Question about Whirlpool WGD5800S Dryer
My woorlpool gas dryer will not fire. The model no. wgd5800swo.
  • Whirlpool Master
  • 43,501 Answers
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check out this electric no heat tip...
heatman101
Posted on Nov 11, 2010
Have a five year old Amana Gas Dryer Model Number NDG5805 that makes a buzzing sound only when it is heating, what could be the problem?
the gas valve coils on the gas valve body that hold the gas valve open to supply gas to fire the burner are getting loose and need replacing
Mar 08, 2011 | Amana NDG5805AW Gas Dryer
Gas dryer does not heat
A gas dryer is nothing to mess with if it does not fire up the flame. Pull the lower kick plate off the front of the dryer, unplug the unit and clean out dust/lint build up. Vacuum as needed.
Then after checking that the gas valve that is connected to the end of the gas line that connects from the dryer to the wall, I recommend you get a professional.
Common failures are the pilot / ignition system / thermocouple.
No way to be more specific unless you provide the brand and model number of your dryer.
May 21, 2010 | Kenmore 74602 Gas Dryer
My Frigidaire gas dryer isn't hot. Otherwise it runs fine.
it could be either your ignitor(glow coil) flame sensor control, or a defective thermal switch telling dryer its at temp and shutting off gas supply before it even fires initially
Oct 17, 2009 | Dryers
Dryer heating problems
If this is a gas dryer, this is commonly caused by bad gas valve solenoids. Please post back with your make and model so I can verify your configuration and assist you further.
Jan 25, 2009 | Dryers
Maytag gas dryer model#NDG2330AWW heating problem
your gas coils are bad. they open up for the first cycle but fail to after. Replace your coils and this will solve your problem
Dec 13, 2008 | Maytag Dryers
Samsung dryer smells like gas
Replace the operator coils. They are intermittant. Typical operator coils look like this:
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Nov 27, 2008 | Whirlpool GGQ8831L Gas Dryer
Maytag dryer MDG5500AWW will not heat. Tumbles but no heat.
Could be any number of things .. igniter ( which lights the fire that dries your clothes) over-temp switches ( that disable the gas valve from opening and won't let a fire get started..) Defective gas valve.. not opening to let gas in for the fire that dries our clothes..
Those are the main components in your system and not much more I can provide to you unless I had specific details on what you've checked etc.. maybe this link will help identify the parts associated with your dryer... and if your so inclined..can do your own diagnostics... http://www.pcappliancerepair.com/model-display.php Hope that helps...
Aug 24, 2008 | Maytag Dryers
My maytag dryer does not get hot how can i fix it the model number is dg212 series 01
We bought this machine last year, converted it to propane & have loved it. All of a sudden there is no ignition ( fire). I have taken off the front & cleaned everthing I could see. Still no fire. I have check the gas supply, the drum is spinning, the only thing I think I heard last year right after it started and right before the "FIRE" was a clicking sound? What ever you might sugest would be greatly appriecated! Thank You, Don Wagner Jr @ SmoothSeal1@aol.com
Jan 12, 2008 | Maytag Neptune MDG5500AW Gas Dryer
Whirlpool WGD5800S Dryer Logo
106 people viewed this question
Top Whirlpool Dryers Experts
Sal De
Craig Butler
Craig Butler
Marvin
Marvin
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
