Question about Home
I have a necht millenium toilet seat which needs replacing but it's not a standard shape or size. Where can I get a replacement?
  • 9 Answers
SOURCE: the toilet seat has split
Hi, Dayne here,
You can buy a new seat from Lowes or any of those places For 11-20 dollars. If you look at the hinge where the seat mounts to the bowl, with a screw driver, pop open the small access doors on top to expose the screw heads. From underneath, hold the nut with pliers or a wrench and remove both bolts. To install new one just reverse this order.
Thank you.
Posted on Dec 22, 2010
  • 50 Answers
SOURCE: Need to replace working parts , push button , one piece toilet
Here is a link to a site with a ton of replacement parts for amstan toilets.
Without model numbers etc. its hard to know exactly what parts you need but you should be able to look at the pictures on the site and order the right parts...
http://www.plumbingsupply.com/amstan.html
HOpe that helps...
Posted on Feb 09, 2009
SOURCE: Square toilet seat made by American Standard Model TL 235.
This guy Allen in NY has lots of odd seats. Try him 914-963-6895
Posted on Nov 09, 2009
  • 3600 Answers
SOURCE: How do I replace the toilet seat on a Kohler
I repaied one of these laast week and it had the Plastic nuts in between the webbing on the seat where the lid connects I believe You remove the plastic cap with a knife and use a flat tip screw driver to remove the screws and replace the seat.
Posted on Jun 01, 2010
  • 268 Answers
SOURCE: How do we replace the seat on a Kohler K-3386-0
Kohler will try to sell you $46 anchor bolt kit 84999 & also there special tool. You should expect that for a $400 toilet.
Try this instead:
1. Use 1/8" drill bit and drill and drill around the bolt until the anchor material can be removed.
2. Carefully clean hole with 11/32 drill to remove all remaining acchor material.
3. Go local hardware store & buy a 10 - 32 3/8"X3/4" rubber expansion plug (make certain threaded part is brass & has shoulder on 1 end), a 10 - 32X1.5" Phillips bolt and couple of small fender washers fit the seat.(about $4 for 2)
4. Assemble carefully not to over tighten and crack the porcelain.
Hope it helps
Posted on Oct 07, 2010
Where is the serial number - toilet is 25 yrs old and need a new toilet seat.
Typically there is no serial number associated with a toilet seat. The seat will either be a round front or an elongated seat. Just make sure the shape is the same when purchasing the replacement seat.
Jan 20, 2015 | Porcher Home
How to install a u shaped toilet seat
Remove old by loosening nuts from under rear of seat and reinstall new seat in the opposite
Aug 10, 2014 | American Standard Church Seats EL270...
Replacement seat....size???
American Standard is the brand, so you've got a start there, but 1.6 is a flush measurement. Look around the inside for a tank for a model number - with AmStan toilets it's usually a four digit number beginning with a 2 or a 4. This will be what you need to get the OEM toilet seat. However, since toilet seats are purely cosmetic (they don't affect the functioning of the toilet), you can literally take a few measurements and find something that simply keeps you off the porcelain. http://www.plumbingsupply.com is a good one for toilet seats, btw.
Aug 21, 2012 | Home
Need to replace toilet seat and cover for a Williamsburg, white toilet. The part number I have is 5395.700.....but I have learned this number no longer exists. What number toilet seat/cover fits a...
Your toilet is still offered by the manufacturer:
http://www.americanstandard-us.com/toilets/williamsburg-one-piece-elongated-toilet/
Available replacement toilet seats from American Standard can be seen and ordered here:
http://www.americanstandard-us.com/repair-parts/toilet-seats/
You might consider finding you nearest dealer or choose another on-line retailer:
http://www.americanstandard-us.com/dealerLocator.aspx
Before ordering suggest you confirm with American Standard Customer Service the appropriate replacement seat for your model.
http://www.americanstandard-us.com/customerservice/onlineStoreSupport.aspx
Mar 15, 2011 | American Standard Williamsburg Toilet Seat...
I have an antiquity 2038 toilet and replaced the flapper and it still leaks what can i do now?
use toto or over size flapper. kohler makes one with a bulb portion that wil seat into the flush valve
Sep 02, 2010 | American Standard 2038 - Antiquity...
I have a square shaped toilet and need to replace the seat. Where would I find one?
Check with your local plumbing supply houses. I believe Kohler and Eljer noth made square front bowls at one time. I hope this helps.
May 19, 2010 | Home
What size toilet seat fits a sanicompact elite?
The manual http://www.saniflo.co.uk/pdf/install/Sanicompact.pdf shows that the lid and seat is of an elongated design and I think that you would need to get a direct replacement instead of trying to fit a standard seat/lid combo as a replacement. A normal seat/lid may line up with the fixing holes, but would probably not be the same elongated design.
You should be able to get a direct replacement from your plumbers merchant (may need to order), or from Saniflo directly http://www.saniflo.co.uk/
If this helps please leave feedback, if not let me know and I'll try and help some more!
Jan 31, 2010 | Elite Saniflo SaniCompact- SaniCompact One...
Home Logo
142 people viewed this question
Top Home Experts
Donni Steen
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
