Question about Frigidaire FRS6R5ESB
The refrigerator quit getting cold a couple days ago, the cold air quit coming from the freezer side to the refrigerator. Although the freezer is cool, things like the ice cream are thawing. We took the cover off the coils to find that they had a lot of ice build up, we turned the freezer & fridge off for ice to melt. The fridge & freezer worked again for 3 days, last night the fridge quit getting cold again, same thing, we discovered that the coils are iced over, what can be causing this. We turned off the freezer and fridge over night, turned it back on this morning, it cooled for a couple hours then stopped again.
  • troy chen
    troy chen Nov 05, 2013
    Was your problem resolved? None of the info in below links was really geared toward this issue. They didn't help at ll!
  • Frigidaire Master
  • 43,501 Answers
Check out these tips...they can help you figure out what is going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Posted on Dec 27, 2010
Refrigerator not as cold as it should be, freezer too cold and has some frost
check the fan should be run in freezer & its air flow clear to refrigerator side,no blockage items or ice in its way oy of air flow
Jul 07, 2014 | Amana Refrigerators
I have a Frigidaire Model FRS6R5ESBF that is 3 years old but did not get installed until 4 months ago. The freezer appears to be working fine but the refrigerator side is getting warmer by the day. It...
Could be that the freezer is icing up stopping the air flow coming up into your fridge, try switching it off for at least 12 hours with the freezer door open.
Nov 02, 2010 | Frigidaire Refrigerators
If the coolant from the freezer compartment leaked, will the refrigerator still work (stay cold)? I know the freezer won't work. thanks.
There is only one coolant circuit for a refrigerator. There is a fan that circulates the cold air from the freezer side and pushes it through the refrigerator side and that's how that gets cold. So if all or some of your refrigerent leaked out then the refrigerator will have to be repaired by a qualified technician if you still want to use it.
Sep 17, 2010 | Haier HNSE05SS Stainless Steel
I can smell items in my freezer when I open the door of the fridg
Good day,
All cooling in a refrigerator, be it the freezer section, or the fresh food section is performed by the freezer.
The freezer takes care of itself, but also by the function of the fan motor in the freezer, blows a limited amount of the freezer air into the fresh food compartment to cool it to the nominal 37 degrees.
The odor in the freezer is disguised by the extremely cold air, and is not apparent. But that odor when raised to 35 or 40 degrees will become noticeable.
As well, the freezer compartment rises to 30 degrees plus when going thru it's automatic defrost cycle, which occures for approx. 30 minutes once or twice a day, adding to the problem.
Sealing the packages is probably the only real answer.
Thank you for using FixYa.
Dec 18, 2009 | Kenmore Refrigerators
My freezer stopped freezing a couple of days ago,coil frozen up i defrosted it and now no air is blowing into refrigerator part both freezer and refrigerator are not cold
if the fan is not running then most likely the defrost stat has failed but you should also check the fan for continuity if you have continuity the fan should be ok you can find a defrost stat on parts advantage.com
May 10, 2009 | Amana ARS2661B Side by Side Refrigerator
REFRIGERATOR AND FREEZER UPPER HALF NOT COLD
If you live in a humid area, I'll bet ice buildup is screwing with the air flow. I have a similar, but less intense problem. So in my case, simply unplugging the fridge and letting all the hidden internal ice melt solves it for several months. GE sells a "moisture kit" which I refuse to buy, since it's $340! Plus, I doubt it will fix anything. Good luck!
Apr 15, 2009 | Refrigerators
Both the Freezer and the Refridgerator quit working...
Do you have ice build up on the back wall in the freezer? If so you have whats called a defrost problem. (can be timmer, adc, heating element or thermostat)... All cold air in you fridge side come from the freezer, therefore if you have ice build up behind back wall in freezer it is blocking air flow....
Dec 21, 2007 | Maytag MTF2156GEQ Top Freezer Refrigerator
Frigidaire FRS6R5ESB Logo
934 people viewed this question
Top Frigidaire Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
