Question about Refrigerators
Oil cooler/compressor turns on, and runs for 45 seconds, then clicks off. No Refrigeration. front grill was dirty, we are hoping after cleaning and coolinf it down it will start again?
  • 1 more comment
  • Donna McLaren Nov 08, 2010
    Hi Tim, Thanks for your answer, we are trying what you suggested. Also have a fan, trying to cool it.
    We took out a connector part, it's a cube. it rattles when we shake it maybe this needs replacing?
    We did get another part, although the appilance fellow wasn't very helpful. Anyway the new part didn't quite fit, but by taking the old onfe apart, we could see pieces, of the magnesium disc. We just traded it into the original part and the fridge is up and working again. just have to keep learning stuff:)
    President:
  • 2,777 Answers
Yes many times just dirt and dust can cause the compressor not to work. Make sure you to get behind / under that grill, usually with a vacuum or something similar and get all the cobwebs and dust out of there you possibly can. Check the back of the fridge as well and get all dust out that you can...
This should definitely help that compressor get back to running normally.
Thanks, let me know if you have any questions or concerns, just reply to my answer here and I will be right back with you.
Tim
Posted on Nov 08, 2010
  • 1 more comment
  • Tim Grayson
    Tim Grayson Nov 08, 2010
    Sounds good!
    Tim
  • Tim Grayson
    That definitely is a good sign that it's probably failed, you should be able to take it to an appliance shop and have them identify it and verify it is bad, but it sure sounds like you found the culprit!
    Tim
  • Tim Grayson
    Fantastic! That's what I like to hear.
    If possible please come back to the question here and click the Accept This Solution button, it should be below my answer here.
    That shows I helped with your question.
    Thanks so much!
    Tim
Beverage-air DW freezes
Try turning thermostat knob all the way to left or counter clockwise. This should shut the compressor off. If the compressor continues to run the thermostat is stuck closed & bad. If the compressor remains off with thermostat turned all the way to the left try turning it slightly to the right (warmest setting). See if it stops freezing. If it continues to freeze set at warmest setting replace the thermostat. Try pricing a thermostat out at Refrigeration Hardware. Link attached. Refrigeration Hardware Supply
Oct 05, 2013 | Beverage Air Refrigeration Deep Well...
My True TD 50 18 beer cooler does not cool beers
If you hear a clicking noise coming from the compressor there is about a 80% chance that the compressor is dead. But you'll have to call someone out to be sure.
If the fan motor behind the grill is running (condenser fan) then the compressor should be running and vice versa. If the compressor is hot as a pistol and clicking and the fan motor is not working then it may cool down if you shut it off and you might just have a bad fan motor. With power turned off the condenser fan motor should freely spin. Compressor have a 5 year warranty from the manufacture not including labor and additional materials. Hope this helps.
Jan 14, 2012 | True Refrigerators
After running for a few hours it gets hot and shuts down but runs fine every morning
Without more info I will have to give you several things to look at. Typically during the hot months rotary units experience temperature shut downs due to the following. Dirty oil coolers. Blowing them out with air my help some but ideally they need to be washed using a degreaser solution. Location. during the hot months poor air flow/ air removal may let heat from the compressor build up in or under the cover or room. This hot air gets drawn in by the compressor and raises the compressor temperature. The cycle continues until the compressor shuts down on high air temp. Maintenance. Poor maintenance on rotary screw compressors leads to shut downs on high temp, high air temps then play havoc on dryers which causes moisture in the air system. Maintenance items that need replacing regularly ( about 2000 hrs) oil filter, air filter, Depending on type of oil used change 2000 to 8000 hrs, seperator @ 8000 hrs. Also the amont element will cause high temps if bad. It is located where the three oil lines come together. There should be 4 screws that hold the cover on. the cover also has a hose connected to it and located close to the oil cooler. This amont element acts like the thermostat in your car. it lets oil bypass the oil cooler or causes more oil to go thru the cooler. the cooler oil and bypass oil mixes and maintains a certain temp. air end temp should run about 195 F and injected temp about 165 F. hope this helps. if you can give more detailed info I can get you closer to your problem.
Jul 13, 2011 | Air Tools & Compressors
Why air compressor model: MH75 intercooler leaked with dirty oil? Please state also what is the causes, recommended and effect if not change anything.
