer
Printer is too slow to print once the command is given from PC
Hi
While printing from the USB Port sometimes slow printout/data transfer will result in slow printing of print jobs. or The printer might be printing slow , pausing in between print jobs , or intermittent printing. The symptom solution is mention below, read and follow the instruction.
Solution 1
After the printer is installed on the USB Port, check the description under the Ports Tab what is selected. Please refer to the figure below : c00873625.jpg Using the USB/ Virtual Printer Port and DOT4/ HP Laserjet 2420, under the Port/Description Tab printer speed will be as per the standard. Whereas using the DOT4/ Generic IEEE 1284 under Port/Description Tab, Printer speed will be very slow. If DOT4/ Generic IEEE 1284 is selected by default, then you have to uninstall the USB driver from the Device manager and plug in the USB cable again. Then it will detect the printer and USB port with respect to the printer model. Insert the Driver CD as prompted and by default it will select the DOT4 HP LaserJet2420 Port.
Solution 2
  1. Insert the HP LaserJet 2400 print series CD-ROM.
    NOTE: If the HP Software does not automatically start, click Start , Run , and then Browse . Browse to the CD-ROM drive at the top of the window under look in and select Setup.exe .
  2. Select Modify Installation . Figure 1: Modify Installation c00369540.gif
    NOTE: If Modify Installation is not available See Modify Installation is not Available.
  3. Select the Language of your choice. Figure 2: Select Language c00369541.gif
  4. Click Next. Figure 3: Setup Wizard c00369542.gif
  5. Verify Reinstalling an existing printer is selected. Under Select the port for this printer , choose USB001 or Dot4_00x and click Next . Figure 4: Choose Port c00369543.gif
  6. Select desired Features and click Next . Figure 5: Select Next c00369544.gif
  7. Click Finish . Figure 6: Select Finish c00369545.gif
Uninstall options
  • First verify if an uninstall options is available. If an uninstall option is available under Start, Programs, HP LaserJet 2410 2420 2430 , use this method to uninstall the printer.
God Luck
Sep 09, 2011 | HP LaserJet 2420 Printer
LaserJet 5Si printing slow use to be able to hit the print key then the printer would fire away. seems like the printer pauses between pages then prints maybe 3 to 4 pages per minute
Could be software. I have seen the last several Adobe latest version documents take several seconds to print. I have also seen increased print times with MS office 2003 Powerpoint documents.If it is a single page MS Word or Excel document and u are printing several copies of it, you should turn off the collate feature for printing of that document
Dec 05, 2009 | HP LaserJet 5si Printer
Printing is very slow
Try adjusting your printer settings to a lower quality. That will usually speed things up.
I hope this helps :)
Best Regards,
James Trageser
Jul 29, 2009 | HP LaserJet 5550dtn Printer
HP Color LaserJet 2550N. Slow printing takes 16
http://www.hp.com/#Support
Follow the link and get the correct driver and get installed
Jun 30, 2009 | HP LaserJet 2550n Printer
Speed
Hi, your printer basically printing speed is 43 ppm, please see:
http://h10010.www1.hp.com/wwpc/hk/en/sm/WF06b/18972-18972-3328059-236263-236263-412144-412150.html
so sometimes the print speed depends on your print file size and the PC process ability for large file. large file printing at lower speed right. so you do not worry it.
is it help you? please feed back any question.
May 12, 2009 | HP LaserJet 4250n Printer
Slow Printing
You need to change the pickup roller. The rubber dries out and it is not able to pick up the paper quickly. I had this problem with our printer at work. We changed the rollers and its printing like new again.
Apr 24, 2009 | HP LaserJet P3005n Printer
Slow to print
Make your hard disk space free, put less pages in buffer will solve your problem....
Malik Muhammad Mehran
Apr 20, 2009 | HP LaserJet 6L Printer
Laser jet 2430tn printing slow
Check the way your print Jobs Spool up in your PC. you may have a totally different set up for printing in your new computer that takes two or three extra steps(such as spooling the print job) prior to actually sending it to the printer to be printed. If you have a user manual for your new computer, check the printer set up and see if it is set up to print directly to printer or print to spooling folder then to printer. Also try a different driver if you wish, I know the 2430 can use either PCL5 or PCL6 drivers... I'd start there and see if there is a difference.... the problem isn't your printer obviously its the way your computer is communicating to it. Best of luck to you.
Faxgenius.
Oct 18, 2008 | HP LaserJet 2430dtn Printer
LJ 2430 Printing Blank Pages
HI there have you tried the toner cartridge as this could also cause this problem? Also change the transfer roller and are the bands going from left to right or from up to down. If the bands are left to right change both if up to down more likely to be the toner cartridge.
Hope this helps you
Thanks J
Jan 11, 2008 | HP LaserJet 2420 Printer
HP LaserJet 2430dtn Printer Logo
180 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
