Question about HP OfficeJet 7310 All-In-One InkJet Printer
What means error Oxc0620004 ? - HP OfficeJet 7310 All-In-One InkJet Printer
  • 4,472 Answers
That means the ink system or the printing mechanism of your printer has gone bad because either the printer is connected to a power strip or surge protector or you are using ink cartridges which are running low on ink.
I would try unplugging the unit for a minute and then plugging it back in. Also if it's not plugged in directly to the wall you may want to try that.
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00489814&tmp_task=solveCategory&lc=en&dlc=en&cc=us&lang=en&product=391182#N60
That link may help you as well follow the instructions if the error also includes ink system failure. Here are some other steps for trying to reset the error if not the unit may need to be serviced:
Without turning off the product, disconnect the USB cable from the rear of the product.
NOTE: The USB cable connects to the port on the back of the product. The port is labeled with the USB icon
  • Remove the cartridges from the product.
  • Wait for the 'Insert Cartridges ' message to display on the control panel.
  • Disconnect the power cord from the back of the product.
  • Wait 60 seconds.
  • Reconnect the power cord. If the product does not automatically turn on, press the Power button (What means error Oxc0620004 ? - c01602202.gif ).
  • Reinsert the cartridges, and then close any open doors on the product.
  • If you receive a prompt to print a calibration page, do so.
  • Reconnect the USB cable to the rear of the product, and then try printing again.
  • Thank you,
    Lee
    Posted on Nov 08, 2010
    I have a R 93 ami jukebox and keep haveing error codes 1and4 what do they mean
    Error 4 means the memory backup battery inside the Central Control Computer is dead or very low. Error 1 means factory defaults are being loaded due to a dead battery.
    Jun 15, 2014 | Wurlitzer Jukebox CD Player
    What does this error mean dryer has error f-01?
    The "F1" error means that the dryer's thermistor failed and needs to be replaced. Make sure you check the dryer vent for clogs before installing the new part.
    May 04, 2014 | Kenmore Dryers
    Erorr code 4003 zebra zxb8
    Error Code 4001
    System error code 4001 means "The local WINS cannot be deleted." This error code may also display as "ERROR_CAN_NOT_DEL_LOCAL_WINS" or as the value 0xFA1.
    Error Code 4002
    System error code 4002 means "The importation from the file failed." This error code may also display as "ERROR_STATIC_INIT" or as the value 0xFA2.
    Error Code 4003
    System error code 4003 means "The backup failed. Was a full backup done before?" This error code may also display as "ERROR_INC_BACKUP" or as the value 0xFA3.
    Error Code 4004
    System error code 4004 means "The backup failed. Check the directory to which you are backing the database." This error code may also display as "ERROR_FULL_BACKUP" or as the value 0xFA4.
    Error Code 4005
    System error code 4005 means "The name does not exist in the WINS database." This error code may also display as "ERROR_REC_NON_EXISTENT" or as the value 0xFA5.
    Error Code 4006
    System error code 4006 means "Replication with a nonconfigured partner is not allowed." This error code may also display as "ERROR_RPL_NOT_ALLOWED" or as the value 0xFA6.
    System Error Codes
    Sep 15, 2013 | Zebra ZXP Series 8 Thermal Card Printer
    My printer will not print. I get error:oxc0620004 411:lib-micci2.0 messages.
    Hi there maximum time we found it is a the head problem. The print head is what the cartridges sit in inside of the printer. For resolve the problem please follow these.
    Open the printer and wait for the carriage to slide over. Some how if its not come then Unplug the printer & Manually slide the carriage. Now Remove the ink cartridges from the print head & Use wet warm cotton swab or use alcohol to thoroughly clean the print head. Repeat this until there is no ink residue coming off on the cotton swab. After finished it make the head dry then fix it back. Now Try to print something now
    If that does not work then follow the next step.
    Remove the printer data cable & restart the PC & printer. Then fit back the data cable & turn on the printer. Hope that's start working , if no luck then Uninstall the printer driver & restart the PC & Printer both again. Now install the driver of the printer and connect it with PC ,Turn on printer & go for a test print from the printer preference. Thanks & waiting for your reply.
    Jan 15, 2011 | HP PSC 1610 All-In-One InkJet Printer
    Error codes
    Here are the common error codes for the LG machines.
    LG Washing Machine Error or Fault Codes
    If you have a LG Washing Machine you may see an error code come up and wonder what it is. Here are the common error or fault codes that will be displayed on the LG machine.
    OE
    This means that the washer has tried for ten minutes to drain the water out of your machine and the water did not drain out.
    UE
    This means that the load in the drum is out of balance causing excessive vibration when spinning.
    IE
    This means that the washer has not filled with water in 8 minutes.
    LE
    This means that the motor and the control panel are not talking to each other properly
    PF
    Power Failure – The power has gone out to the machine and then has come back on
    FE
    This means that there is too much water in the machine
    PE
    This means that the water level sensor is not working properly
    CE
    The washer motor has received and over current condition
    TE
    This means that your heating sensor is not working properly
    SE
    This means that you had a temporary sensor error
    HE
    This means that you had a temporary heater problem
    DHE
    This means that you had a temporary dry heater problem
    This will give you a basic idea of what has caused your error code.
    Heatman101
    Mar 15, 2010 | LG WM2277H Front Load Washer
    HP Photosmart 2610 displays Error: Oxc0620004 411:lib_micci2.c -- This happened a few minutes after I successfully printed a document. Tried to remove ink cartridges as per HP directions, but they will not...
    In addition to the error message Ihad a display of flashing lightsI disconnected all the leads anf placed theprinter on a table for easy access. Searched for scraps of paper etc none.THen noticed that the back panel was not properly secured.Tidiedthis up-reconnected OK
    Jun 07, 2009 | HP OfficeJet 7310 All-In-One InkJet...
    Code errors on kodak easyshare esp 3
    error code 3501 means the front access door is open on the printer. Error code 3502 means the paper tray is empty. The error code 3602 means the print job did not finish printing.
    for more hrlp visit CBR Tech Solutions
    Apr 10, 2009 | Kodak ESP 3 Multifunction Printer/ Copier/...
    Hp 2355 all in one error message
    open the rear access door and clean the rollers with a cloth, dam it with little water and unplug the machine and press and hold the ON button for 1 min and release the button and plug in the power cord, it should resolve the issue.
    Regards,  raj_p5983
    Jan 21, 2009 | HP OfficeJet 7310 All-In-One InkJet...
    reset to factory defaults, also check the whole printer for paper jams. A paper jam can often casue smaller pieces to get stuck in gears or rollers. The message about opening and closing the lid is how the printer knows you went in to check it and closeing it triggers it to try again. If thers still a jam it will keep giving the message. The fist jam was caused by something, check and make sure there isnt any pieces of plastic broken off inside. If it has a rear access panel, check there also.
    Feb 16, 2008 | HP PSC 2355 All-In-One InkJet Printer
    HP OfficeJet 7310 All-In-One InkJet Printer Logo
    85 people viewed this question
    Ben Johnson
    mukhtar21 shaikh
    mukhtar21 shaikh
