Question about Garden
Plugged dewalt portable table saw DW744 type 1 , turned on and immediately cut out ,,,cant find a reset ,,can you advise in regards to my problem..thanks Jeff Scanlon
  • 7,733 Answers
Do a overhaul of all the fuel components,change the spark plug or the coil entirely.
Posted on Nov 09, 2010
What is the field resistance on a dw744 xe 240v
if your field coil is dead,most of the time when you run the motor 1 brush spark more
inspect visually for the blackened area or darker on the windings
the resistance is too low to be mesured with dvm
Oct 14, 2012 | Dewalt DW744X 10" Heavy Duty Portable Tab...
The motor sometimes starts right away and at other times I have to use a wood stick to spin the blade and it starts
the brushes in a dw744 have a ledge when they get too short that hangs up. replace the brushes and you should have no problem. the brush holder comes right out with a little coaxing with a screwdriver after the end cap is removed. it just plugs right in.
Dec 22, 2010 | Dewalt DW744S 10" Portable Table Saw with...
Where do i buy an arbour for dw744 table saw
If you have a type number of 4, an assembly will have to be replaced, not just the shaft. THIS COULD BE DIFFERENT IF YOU HAVE A DIFFERENT TYPE NUMBER. It can be purchased online through DeWalt, but verify your type number before ordering.
http://servicenet.dewalt.com/Parts/Search?searchedNumber=153476-07&searchType=1
I hope this helps!
Nov 21, 2010 | Dewalt DW744X 10" Portable Table Saw
Can i use parts from dw744 .qs from usa in norway . usa have 110v and we have 220v
I would have to think it would depend on what parts you are talking about. You can try and go to Dewaltservicenet.com to check compatability on the 2 items.
Aug 08, 2010 | Dewalt DW744X 10" Portable Table Saw
Replaced armature and brush's and there is alot of heat and spark and it starts slowing down?
Unless somewhat preformed, brushes have a tendency to arc like crazy and can produce heat and even smoke. I would remove the brushes and use a fine 'keyhole' type file to give them a little inside curve so they have better contact to start with.
Nov 02, 2009 | Dewalt DW744 Factory Reconditioned Heavy...
Dewalt dw744 motor runs slow and smokes, what parts need replacing?
probably whole motor, if the bearings started to seize up it could have caused the armature/field to burn or if you overloaded the tool the same thing would happen. Does the tool have a burnt electrical smell, if so the motor is burnt and the cost of parts might outweigh getting repaired, You can go to Dewaltservicenet.com and find out the prices and also you might want to call a Dewalt Factory Service Center and ask them about the MAX repair rate on this tool and they will fix everything for that price, no matter what.
Oct 12, 2009 | Dewalt DW744X 10" Portable Table Saw
The saw has stopped I know the circut it is plugged into is live is there a reset button or built in breaker located on the saw? Dw744 10 inch table saw
NO reset or circuit. You can try and unplug tool and blowing into all the exposed areas of the bottom of the saw. WEAR safety goggles. Then what I would do is check the brushes and if you have a volt ohms meter check the continuity to the brush tubes. Start at the cord looking for a break in wiring and go from there. Let me know if you need more help, but I am going to thing brushes or switch
Jun 27, 2009 | Dewalt DW744S 10" Portable Table Saw with...
DW744 table saw
Balde movement up and down? If so, that would suggest worn bearings in teh gearbox. If they are worn there then they might also be worn in the motor. If this happens the armature will float up and down causing it to rub against the stator. You may be able to get the bearings sorted without needing any new motr parts. I beleive this saw uses an induction motor so beware if it does need replcing you might want to be sitting down when you get the quote.
Oct 19, 2008 | Dewalt DW744 Factory Reconditioned Heavy...
Garden Logo
152 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
