Question about Bladez Ion 9.9 Fold-up Treadmill
Hi.i own a 7.9t ion treadmill and have an intermittent problem. when i turn on the power it shows L B and none of the touch keys are working.if i tap on the top sometimes it comes on line for a while but it goes up to ramp level 6 and there is no more control of any keys.Have to shut it down and restart it but stillin dead mode until i tap on board or keep touching lots of keys at same time. Can not use it this way.It is only about 18 months old.t.you
Check to see if the console has air blisters... if you try and iron them out with your fingers it will work again.. on these it seems as if the buttons for the elevation and speed colapse and thus acts as if the button is pushed and in your case level 6. look for the blister around the buttons for level 2 ,4 ,6. It may be hard to see but in the right light you will..
Posted on Jan 27, 2011
  • 66_mustang_6 Oct 29, 2013
    Still seems everyone has the issue still... peel the console sticker back an lay back down... try again and see if works.. if not peel back up and peel apart lower sticker-plastic. ( says leoway on it). this should now work... my previous reply explains bit more on issue.(66_mustang_6)
Hi jplejeune197
Did anyone get back to you with a fix? I have exactly the same problem with my ION 73T.
Posted on Dec 12, 2010
  • 2 more comments
  • eightgage Dec 19, 2010
    I have the same thing going on with mine too
  • winslowclark Jan 15, 2011
    i have the exact same problem. the company was no help at all. have you found a solution?
  • Natureboy132 Jan 28, 2011
    I have the same exact problem!
  • 66_mustang_6 May 07, 2014
    i found too if you peel up the coverlay then use masking tape to build up the layer between this will give an air gap so the button is not on by itself. Use double sided tape to stick the coverlay back down.
I TURN KEY POWER CUTS OUT CLOSE HOOD HARD POWER RESTORES TURN KEY POWER CUTS OFF . TAP FUSE BOX POWER RESTORES TURN KEY POWER CUTS OUT. WHATS GOING ON I CHECKED WIRES AND CONNECTIONS IM LOST
Apart from the obvious electrical connections, you could try checking each fuse. Sometimes they appear to be ok but 1 end of the fuse may be broken and touches intermittently. Try lightly tapping each fuse 1 at a time with the handle of a screwdriver and see if anything goes on and off.
Mar 21, 2017 | Cars & Trucks
I charge my battery of my Samsung Galaxy TAB Lite 7 SM- T116NDWAXFA White CT. I cannot use the phone for anything. If the charger is in it only shows a green 100% battery and nothing else.
Samsung Galaxy Tab 7 Troubleshooting
Tablet Doesn't Turn On No matter what you do, you can't get your tablet to turn on.
Press and Hold the Wake/Sleep Button
If this does not resolve your problem, read on!
Check If Battery Will Charge
First, connect your tablet to the power adapter. Hopefully the tablet will recognize the charger and begin to recharge the battery. If it does not, the battery may be defective and need to be replaced.
Faulty Display
If you determined that the battery was working, it is possible that the display is broken. If no light or images are visible, but the tablet has power, then the display may need to be replaced.
Bad Logic Board
If none of the previous solutions solved your problem, check all of the connections from the display to the logic board. If the device still does not turn on, the logic board in your device most likely needs to be replaced.
Screen Doesn't Respond to Touch Nothing happens when I touch my screen.
Screen protector/tablet case interferes with the touchscreen
Try removing your screen protector or case from the device, and test the touchscreen again.
Caution: Some screen protectors may not reapply properly.
Perform a Soft Reset
A soft reset restarts your device and does not erase any of your content or data. Begin by pressing and holding the Power key until your device turns off. Wait a moment, then press and hold the Power key to turn your device back on.
Bad Touch Screen
The touch screen may be bad and need replacement. The front panel (which includes the touchscreen and digitizer) should be replaced.
Bad Logic Board
If the problem persists, the logic board may need to be replaced.
Tablet Overheats Tablet is too hot to touch!
Reset the Device
Hold down the power button until the device shuts off. Let it cool down for a few minutes, then hold the power button until the device powers on.
Bad Battery
If the device continues to heat up, the battery is most likely defective and needs replacement. Purchase a replacement battery, and replace the old with the new.
Tablet Performs Slowly
Safely Remove Your SD Card
From the home screen, tap the Menu key, then tap Settings. Once in Settings, scroll to and tap Storage. In Storage, scroll to and tap Unmount SD card, then tap OK. You can now safely remove the SD card.
Close or Uninstall Applications
In the Power Usage dashboard, tap Battery Usage. Next, tap the application you want to close or uninstall.
