Can you control heat with thermostat by turning it all the way down. I assume from your description that burner is running. If it is and turning t-stat all the way down made no difference I would remove t-stat from wall and remove red or white wires from it.This should cut power to gas valve turning burner off. If this works replace t-stat. Hope this helps. Thanks.