With out more info I can only pass along what I typically see while in the field. Inner coolers experience a lot of high temps and varying pressures. After a while of expansion and contraction they sometimes fail. This is true for both rotary screw and piston type compressors. As for the dirty oil all oil lubricated compressors pass some oil. this oil plates out in the system. This plating / residue can be linked to the oil used. compressor oil is formulated so their is less carbon and residue built up while lets say oil for your car is formulated differently. I know from experience some auto type oils build carbon badly if used in a compressor. their are several causes but mainly poor maintenance ,this causes more wear and the compressor passes more oil. even small things like leaks that allow unfiltered air into the compressor will cause the oil to become contaminated thus the dirt in the oil plates out in the system as oil is passed and carries over. the dirty oil you see coming out from the leak is contamination that has plated out in the system. what damage is done is done. At this point in time my recommendation would be use a good compressor type oil, do good maintenance, change oil and filters at the specified schedule more often if in a dirty environment and repair/replace the inner cooler. Now if you want to go further you can disassemble and clean parts, coolers etc. You can also purchase cleaners for some compressor that will remove build up that has plated out in the system. However please be careful and make sure the cleaner is compatible with your compressor. If not it may damage seals ,gaskets, o rings etc. hope this helps you.
Jun 23, 2011 | Ingersoll Rand Air Tools & Compressors
The fan working but fezzer and cooler not cool
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
Many times a freezer and/or refrigerator do not work right because of a dirty condenser coil...there are also many other things that can go wrong.
If you are hearing a clicking or buzzing then check out the last two tips.
If your refrigerator is running but warm, then…
Check out this tip that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
heatman101
Sep 11, 2010 | Everest Refrigeration EPR3
How do i remove the ac condenser on a mazda 3
B3E071161450W02
1. Disconnect the negative battery cable.
2. Discharge the refrigerant. (See REFRIGERANT CHARGING.)
3. Remove the splash shield.
4. Remove the A/C drive belt. (See DRIVE BELT REPLACEMENT [LF].)
5. Detach the two wiring harness clamps.
6. Disconnect the magnetic clutch connector.
7. Remove the A/C compressor protector.
8. Disconnect the cooler hose (LO) and cooler hose (HI). Do not allow remaining compressor oil in the refrigerant line to spill. (See Refrigerant Line Removal Note.) (See Refrigerant Line Installation Note.)
Caution • If moisture or foreign material enters the refrigeration cycle, cooling ability will be lowered and abnormal noise or other malfunction could occur. Always plug open fittings immediately after removing any refrigeration cycle parts. 9. Remove the compressor protector.
10. Remove in the order indicated in the table. Do not allow remaining compressor oil in the A/C compressor to spill.
11. Install in the reverse order of removal.
12. Perform the refrigerant system performance test. (See REFRIGERANT SYSTEM PERFORMANCE TEST.)
A/C Compressor Installation Note 1. When replacing the A/C compressor, remove the following amount of compressor oil from the new A/C compressor.
Amount drained (approx. quantity) • 155 ml {155 cc, 5.24 fl oz} - [compressor oil from old A/C compressor + 15 ml {15 cc, 0.5 fl oz}]
Aug 10, 2010 | 2007 Mazda 3
The water isnt cooling in the dispenser and we dont hear the coils running anymore either. what can we do to troublshoot our dispenser
It is oin the refrigeration unit, if it is not the power ie. outlet. Then not much you can cost effectively do. Could be compressor, dirty coils, thermostat or leaking refrigerant.
Aug 26, 2009 | Avanti Hot and Cold Water Cooler
The compressor on my Sears Coldspot is running at 175 degrees.
Refrigeration compressors used in domestic refrigeration are known as high side compressors, meaning the dome is at high side pressure and temperature.
As long as the condenser fan was running, and the coil was as clean as you could get it, then all is OK. There is no standard temperature that it runs at, and it has been tested to run hot anyway. The fact that you cleaned underneath will allow it to run a little cooler anyway.
Jan 28, 2009 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
True Refrigeration GDM-26 Compressor problem?
More than likely you need a new compressor. It sounds like it's trying to start and then trips on it's "Klixon" overload. Call a commercial refer guy (not somebodys brother in law that works on A/C, it's NOT the same!)
Jul 15, 2008 | True GDM-26 Refrigerator
My fridge is running but not cold
Is the compressor running? How about the fan motor? Chck. those items first and when there be sure coil is clean. Now coil is clean, fan and compresor are running, then you may have leak on the system. Quik test, unplug frige from wall and plug it back after a few second, if compressor runs, you have a leak.
Oct 24, 2007 | Nor-Lake Norlake Refrigeration 4' x 6'...
Refrigerators Logo
42 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
