Question about Bosch 24 in. SHU66C02 / SHU66C06 Built-in Dishwasher
Bosch Logixx dishwasher alarm
When the dishwasher has finished, usually after all are in bed, it wakes up the house with a beeping alarm, repeated persistently at intervals until someone gets up and switches the machine off.  Surely there must  be a way to disable this alarm, but I can't seem to find out how.  Please help cure my insomnia!!
  • papaver Jan 25, 2009
    Me too. Very annoying. We have to close three doors so that the sound doesn't creep upstairs to the bedrooms.
I have found the operating manual online (see link to below off Bosch site) which explains how to do this - looks a bit fiddly by twisting dial and press/hold different buttons. Too complex to repeat in detail here so check out the website:
from the above page (which I know is not the same model)
- follow the User Manual link
- enter the correct model number (mine is WAS32466)
- select the operating manual instructions (installation manual may also be given)
- see section on Individual Settings / Signal.
Posted on Jan 25, 2009
Help, i turned by Bosch Logixx GSL 14424 GB freezer off to defrost and it now won't turn on...
Turn it round and check the electrics for the compressor are dry. You probably flooded them when defrosting and may have shorted something. If it still won't start with everything dried out, call a fridge technician
May 02, 2012 | Freezers
Water not emptying
check if the dishwasher is level. designed to drain correctly under level conditions.
Apr 21, 2012 | Bosch Dishwashers
My Bosch dishwasher is driving me crazy! When it finishes a wash cycle it beeps twice every 10 minutes until the door is opened. We can't run the dishwasher at night after dinner unless we're SURE we...
Hello there,
It would help to know the model number of the dishwasher, but on many Bosch dishwashers, you can switch the cycle cycle completion signal off as follows:
1. While holding the right-hand CANCEL/DRAIN button, also press and hold the ON/OFF button
2. When the LED above the CANCEL/DRAIN button illuminates and the beeping starts, release both buttons
3. Press the right CANCEL/DRAIN button repeatedly until the beeping tone is at the desired volume, i.e. silent!
4. Press the "ON/OFF" button again to set the volume.
On models with the wash cycle buttons on the top edge of the door, the CANCEL/DRAIN buttons aren't always explicitly labelled CANCEL/DRAIN. These buttons are also labelled RESET on some models.
On models with 3 and 4 wash cycle buttons, the right CANCEL/DRAIN button is the third button when reading from left to right. On models with 5 wash cycle buttons, the right CANCEL/DRAIN button is the fourth button when reading from left to right.
Please try the above then let me know if you need further assistance. Please state the model number or series (i.e. Integra) of your washer if/when replying.
Hope this helps.
Mar 16, 2011 | Bosch Dishwashers
Bosch LogiXX - wont go beyond the prerinse stage to wash; keeps recalculating the time to finish.
Mine does the same, but i have a workaround: Use the standard program called "normal extra" from the submenu - does that work for you ?
Jan 19, 2011 | Bosch Dishwashers
How do I turn off the "finished" signal? It beeps
To turn the cycle completion signal do the following:
1. Press and hold the right "Cancel Drain" button then press and hold the On/Off button
2. When the light on the "Cancel Drain button you are pressing illuminates and the tone begins to sound release both buttons
3. Press the right-most "Cancel Drain button until the tone is either at the desired volume or silent
4. Press the On/Off button again to confirm/set desired volume
Hope this helps.
If your problem has been solved, please be generous and award this solution 4 thumbs-up. This service has been provided FREE - your simple acknowledgement is appreciated. Thanks.
Nov 09, 2010 | Bosch SHX68M06UC 24 in. Built-in...
My bosch logixx dishwasher quick wash has never
i would change the control board or control module. thermador .com will let you order it.
Apr 09, 2010 | Bosch SHU9915UC Dishwasher
My Bosch logixx dishwasher is sticking on 1 minute at end of cycle; the dishes will be clean but still wet rather than dry.
100% add the jet dry until it is completetly filled then close the dispenser door and lower then raise the door.repeat this at least three times then check and fill if you can still add more. then after doing that b4 you start the machine run the hot water to get the right temp. when the water is hot enough then start the machine.
Mar 03, 2010 | Bosch 24 in. SGS09L12 Logixx Free-standing...
Bosch 24 in. SHU66C02 / SHU66C06 Built-in Dishwasher Logo
3,356 people viewed this question
Top Bosch Dishwashers Experts
Gerry Harvey
Gerry Harvey
Are you a Bosch Dishwasher Expert? Answer questions, earn points and help others
