Question about Nikon COOLPIX S230 Digital Camera
I fthe camera is on then I plug it in, the computer does not detect the camera's data and say's the camera is in use. But if I turn it off, the computer does not detect the camera at all.
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • Nikon Master
  • 102,366 Answers
Try NOT connecting your camera to your computer.
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program.
Posted on Jun 17, 2011
Why won't my hp 1080p turn on for 1sec then off and can't get it running when hooked to computer?
Most camera work that way. When you connect the camera to computer, and the camera is turned on, it will be detected and will be ready to transfer the data into computer.
The camera will NOT work as webcam and keep trasferring to computer as well.
Apr 28, 2014 | HP V5040u 1080p High Definition Digital...
Recover data form hard disk
What is wrong with yoru hard disk?
If you can't access your files,data recovery program can help.I used this one called Tenorshare Data Recovery to retrieve files off crashed HDD and it worked.
If needed,you can download it and scan your hard drive for free to preview whether your files can be recovered.BTW, you can get it from
Tenorshare Data Recovery for Windows Users
Tenorshare Data Recovery for Mac Users
Can't get it detected?
Turn the computer off without the external hard drive being plugged in.
plug the external hard drive in a usb port, power up, the systems post boot up will find the drive and inform windows what hardware is installed.
When windows boots up, it will look at all the hardware and find the external hard drive, when windows finishes booting up you should be able to see the drive in my computer.
Jun 25, 2012 | Canon PowerShot SX30 IS Digital Camera
Trying to copy photos to a folder using Microsoft Scanner & Camera Wizard. Camara is on and is connected to my PC with a USB cable, but the computer can not detect the camara.
First, check both ends of the USB cable to be sure that the ports and the plugs are properly seated so that the metal pins are able to transfer data. Restart Windows with the cables plugged in, and the camera should be recognized. You also MUST have the camera turned ON in order for the computer to read the fact that it is connected. If these suggestions fail, check your Microsoft Computer Management program to be sure that PlugnPlay devices are automatically recognized by your system.
Have fun with your photography!
Sciencewoman
Mar 31, 2011 | Samsung SL202 Digital Camera
Hello I can not download picture to my computer ....it does not seem to pick up that anything is plugged in? please help
1. you want to purchase the data cable for your konica digital camera.
2.Then connect the one end to the camera.
3.Connect the other end to the computer's usb port.
4.Your camera will detected by the computer then you can access the pictures and import it to the computer.
5.Install your Driver CD which Came with the camera install it for better result.
Sep 12, 2010 | Konica Minolta DiMAGE Z3 Digital Camera
How to import files from camcorder to my pc
If you have data cable given to the camcorder connect it with the camcorder and the other end to the usb of pc.Then computer can detect the device ,import files to the computer.Install your camcorder driver before plugging data cable
Sep 06, 2010 | Panasonic VDR-D100 DVD Camcorder
When i plug my camera to computer it says safely remove usb mass storage device drive (e)
When we connect the camera to the computer using USB cable we need to make sure that the camera is turned on. If the camera is not turned on then the computer will not detect the camerea.
May 28, 2009 | Sanyo Vpc-s1070w Digital Camera
Fe-190 can't be detected as Imaging device
If you are using a Windows computer 2000/xp/Vista
you need no software Windows has all the facilities it needs.
If the Computer cannot detect the camera when it is plugged in to the computer USB socket and switched on and set to up load.
Then there would appear to be a fault with the camera or battery.
I suggest you remove the card from the camera and try to get it read by a friend or processing station to establish if in fact the card has images/data on it.
Jan 05, 2009 | Olympus FE-190 Digital Camera
Turns the computer off when plug USB into a computer
did you try using the camera with a different data cable? there could be a peoblem with the data cable you are using
Aug 16, 2008 | Konica Minolta DiMAGE Z1 Digital Camera
Computer not detecting plug n play devices
run device manager and remove all aunknown device, specially usb storage device..then restart the computer
Mar 28, 2008 | Microsoft Windows XP Professional
Problem
just plug in your camera to the pc, win xp automatically detects camera (if you upgrades frequently)and downloads necessary driver
Sep 25, 2007 | Sony DCR-DVD703E DVD Camcorder
Nikon COOLPIX S230 Digital Camera Logo
29 people viewed this question
Top Nikon Cameras Experts
Steve
Jeff Marcus
Are you a Nikon Camera Expert? Answer questions, earn points and help others