  • To close (turn off) an application, tap Force stop.
  • To uninstall (remove from device) an application, tap App info, Uninstall, and then OK.
Verify That Your Tablet is Running the Most Recent Software
Begin by tapping the System Updates dashboard. Next, tap Device Software, then tap Check now. If an update is available, follow the prompts to install.
Tablet Doesn't Produce Sound No audio from headphones, speakers, or tablet itself.
Bad Headphones/Speakers
Check to make sure your playback method isn't the problem. Check all speaker connections and test headphones on another functioning device. If the problem is not resolved, your tablet may be the issue.
Software
First try a full restore on the tablet to make sure it is not an issue with the software.
Bad Audio Jack
If the problem is still not resolved, try replacing the audio jack. If that doesn't solve the problem, your logic board most likely needs replacement.
Aug 02, 2016 | Samsung Galaxy Cell Phones
Hi my power first t960 treadmill stops working. it turn's on. startup beeps are ok. display turn's on and showing regular digits. but non of keys working and consul dos not response to any key. thanks
Check the cable from console to motor control board. It would be a detachable connector on both ends. Try removing and reconnecting it. Sometime such problems can occur because of the bad contacts of connectors.Please remember to remove the power before attempting any service inside treadmill.
If you wish to get some details; check the site linked here. Pull up older posts.
http://electro-medical.blogspot.com/
Jun 10, 2016 | Exercise & Fitness
Proform V650 Treadmill - Main motor does not turn
The board will most probably need replacing. Almost certain.
I repair this brand for the manufacturer.
Nov 06, 2013 | Proform Exercise & Fitness
F 5 shows in display no controls will work
follow this steps. God bless you
The power up test sequence has detected a key in the operated condition. The power up test
sequence is performed every time the unit is turned on (powered up). This test is performed
because a permanently stuck key will inhibit the correct operation of the unit.
Possible Causes
1. A key on the display housing is permanently stuck in the operated condition.
2. One of the upper PCA's keypad interface chips has failed.
3. Liquid (perhaps perspiration) is present on the surface of a touch sensitive display.
Possible Remedies
1. Remove the keypad connector cable from the upper PCA. Restart the power up sequence, if
the ERROR 5 is no longer present, the keypad is the cause. The keypad is typically part of
the display housing. Replace the display housing to correct the problem.
2. Remove the keypad connector cable from the upper PCA. Restart the power up sequence, if
the ERROR 5 is still present, the upper PCA is the cause. Replace the upper PCA to correct
this problem. Most upper PCA's are provided without software. Therefore, the software (chip)
must be removed from the upper PCA being replaced and re-installed on the replacement
upper PCA.
3. Wipe the surface of the touch sensitive display clean of all liquid. Restart the power up
sequence, if the ERROR 5 is no longer present, the liquid was the cause.
Nov 15, 2012 | Star Trac 3900 Treadmill
Console
Dear Sir:
See the diagram attached for Reed switch, clean, tight the connector very well.
2) Change batteries by new ones, and clean the contact very well!
sincerely. God bless you
Apr 25, 2012 | Proform ZT5 Treadmill
None of the touch buttons work. Fans, volume, speed, incline etc etc. The only two buttons that work are incline buttons 6 & 7. Power comes on and key turns on and off though. Can anyone advise??
sorry but i dont have a solution for you!! i bought the t9ci back in nov of 2008, like you none of the buttons worked had to wait till march of 09 for nordictrack to send me a reprogram card, which did not fix the problem. i then recieved a new console, in april 09, which stopped working in feb 10. a service tech came out and had no clue, so the sent another new console which did not work. in march 10 they sent a whole brand new treadmill, and when i got on it last week the console was not working once again!!!!!!!!!!!!! i hope you dont have as many problems as i did
Nov 05, 2011 | Nordic Track NordicTrack T9 ci Treadmill
It does not turn on says safe
This message appears when you remove the Safety key.
Kindly provide me with the make and model of the machine?
Are you sure that the key is intact? Is it properly placed?
Thanks!!
Aug 21, 2010 | Exercise & Fitness
Buttons Froze during workout, now none of them work
It sounds like you just need some calibration. To calibrate incline, turn power on press press any incline buttons, as the incline try to change unplug the key. Now re-nsert key and incline will self calibrate,
Aug 23, 2009 | Nordic Track NordicTrack Treadmill, A2550
Bladez Ion 9.9 Fold-up Treadmill Logo
757 people viewed this question
Top Bladez Exercise & Fitness Experts
gbob59
ray gallant
Tom Chichester
Are you a Bladez Exercise and Fitnes Expert? Answer questions, earn points and help others
