Question about Yamaha RX-V661 Receiver
RX-V661 front display problem
Comment by Holyrider, posted on Jun 09, 2008 I had also exactly the same problem with the front display of my Rx-V661which was becoming completely blank... As mentionned as solution, I replaced the four capacitors handling the display power. Then, my display was back. (I didn't replace the diodes which were well working with new caps, so...)
I thought that problem was solved. But one week later, this problem was back and now, I haven't again nothing on front panel screen...
I suppose that there is something else which damaged the caps....but what's wrong?
Someone can help me?
  • Holyrider Jun 20, 2008
    at source, caps of 50 V are installed. Do you think that if bad caps are replaced by new ones of 65 V, it will solve this problem???
  • Anonymous Mar 30, 2014
    Hi guys, My Rx-397 gets power on, for a second and gets off, every time i power it on. I can see the front panel display also but the problem is power gets off....plz help
  • 979 Answers
Excess power supply demand from the display can cause the symptoms you describe. Unfortunately, the fix will be a new display if this is the case...accordianman
Posted on Jun 20, 2008
  • Michael Borelli Jun 20, 2008
    That will be a temporary fix, but it could last a few years...accordianman
Clock light and temp.light fading out.what needs to be fixed
LED clock/temperature light fading an - Appliance Repair Forum
forum.appliancepartspros.com/oven...ranges.../650-led-clock-temperatur...
Aug 20, 2007 - 3 posts - ‎3 authors
The LED clock/temperature/etc control light has been becoming less ... needs to be replaced (board being the oven clock/erc/control board). Control pad temperature light out
Jun 15, 2014
Dim temp lights
Feb 7, 2014
Frigidaire range LED display is dim
Aug 28, 2009
Oven clock & light
1 post
Jun 21, 2009
More results from forum.appliancepartspros.com
Cheap Fix for a Dim Display on an Oven Control Panel ...
Nov 29, 2015 | Whirlpool 30" Self-Cleaning Freestanding...
Yamaha RX-V663 display is not working
If you have your receiver hooked up to a TV or Monitor, press "Menu" then toggle to section "5" "option menu" and check your "Dimmer" setting "0" is highest. Then check "FL Scroll" and the choice is "Cont". This info is on page 96 in your manual, if you don't still have a copy, here's the link
http://www.yamaha.com/yamahavgn/Documents/YEC/AV_Receivers/Manual/RX-V663_U-1.pdf
Hope this helps. If you still have a problem, post a comment and I will help you further.
Dec 26, 2009 | Yamaha RX-V663 Receiver
Yamaha RX V 657 - No Sound Output, and No input detection
Bad DSP chip. The only other possibility is if you have the "Direct" on. On the front of the receiver it's a small button. Also make sure your "Speaker Select" A/B is "on" You will see it on the display, it's also a small button on the front of the receiver. If all this is correct and you still have no audio, it's a bad DSP chip. Not worth repair, it's 400-500 repair. Not very common in a Yamaha RX-V series, but I have seen it. I'm a Yamaha Dealer. If you need further help, post a comment and I will be glad to help you further.
Aug 23, 2009 | Yamaha RX-V663 Receiver
I dont get streo sound from my front left and
On the front LCD display of the receiver their is a small button for speakers A & B, make sure they are both lit. If they are, post a comment and I will help you troubleshoot further
Jun 29, 2009 | Audio Players & Recorders
1986 Volvo 240 DL alternater
Reuben, did you recieve my last email about trouble shooting your problem? I sent it a while back but I'm not sure if you received it because it doesn't show on the site here. Let me know so I can re-send. Thanks
Jun 25, 2008 | 1984 Volvo 240 Series
Thanks........
Comment by ohms, posted on Jun 19, 2008Definitely it is not your computer. When it was given the signal to go OFF, it did but like completely off. Comment by ohms, posted on Jun 19, 2008Oh one more thing, if the monitor still exhibits same issue after setting your Power Options as displayed above,
check your warranty with that monitor and exercise it.
Yep u got it !
Jun 19, 2008 | Gateway FPD2275W LCD Monitor
LG Monitor L194WT - Indicator Lights Flashing
sorry - i posted my response at the original thread : )
Yep u got it ! warranty or new monitor
Jun 19, 2008 | Computers & Internet
Water dispenser keeps flowing when water source is turned on
HI,
I have a little experience on your problem.S i suggest you to ask another experts advice.
Jun 13, 2008 | Refrigerators
Bad picture
Try changeing the image quality, is this a cheap around 30usd model?
Comment by Ekse, posted on Jun 12, 2008 Still image: 640 x 480 (high-resolution setting), or 320 x 240 (low-resolution); movie clips: 320 x 240
the thing is this a very cheap camera and the quality doesn't get any better than that. Comment by Ekse, posted on Jun 12, 2008 I can find this camera for even 20 dollars, you have a cheap knock off. You can't get a quality camera for this cheap. Comment by Ekse, posted on Jun 12, 2008 but if you change the setting to high resolution 640x480 which by the way still is very bad. it should look a little better.
Jun 08, 2008 | Vivitar MAGNACAM Binocular
Yamaha RX-V661 Receiver Logo
442 people viewed this question
Top Yamaha Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Yamaha Audio Player and Recorder Expert? Answer questions, earn points and help others
