Question about Panasonic 900 MHz Cordless Phone
Hi, my panasonic 900mhz cordless has the following problem: the phone keeps turned of and it appears the battery won't charge in any way i put it on the base, the light that show "in use/charge" blinks 3 times then keeps turned on when i put it on the base, what should i do?
    Top Expert:
  • Panasonic Master
  • 52,940 Answers
BUY A REPLACEMENT
Posted on Feb 28, 2018
SOURCE: Panasonic KX-TGA101S base not charging.
PyroPC Man is right! Thanks!
Posted on Mar 18, 2008
SOURCE: my ge phone 900MHZ, cordless
I need a replacement part for the phone model 26955 cordless handset and corded speaker phone. The part is called a handset hook that is used to hang this phone on the wall.. I would like to purchase this piece for the missing piece that did not come with my phone. Can you help me find this piece.
Posted on Sep 06, 2008
leroyal
  • 2120 Answers
SOURCE: How to link 3 same model cordless phones to one base
Only if you have 2 phone lines.
Posted on Nov 06, 2008
SOURCE: Panasonic KC-TC1713 cordless phone - Voicemail light stays on
You guys had the owner manual scanned on your web site so I just RTFM ;~).
To clear the voicemail light on the base unit, first press the Redial button on the phone, then hold down the Clear button on the phone for a few seconds. The light should go out.
Here's a tip: I wrote down the above instructions on a small piece of paper and taped them to the back of the phone. You could also tape the note on the inside the battery door.
Posted on Nov 25, 2008
dgrayman919
  • 10 Answers
SOURCE: DX15586-3 Series Uniden Cordless base light always blinking
I know it sounds silly but you may just need to check your messages on your phone then the blinking light should go off.
Posted on Dec 13, 2008
Bought a new battery pack (jensen brand) for panasonic 5.8GHz gigarange supreme KX-TG6500 2Line cordless phone and it wont charge.
check that you got the right make of battery for the charger
some phones use a nicad battery and others use a lit ion battery
2 different recharegable batteries -- 2 different chargers required
Nov 29, 2016 | Panasonic Lands Phones
Why five rapid beeps and screen saying "charge battery"? I had turned on and was charging, and 1 day later phone off and charge gone.
The batteries are defective, your local supermarket should have rechargeable batteries or try an online auction site, look for the highest 'mah rating you can get something like 2800mah, the higher the rating generally the longer the battery will hold charge
Sep 25, 2014 | Panasonic KX-TD7896 Cordless Phone
Buttons don't make any sound but can hear dial tone, speaker phone doesn't work, phone dies fairly quickly - would this all be caused by bad battery and what is the life of battery in a Panasonic cordless...
First off, try changeing from tone dial to pulse dial and try calling out. If that does'nt work, touch bad is probly bad. As far as the speaker phone it does not work off battery's it works from the main base which is powered from the A/C. And for the battery life, when you have a cordless phone you have to build the life to the battery, what I mean is : first time you charge it for 12-14 hours, after that use the phone and do not put it back into cradle, the battery will hold a charge for 8 hrs, if you use it for 30 mins and put back on cradle untill next use, use another 30 min and continue doing this the battery will build its life to 30 min and always die after 30 min, try to get into leaveing off cradle all day and charge while you sleep and keep off cradle all day.
Nov 07, 2013 | Panasonic Lands Phones
Re: Panasonic KX-TC1402 900MHz cordless phone ..... Had "recharge" indicator showing. Replaced battery and seemed to work OK for a couple of months (until the new battery ran down?). Now the...
I had this phone for awhile. finally connected and it worked for awhile. I unplugged to move to a different room now it doesnt work. The in use light does not work.
Apr 09, 2011 | Panasonic Cell Phones
Handset 2 which is doc upstairs goes dead as soon as you want to use it
It's time for a replacement battery. Cordless telephone batteries can be purchased at most places that sell cordless telephones, or battery stores such as batteries plus.
A test for this is that you can swap the batteries with handset 1 and see if the problem follows the batteries.
Does it appear to be charging when on the cradle?
Attempt to charge Handset 2 on the charging cradle you have for Handset 1.
Good Luck,
Mark
Apr 02, 2011 | Panasonic Lands Phones
Phones won't charge
hi,
have tested the charger if it is working?
if you test the charger with another phone and is working perfectly then the charging port of your phone is bad.
the charging port is the port where you insert the charger.
try and get a new charging port and replace with the bad one, the phone will charge.
thanks for using fixya.
Jun 06, 2010 | Panasonic KX-T7885 Cordless Phone
Battery works. Won't turn on
I have the exact same phone and exact same problem. Phone is charged in cradle and green light (indicating full charge) is lit on handset. Opened it up and everything appears clean as a whistle. Did the original poster find a solution? if so, please post it. Thanks.
May 27, 2010 | Panasonic KX-TD7896 Cordless Phone
Panasonic Cardless Phone
Click on the link below to download the user manual
KX - TC1703B Manual
LEt me know for further assistance.
Sep 06, 2009 | Panasonic KX TC1703 Cordless Phone
Panasonic 900 MHz Cordless Phone Logo
49 people viewed this question
Top Panasonic Lands Phones Experts
guyvstewart
john milligan
Are you a Panasonic Lands Phone Expert? Answer questions, earn points and help others
