Question about Whirlpool Dryers
Wed8300swo whirl pool dryer replace motor you set all setting push start nothing comes on but the heat
  • Whirlpool Master
  • 43,501 Answers
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Posted on Nov 11, 2010
Hi! I have a whirl pool thin twin washer/dryer combo model # ltg6234aw1. The washer will stop before it rinses. Ive tried stoping it and starting it again and nothing. Ive tried putting knob all the way...
your water filter outlet is blocked up
or the pump has something inside it stopping it rotating
so you have a blockage
inside the wirlpool on top of the dryer unit youll see two disks
bolted on that have 4 wires
you need first too check all screens and clean any lint from the whole heater assembly
anywhay at the center of the two disks {over heat sensors} is two small red plastic cyclinders
just press both back in and then the heating is reset
some machines will need these replaced instead
anyway you need to also check the motor brushes and
replace them if needed and clean the motor with a dry brush to remove any carbon dust
now once your sure the drain and heater paths are aok and free from any blockages
your good to go
you can reset the machines controller by turning on the mains at the plug / socket while you hold in the start stop {or sometimes power } look up this detail in google
hope this helps
Dec 01, 2014 | Washing Machines
The heating element in my GE dryer I noticed the element will come on when the timer is set and without pushing the start button. The drum isn't turning when this occurs. The cabinet is still apart and...
There is a heater switch in side the motor that is bad have to replace the motor unfortnatly. The main power wires run thru the motor to the heater.
Jan 04, 2011 | Dryers
Have a Whirlpool GEQ9800LW0 and it won't start. When I set the timer and push the start button nothing happens. The timer still makes it's usual clicking sound but the dryer won't start. What needs...
Check power to the inlet valve, if absent let the program move forward and if the motor does not work either it is possible that thetimer though ticking is not contacting.
So go back to check for the wash cycle, when start is pushed, inlet valve on, water comes in, water fills , triggers level sensors,washing starts with motor on.
If there is no voltage on any parts ,the timer contactor is faulty
Sep 19, 2010 | Whirlpool GEW9200L Electric Dryer
I have an electric whirlpool with start switch not working
OPEN THE DOOR/PUSH THE START SWITCH ON DRYER/THEN PUSH THE DOOR SWITCH/HAVE A PERSON TURN THE DRUM/IF IT STARTS TO TURN (DRUM) OR STILL HUMS AND DRUM WILL NOT TURN YOU HAVE A BAD MOTOR/REPLACE MOTOR.
FREDDY
Feb 14, 2010 | Whirlpool LGB6300 Gas Dryer
Maytag dryer makes an electrical buzzing noise when start button
It sounds to me like the motor is not turning, but the heating element is coming on. with no air flowing over the element, it is getting too hot. Can you operate the start switch with the top tilted up so you can see if the motor is turning but the drum is not, and just where the buzzing is coming from. Also, I would try the dryer on manual setting and on air dry to see if any setting works. Good luck
Jan 07, 2010 | Maytag MDE6000 Dryer
Whirl pool dryer LEC9000PW0 will not turn on
Has a household fuse blown or has a circuit breaker tripped?
There may be 2 household fuses or circuit breakers for the dryer. Make sure both fuses are intact and tight, or that both circuit breakers have not tripped. Replace the fuse(s) or reset the circuit breaker(s). If the problem continues, call an electrician.
Is the correct power supply available? (Electric dryers only)
Electric dryers require 240-volt power supply. Check with a qualified electrician.
Is the dryer door firmly closed?
Your dryer door may not be fully closed. It may look shut, but may not be latched. Push on the door to engage the latch or latches. Some models have an upper and lower latch. Both latches must be secure for the dryer to run.
Was the Start, Push to Start or Hold to Start button firmly pressed?
Large loads may require the Start, Push to Start, or Hold to Start button to be pressed and held for two to five seconds.
Is the Cycle Control knob set on a Sensor Dry or Timed Dry cycle? (on some models)
The Cycle Control knob must be set in a Automatic Dry or AccudryTM or Timed Dry cycle. The dryer will not start if set on the Wrinkle ShieldTM option.
Is Controls Locked status light on? (on some models)
Press and hold the Cycle Signal button for three seconds. This will turn off the Controls Locked feature.
Did you recently install a power supply cord on the dryer? (Electric dryers only)
The power supply cord may be incorrectly installed. If the power cord is incorrectly installed, the dryer may not start or heat. Review the Installation Instructions to check that the power supply cord is properly installed.
Dec 02, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Dryer heats up but won't turn
Depending on the make of dryer,there are several possibile reasons for this.
First and foremost, could be a faulty motor- faulty start capacitor, Faulty start relay.
Without more information I cannot be more specific.
Hope this helps.
Please leave feedback.
Thanks.
Nov 27, 2008 | Dryers
I need to replace the belt in my ge dryer. how do i get the back off to get to the inside. we have unscrewed every screw and it doesn't seem to want to come off.
whirl pool and most other manufacturesdryers are front serviceable for belts depending on dryer top pops up (2 srews under filter on whirpool top filter dryers )2 front clips push those in top lifts ..2 screws on inside front panle take out front lifts off
Apr 26, 2008 | Dryers
My Dryer Heats but won't tumble
do you hear a humming noise? and is air coming out the rear if so the belt has broke if not the motor has gone bad let me know what you find
Jan 08, 2008 | Whirlpool GEQ9800P Electric Dryer
Whirl pool Dryer not staying hot
you need to have your gas valve coils replaced good luck
May 27, 2007 | Whirlpool LGR4634J Gas Dryer
Dryers Logo
56 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal De
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
