Question about Bosch Dishwashers
My bosch dishwasher does not drain the water away, left sitiing in bottom
  • mike ratken Jun 16, 2008
    seemed to do the trick,using a pipe cleaner cleaned out some small stones from outlets and she`s going again.
    Genius:
  • 1,665 Answers
    Brigadier General:
  • 6,966 Answers
It could either be the filter (most likely), the drain pump (likely) or the drain hose/tube (least likely).
Normally, there would a filter somewhere at the bottom of your washing machine with the primary function of keeping loose clothing, torn fabric, lint, fluff and foreign objects away from the impeller/pump. Most current washing machine have self-cleaning filters and therefore regular cleaning is no longer a concern. However, some other washing machine need to have the filter manually removed and cleaned regularly or as even in your case. If the filter or grate is clogged or blocked with debris, it may interfere with the normal functioning of your washing machine and may cause the problem as you have described; water doesn't leave the tub.
To check the filter and/or the drain pump, the bottom has to be exposed, the filter/pump located and cleaned. In some instances, the drain could be a valve operated by a solenoid.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
Posted on Jun 16, 2008
  • Louie  Role
    Louie Role Jun 16, 2008
    Ooops that should be dishwasher instead of washing machine. My apologies for the mixup.
  • 13,433 Answers
Is there something blocking the outpipe and is there anything inside the washer that is blocking the water from going out, this can be caused by food geting stuck in there.
My bosch SGS3062GB is not draining the water away - the water is stagnent in the bottom of the dishwasher. I ran the rinse cycle and it left about 2.5inches on water in the bottom of the...
Hi
Dishwasher not draining issue usually occurs due to kinked drain pipe, clogged drain filter or drain pump. Check the drain hose for any visible clogging, remove if present. If no visible lint is present then remove then turn off the dishwasher and remove the drain hose and check for any visible clogging. If still not visible then the drain filter or drain pump is clogged and you'll need to clean the drain filter and drain pump.
Please note that dishwashers don't drain out the complete water such that heating element doesn't overheat. Hope this helps... Please post back for any further assistance.
Daniel
Dec 13, 2010 | Dishwashers
Water does notdrain away
Here is a tip that I wrote that will help you with your dishwasher2_bing.gif not draining problem...
Dishwasher2_bing.gif Problems - Water will not drain out
http://www.fixya.com/support/r4078724-dishwasher_problems_water_will_not_drain
heatman101
Jul 21, 2010 | Bosch 24 in. SGS4072 Free-standing...
My bosch dishwasher won't drain
mine is doing this too. I am trying to figure out if its the pump.
Nov 12, 2009 | Bosch 24 in. SHU53 Built-in Dishwasher
Drain pump runs continuously. Nothing else happens!
Water had accumulated in the sump - a plastic tray at the bottom of the dishwasher which catches any leaked water. This operates a float switch which makes the drain pump run all the time. The fix was to tilt the dishwasher backwards to drain away the water. It isn't filling up again, so I'm not sure where the water came from, but I'll keep an eye on it!
May 17, 2009 | Bosch Dishwashers
Bosch dishwasher wont drain
You can check the drain or the filter. You will have to pull it out of the space it is now to access it. Items will get stuck in the drain clogging it.
Feb 22, 2009 | Bosch 24 in. SGI43E05GB Built-in...
I have a bosch dishwasher classixx its less than a year old, the 'check water' light comes on and it doesn't complete the cycle. Water is left in the bottom unable to drain away. I have checked pipes as...
if its less than a year old why dont you contact the manufacturers service team it will still be under guarantee as the bosch guarantee is 24 months
you can dowload a copy of the instruction maual free of charge from the bosch or bsh home appliances web site
Feb 21, 2009 | Bosch 24 in. SRS43C12 Classixx Slim-Line...
Bosch classixx check water light
ok sounds like a drain promblem love your do it your selfness but one thing you must keep in mind its under warrenty and if you mess with it you could void your warrenty if you have a cancel drain option try that if it still doesnt drain call for service
Mar 18, 2008 | Bosch 24 in. SGS43C12 Classixx...
Bosch dishwasher
1. Check for a clog in the air gap:
That's the silver dome on the back of the sink. Not all homes have an air gap for the dishwasher. (Though it is highly recommended!) Lift off the silver cover. Unscrew or unclip the plastic cap on the top. Look inside. Toothpicks are often found there.
2. Check for debris in the sump by:
Remove the lower rack, the lower spray arm, and screens. Use a #15 Torx bit to remove the cover over the drain pump suction. The hole leading to the drain pump is on the left at the bottom. Remove any debris you find.
3. If you find no debris, you almost certainly need a drain pump. After clearing any clogs, if you hear the drain pump humming, but it doesn't turn, replace the pump.
Comment back if you directions for this.
Mar 12, 2008 | Bosch 24 in. SGS43C12 Classixx...
Shu9915uc dishwasher wont drain
it should have water just below filter tray, if it does not actually empty then you have a blockage ,remove left side panel to gain access to drain pipe and side chamber. Regards Engineer
Aug 05, 2007 | Bosch SHU9915UC Dishwasher
Open Questions:
My Bosch 800 series won't start when I close the door, instead it flashes the InfoLight on for half a second and then powers off. The unit is a SHXN8U55UC/07. Everything seems normal, I open the door, press the power button and the display lights saying 2:09 and the light under Auto is on. The Auto light, InfoLight, and display are flashing once a second. The InfoLight is the red light that shines on the floor while it is running. I press the start button for a second until it beeps, then close the door. The InfoLight will light up for half a second and then it turns off. Normally it would turn on and stay on while the cycle runs. When I open the door, all lights and display are off. If I press the power button, it will come back on. I called Bosch technical support and they had me go through a reset cycle. This involved, IIRC, holding the power button for 3 seconds, then closing it and waiting a minute. When this didn't solve the problem, they said I needed a repair visit. Two points of interest: I did the troubleshooting with Bosch at 10pm, then gave up and went to bed. Around 6pm the following evening I opened the washer up and the display was on and showed clean. The dishwasher had obviously run, and was still a little warm like it had finished running in the last couple hours but not hot. I have been unable to replicate this, though I've only waited ~12 hours so far. This was working fine for 6-9 months, then we had a contractor in who pulled out the flooring and cabinets. They left the dishwasher powered on and connected to the power supply, but not water or drain. Since re-installing the dishwasher, it has not worked.
Feb 09, 2017 | Bosch Dishwashers
Dishwashers Logo
225 people viewed this question
Top Bosch Dishwashers Experts
Gerry Harvey
Gerry Harvey
prem mathew
Are you a Bosch Dishwasher Expert? Answer questions, earn points and help others
