Question about Audiovox Televison & Video
Audiovox Model No. VE 500 Kitchen TV. I cannot get any sound (audio). The picture is excellent, but no sound. Help! Thank you.
  • 93 Answers
SOURCE: Audio out connection
How did you connect it? With SCART, RCA cable, or what?
Posted on Oct 03, 2007
micromaster
  • 3614 Answers
SOURCE: Sound but no picture
This can be a Power supply failure- some of the filter caps could cooked dry and the yellow glue they use in this power supply turns conductive where it turns dark brown. You can unsolder the devices and feet on the heatsinks and remove them along with the stand-up driver board. Change some of the filter caps-1000u/16V, 470u/16V, 47u/50V, 10u/50V. Scrape and pick off the brown glue from all devices. Removed the fan and found the bearing was seized in it. Power supply will now run properly with the defect fan unplugged.
Posted on Feb 27, 2008
DarrenP
  • 78 Answers
SOURCE: no picture.
Tell a tech you need to resolder the legs on the inverter board - this should cost you a LOT less than letting them poke around to find the problem. This is a common issue with the Darfon v144-001 boards used in the FPE3000.
Posted on Apr 09, 2008
budmrtn
  • 11361 Answers
SOURCE: Audiovox model FPE3000, has sound and picture but
There are two places to look for the problems, the backlight inverter board and the power supply. Look at the power supply first since it is easier to get to, look for burnt parts, bad capacitors, etc.
http://en.wikipedia.org/wiki/Capacitor_plague
Please post back what you find.
Posted on Dec 02, 2009
  • 39 Answers
SOURCE: MY TV TURNS ON BUT NO PICTURE OR SOUND I HAVE A
you could have bad capacitors in power supply.You can probably see the they normaly have flat top.If top is round like a bubble it is bad.This is common problem with flat panel lcd tv and monitors
Posted on Feb 22, 2010
Sound quit on my hisense tv,plug and un-plugged, pressed on every audio tabs on remotes, picture is excelant, channels are excelant,the mute feature is ok,just no sound!
really need help from a professional...there must be some kinda complecation on the inside ,maybe caples are touching and they happen to be open(uncovered)
May 27, 2017 | Hisense Televison & Video
Model # LT-46249 tv has no sound
Check whether the TV is in Mute Mode.. Also check whether you've connected anything to the Audio output of the TV. like headphone or an external speaker...
Oct 15, 2012 | Mitsubishi LT-46249 46 in. HDTV-Ready TV
Trying to hook up digital converter box but cant get reception
This seems related to the TUNER and the IF section as the sound- audio and picture- Y signal does not process with the correct alignment.
Dec 06, 2011 | Audiovox VE727 7 in. Under Cabinet TV
MY TV TURNS ON BUT NO PICTURE OR SOUND I HAVE A AUDIOVOX FPE3206 MODEL
Feb 22, 2010 | Audiovox FPE3206 32 in. LCD Television
Adding vcr & rec to a '93
Please hook up VCR with TV through RF cable and check picture of VCR playback in TV.
Now you can hook DVD player video-audio out in VCR input and can have dvd playback picture in TV via VCR modulator.
If you want to listen sound via receiver then hook audio red-white cable between VCR audio out and receiver audio in terminals.
Let me know exact model numbers of units to help you out more.
Thank you.
Jan 13, 2009 | Televison & Video
AudioVox VE 1020 BAD DISK
I was able to find a junk unit (screen no good) on eBay -- swaped out the dvd player - everything has worked fine since (except 6 months later I had to swap out the audio card from the same junk unit - and now all OK ever since.)
Nov 10, 2008 | Audiovox VE1020 10.2 in. TV/DVD Combo
Repairing lcd tv.
thanks very much about your technical support.but i solve allready the problem of LG LCD TV MODEL LT-15A10 TROUBLE; no picture with sound, i replace the socketed ic SDA555XFL62 PINS. THANKS... LODIVAR.
Feb 17, 2008 | Audiovox VE920 9" ULTRA-SLIM DROP-DOWN LCD...
AUDIOVOX VE1020 has audio, but no video
Ok, here is a bizarro solution that just worked for me. It is a solution to the problem, not a technical fix.
1 Turn unit on
2 Using remote control unit press "DVD" button, upper left.
(When I did this the Audiovox screen appeared)
3 Then using remote control unit press "TV" button, upper left next to DVD button.
(For my unit, this gave me a TV picture)
Strange, huh?
Dec 14, 2006 | Audiovox VE1020 10.2 in. TV/DVD Combo
Televison & Video Logo
Top Audiovox Televison & Video Experts
Jaime Hernandez
romy sibug
romy sibug
Are you an Audiovox Televison and Video Expert? Answer questions, earn points and help others
