Question about Mackie FRS1300 Car Audio Amplifier
How much is it or can i get a replacement knob for this?
  • 23 Answers
How to replace the knob and stem on a frigidaire range?
Stem is part of control switch need to replace control .....
Knob is probably fine, just pull out shaft from knob use old knob on new switch as long as plastic knob is not broken
Aug 12, 2014 | Frigidaire Kitchen Ranges
On/off swith knob broken
Is it the actual knob that is broken or the little tab the knob holds onto that is broken. You either need a replacement knob or a replacement switch assuming the know is also the thermostat for the unit. Does that same knob control the fan speed? Temprature or timer?
Mar 31, 2014 | Pelonis Heating & Cooling
My frigidaire oven knob quit working. The knob turns but it does not adjust the temp.
the knob is probably stripped. if the stove is from 1950 you may want to consider replacing it. If it is not to expensive to replace the knob you can try that just email the company and see if they can send you a replacement knob
Jan 15, 2013 | Ovens
The steam knob has broken. I have a replacement with no instructions on how to remove the knob
My husband replaced the knob on our Magnifica. It actually pops on and off. When the knob is in the Off position, take a butter knife under the RIGHT side of the knob and gently pry the knob out about 1/8". At that point, you should be able to use your fingers to pull the knob straight out. When replacing the knob, be sure to line up the flat spot on the inside of the knob with the same spot on the coffee machine.
Apr 29, 2012 | DeLonghi EAM3400 Espresso Machine
Starter knob on GE dryer came off. Dryer won't turn on.
If it turns hard, the timer may need replaced. But if you can turn the shaft with a pair of pliers and the dryer works, just get a new knob.
Jan 04, 2010 | General Electric WHDRR418GWW Dryer
Need replacement security door knobs
You find replacement door knobs at any hardware or home improvement store (ACE, Lowes, Home Depot, etc.)
Jun 09, 2009 | Hardware & Accessories
Compatible replacement handles for Moen Garden Tub faucet
I dont know if moen made chrome handles for that valve back then. If they did then they will probably be lever handles but they wont turn correctly unless you remove the cartridges and turn them. Iwould suggest probably replacing the whole unit.
Apr 20, 2009 | Moen Chateau, Two-Handle Garden Tub Faucet...
Removal of the timer knob.
you have two different knobs to replace?..is it the water level knob or the timer knob?
if its the timer knob you need to remove, look underneath the timer and you will find a black plastic pin depressed at the middle. pull it slowly for about 1/4 of an inch.
then you can remove the knob in the front of the timer switch.
in putting it back, install the knob first in the timer and then depressed that black plastic pin to lock the knob.
be carefull not to pull the plastic pin all the way out. it would be very hard to put it back in.
cheers,
drcool
Aug 02, 2008 | Frigidaire GLWS1339CS Top Load Washer
Mackie FRS1300 Car Audio Amplifier Logo
Top Mackie Car Audio & Video Experts
xxxxxx xxx
Are you a Mackie Car Audio and Video Expert? Answer questions, earn points and help others
