Have a grand aire, the blower will not work, bought a new running capacitor..still nothing. What could be the problem
    Problem Solver:
  • 12 Answers
Blower moter winding week,replace the moter or give that moter to winder
Posted on Nov 09, 2010
I have poor air circulation for my 2001 Mercury grand marquis. I only get air from one dash vent. the blower goes up and down but even on high it seems like it is medium
well, if nothing was disconnected on the ducts and the selector works fine , my guess will be that you have a nest in the fan it self, take it out and clean the nest so the fan can blow full amount of air. good luck.
Nov 28, 2014 | 2001 Mercury Grand Marquis
I have a '03 Dodge Grand Caravan Sport AWD that the heater only blow hot air when going down the road. Van has a new radiator and new thermostat. Sometimes the blower will not kick on for a few
If the problem is a lack of air flow from the vents, and you suspect the blower motor is not running at times, you would need to test the blower relay and blower motor for power and ground when it is not working.
Apr 08, 2013 | 2001 Dodge Grand Caravan
Electrically it is fine. The main blower is running, but the fan outside is not. I hear a humming, however. Obviously, the house is hot and nothing is frozen up.
You either need a new capacitor and or a fan. If you
cannot hear the compressor run and it is not tripping
any breakers you may need to install a hard start
capacitor kit
Jul 03, 2010 | Heating & Cooling
I have a Dometic 579 Series Brisk Air AC. The model Number is 57915.531. When I turn the fan on, nothing happens. If I reach up and turn the wheel blower the fan will start up and everything works. I...
My sheet shows part # 3100248.420 as fan run capacitor.You may have an updated number. Check voltage outputs labeled on it are same as on old one, and double check wiring is correct, to and from capacitor. Be careful not to mistake compressor start capacitor as well. By sounds of number, it's probably the right one.
May 27, 2010 | Dometic Rooftop RV Air Conditioner
Wiring Question York Diamond 90 Condensor Unit - New Capacitor
the wire diagram should tell you how. it all depends where wires lead to. be very carefull, capacitors can be dangerous. brown usaully go to fan black usaully goes to common red usaully goes to herm or compressor. it all depends where wires come from
Aug 27, 2009 | Heating & Cooling
I just bought a 99 jeep grand cherokee. The air
see if the air duct piping is still connected to the blower housing or the fan blade might have come loose from the motor and the shaft is just spinning inside the fan blade
Aug 11, 2009 | 1999 Jeep Grand Cherokee
Capacitor is out? Compressor won't kick on.
yellow line from capacitor to compressor has nothing to do with coil freezing up. sounds like your low on charge again, dirty filter causing coil to freeze, no blower operation, dirty coil.if system low again you might want to start looking for a leak.
Apr 26, 2009 | Intertherm P3RA-036K Air Conditioner
Run capacitor
yes....they use seperate capacitors.
Aug 18, 2008 | Heating & Cooling
Fan not running
the motor could be worn out and just working when it can.is it the main blower motor or the one for the ac?
Jul 16, 2008 | 2004 Pontiac Grand Prix
Heating & Cooling Logo
130 people viewed this question
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
