Question about Samsung SyncMaster 930B 19" LCD Flat Panel Monitor
Hello, My Samsung 930B suddenly quit displaying and also no menus etc will display so I assume the back lighting function has failed. Is this a replaceable lamp or more likely a power supply issue? Any ideas would be appriciatred, thanks, MArvin
  • 11,361 Answers
Look at the power supply caps first.
If you are going to DIY and have proper tools and know safety precaution then please read on:
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply (they should be replaced in a set), blown fuses; poor solder joints, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed SAMSUNG monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further and it will help out other people in the future also.
Basic LCD monitor troubleshooting guide:
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Posted on Nov 08, 2010
Samsung smh2117s. The display does not light up, however the touch pads all work. How do you get the light back?
SAMSUNG SMH2117s is a Microwave oven.. :-D
you're in the wrong section. This is for mobile phones.
But, may be the display is gone if you cannot see any lights(Assuming the Microwave oven itself has a LCD to display temp, time..etc.. I don't actually know the model. But many Ovens are digital.). In this case, do not dismantle,crack open it. This is far beyond a rookie operation.
Jun 07, 2017 | Samsung Cell Phones
Very dim display..so dark that all I see is a faint picture. Are bad capacitors to blame?
I would say either the video cable has disconneted, causeing the led that lights the screen up to not function,, simpley take the bezel around the screen, take the small screws aroud the screen to slightley pull the screen away from the back top to see if the cable is, or has pulled loose...If now the screen is bad..
Oct 13, 2014 | Samsung SyncMaster 930B 19" LCD Flat Panel...
How do I replace the inverter in a samsung syncmaster 930B?
The 930B and the 710T use the same power supply/inverter boards. Below is a link to a repair guide for the 710T unit that should get you going in the right direction.
http://www.ccl-la.com/blog/index.php/repairing-the-samsung-syncmaster-710t/
Jan 27, 2013 | Samsung SyncMaster 930B 19" LCD Flat Panel...
Display not working but system functioning
tried with other monitor just to ensure if the problem is only with in the monitor. if the same problem, the cause it could be the inverter board for screen back light which has component being shorted.
Aug 15, 2012 | Samsung SyncMaster 713N 17" LCD Monitor
Monitor will flash the display for a second then go black again.
Most common failure in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed SAMSUNG monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
http://www.badcaps.net
Apr 12, 2010 | Samsung SyncMaster 930B 19" LCD Flat Panel...
I have a power light on my Samsung syncmaster 930b but no image at all is this just a lamp issue or is it a dead moniter.
The problem can be bad caps in the power supply, inverter circuits, or bad lamps. You need to open it up and see, report back what you find so we can help you further, see example of failed monitors due to bad caps, lamps here: http://s807.photobucket.com/home/budm/allalbums
Feb 02, 2010 | Samsung SyncMaster 930B 19" LCD Flat Panel...
My Samsung Syncmaster 930B was working fine unti I disconnected and then reconnected it to my computer. Now I get a black screen with a roaming box that says, "check signal cable".
Hello
1st Pull all power from pc from the wall.Plug back in and start pc up.
While starting hold down the f8 key and select safe mode.
once in go to control panel and select display.
set resoulution to default 60 hz and screen size to 800 by 600.
Reboot.
You may need to readjust your screen again.
Hope this helps.
Jan 14, 2010 | Samsung SyncMaster 930B 19" LCD Flat Panel...
SyncMaster 930B takes 20 minutes at least to become visable
IT SHOWS THAT THE PROBLEM IS IN THE POWER SUPPLY SECTION OF THE LCD. CHANGE THE CAPACITORS PLACED IN THE POWER SUPPLY SECTION. IT WILL WORK.
DONT FORGET TO VOTE.
Oct 10, 2009 | Samsung SyncMaster 930B 19" LCD Flat Panel...
Display
hello,
firstly backup all contacts and e-mails etc before fixing this issue.
if your operating system or configuration files are missing then you should try re-installing from the following samsung download site-
http://www.samsungmobile.com/support/omnia/index.jsp
if this doesn't work try a hard reset by pressing a pin or pen into the hole adjacent to the power button.
// j
Jun 26, 2009 | Samsung SGH-i900 Omnia Unlocked Cellular...
Samsung 930b analog to digital input
Did you check for new drivers to both vid card and display? That'd be the first thing to try.
May 30, 2008 | Samsung SyncMaster 930B 19" LCD Flat Panel...
Samsung SyncMaster 930B 19" LCD Flat Panel Monitor Logo
533 people viewed this question
Top Samsung Computers & Internet Experts
Computer Repairing
Computer Repairing
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
