Question about Canon PIXMA MP470 All-in-One Printer
How to scan a two sided document? - Canon PIXMA MP470 All-in-One Printer
  • 10,865 Answers
Hello. The only way to do this is to scan one side and then manually turn the document over and scan the other side. Joe
4 thumbs up please. ty.
Posted on Nov 08, 2010
Scan both sides of document?
Scan one side of document, print that side. Flip document and scan, then follow printer directions for printing other side of document on first printed document.
Nov 11, 2015 | HP OfficeJet Office Equipment & Supplies
Tip
ERROR codes Canon 3525
Canon 3525 E000 Fuser problem E000 Heat E010 Main motor, motor board, clock pulse E010 Drive E030 Counter E030 Counter E050 Duplex side to side problem E050 Duplex problem with cross alignment E051 Duplex side to side problem E051 Crossway registration E200 Scan problem E200 Scan reverse sensor or scan E202 Scan return problem E202 Scan home sensor or home scan E204 Scan E204 Document sensor, scan reverse sensor or scale E210 Lens problem E210 Lens E220 Lens E220 Blank lamp open or lens home problem E240 DC controller E240 Bad DC controller E400 Document feeder board problem or document feeder interface problem E400 Document feed problem E500 Sorter E620 Editor E620 Editing problem
on Jan 18, 2010 | Office Equipment & Supplies
Tip
ERROR codes Canon 3025
Canon 3025
E000 Fuser problem
E000 Heat
E000 Fuser problem
E010 Drive
E030 Counter
E030 Counter
E200 Scan problem
E204 Scan
E210 Lens problem
E210 Lens
E220 Lens
E240 DC controller
E500 Sorter
E620 Editor
How to scan documents
  1. Position the document on your scanner.
  2. On the File menu, click Scan New Document.
  3. In the Scan New Document dialog box, select the options you want.
    • To select additional scanning options, click Preset options, and then click either Create new preset or Edit selected preset.
    • If you want to scan a double-sided page, select the Original is double sided check box.
  4. Click Scan.
If you selected the Original is double sided check box, the Scan New Document dialog box reappears as necessary.
  1. If you selected the Original is double sided check box or the Prompt for additional pages check box, click Done to save the file after the last page is scanned.
Feb 17, 2011 | Cycling
I cant scan to computer
  4. Click Scan.If you selected the Original is double sided check box, the Scan New Documentdialog box reappears as necessary.
  5. If you selected the Original is double sided check box or the Prompt for additional pagescheck box, click Done to save the file after the last page is scanned.
Note By default, OCR is performed automatically when you scan documents. To turn off this feature, click Scan New Document on the File menu, and then click eitherCreate new preset or Edit selected preset. On the Processing tab of the Preset Options dialog box, clear the Use OCR to recognize the text of the scanned imagecheck box.
Hope this helps!!!
Please rate my response!!
Jan 29, 2010 | HP Photosmart C4580 All-in-One InkJet...
HOW DO YOU SCAN DOCUMENTS
  4. Click Scan.If you selected the Original is double sided check box, the Scan New Document dialog box reappears as necessary.
  5. If you selected the Original is double sided check box or the Prompt for additional pages check box, click Done to save the file after the last page is scanned.
Hope this helps!!!
Jan 29, 2010 | Microsoft Word for PC
How to scan picture to upload on computer
First, ensure you are connecting the scanner to your computer. I'm assuming USB connection, and that you're using an operating system supported by this device.
Next, install the drivers and software for this device. Those should have come with an installation disc, but if you don't have that disc, you can get them from the PIXMA MP830 support site, here:
http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&fcategoryid=123&modelid=12804
To scan a single document, place the document:
1. Place the document face down on the platen glass.
2. Open the MP Navigator 2.2 software.
3. Click Scan Photo/Document.
4. Click Document Type drop-down arrow and select the type of document to be scanned. Chose from the following types.
  • Color Document(Simplex): Select this to scan one side of color documents.
  • Color Document(Duplex): Select this to scan both sides of color documents.
  • B/W Document(Simplex): Select this to scan one side of monochrome documents.
  • B/W Document(Duplex): Select this to scan both sides of monochrome documents.
  • Text(Simplex): Select this to scan one side of text documents.
  • Text(Duplex): Select this to scan both sides of text documents.
5. Click 'Specify' and set the preferences as required. Click here for detailed information
6. After making the setting changes, click 'Scan'
7. Click 'Save to PC' or 'Save as PDF file'. Save to PC is displayed when an image is captured with Scan Photo/Document or Batch Scanning
The directions for Batch Scanning, or using the ADF to scan, are shown below.
  1. Place the document(s) in the Automatic Document Feeder (ADF).
    1. To scan using the ADF, remove any documents from the platen glass.
    2. Open the document tray.
    3. Insert the documents face-up in the ADF and then adjust the document guides.
      Note:
      When scanning using the ADF, the documents will automatically feed.
  2. On the Windows desktop, double-click 'MP Navigator 2.2'.
    1. Alternatively, on the Windows taskbar, click 'Start', point to '(All) Programs', 'Canon', then 'MP Navigator 2.2'.
    2. Then click 'MP Navigator 2.2'. MP Navigator opens.
  3. Click 'Batch Scanning'.
    * Color Document(Simplex): Select this to scan one side of color documents.
    * Color Document(Duplex): Select this to scan both sides of color documents.
    * B/W Document(Simplex): Select this to scan one side of monochrome documents.
    * B/W Document(Duplex): Select this to scan both sides of monochrome documents.
    * Text(Simplex): Select this to scan one side of text documents.
    * Text(Duplex): Select this to scan both sides of text documents.
  5. Click 'Specify' and set the preferences as required. Click here for detailed information.
  6. After making the setting changes, click 'Scan'.
    1. After the documents are scanned, a dialog box will appear indicating to load the next document.
    2. After the next document is loaded, click 'Scan'.
    3. Repeat steps 6a and 6b until all documents have been scanned and then click 'Exit' to end the scanning process.
  7. After all documents have been scanned, ensure the documents, in the preview area, are selected (have a check mark).
  8. Click 'Save to PC' or 'Save as PDF file'. Save to PC is displayed when an image is captured with Scan Photo/Document or Batch Scanning.
    Save to PC dialog box
    Save as PDF file dialog box
  9. Make settings to save a file. (Click File save settings for details.)
  10. Click 'Save' after all settings have been selected.
Aug 27, 2009 | Canon PIXMA MP830 All-In-One InkJet...
Problem with c6180 when used with mac/leopard
Follow below instructions to scan more than one pages to a single document :
1. Open HP solution center.
Click Start - All programs - HP - HP Solution center.
2. Click Scan document - Click Accept.
Computer will ask "Would you like to scan another page?" Say Yes and scan the other side of the document by following onscreen steps.
Thanks
Dec 22, 2007 | HP Photosmart C6180 All-In-One InkJet...
Scanning a combination of one-sided and two-sided documents
Use the "Separate Scan" button on the panel. By pushing this you are telling the scanner that you have separate scans to scan as one document. Once all files are scanned, push the separate scan button again to indicate you are finished scanning.
Oct 17, 2007 | Konica Minolta bizhub 250 All-In-One Laser...
Canon PIXMA MP470 All-in-One Printer Logo
71 people viewed this question
old marine
old marine
