Question about Lavazza Espresso Point Capsule Machine
Is there a company in Chicago that repairs Lavazza Expresso Point Machines?
SOURCE: heating element on an lavazza expresso machine
you can call this number they will help you with your problem
1-866-526-6204
Posted on Apr 29, 2009
  • 19 Answers
SOURCE: buttons don't work
contact me @ www.lavazzarepair.com
Posted on Nov 11, 2009
  • 19 Answers
SOURCE: Lavazza Expresso Point Machine - not able to steam
The wand is clogged try reaming out with a small thin paper clip straighten out and insert thru the hole in the tip of the wand contact me www.lavazzarepair.com
Posted on Nov 12, 2009
RescueTechLA
  • 2653 Answers
SOURCE: my lavazza expresso point machine
You need to email their customer service department.
LUIGI LAVAZZA S.p.A. (Lavazza Customer Service)
VAT number IT00470550013
C.so Novara, 59 - 10154 Turin Italy
Tel. +39 011 2408400
Fax + 39 011 2398333
e-mail: info@lavazza.it
From experience it takes a few days for them to respond. Just be persistent with them ;)
Posted on Oct 16, 2010
  • 92 Answers
SOURCE: My expresso point machine will make one cup of
It can be a defective thermostat (left upper light flashing).
Posted on Jan 18, 2011
I have lavazza expresso pointe machine. I put in cartridge and select cup size and water keeps going. It doesn't stop so cup overflows and ends up just water flowing thru
need to remove the back cover, which has a few screws in the bottom left corner is a round and white plastic device that is said meter. Disconnect hoses from it and open it. Clean it well and then close it and put in place. Should be fine!
Jan 06, 2014 | Lavazza Espresso Point Capsule Machine
Lavazza Espresso point not heating up
The electronic control board is defective, it must be repaired or replaced.
To get a dealer address send an email to: f.vitare@lavazza.it. I could help you, but, I live in Canada. Guru
Nov 15, 2011 | Lavazza Espresso Point Capsule Machine
LAVAZZA EXPRESSO POINT THE RED LIGHT BUTTON KEEPS FLASHING CONSTANLTY, WHEN I MAKE THE COFFEE IT SQUIRTS OUT ALL OVER THE PLACE, IT DOENT HAVE A NICE FLOW LIKE IT USE TO
Causes:1- the 130 deg thermostat is open. 2- working thermostat, 104 deg, defective, allowing temp to rise.3- the machine becomes hot because the water valve is stock open. machine needs to be sealed so not to allow water to boil.Water boils at 100 deg Celsius. 4- valvolino or o-rings are worn out and leaking. You need a repair shop.
Guru
Sep 21, 2011 | Lavazza Espresso Point Capsule Machine
I have a Lavazza Point Expresso Machine and it started leaking water out of the front. I believe it needs a gasket, but can't seem to get the parts to come off to get to it. I have used an Alen Wrench,...
When replacing the o-rings inside the boiler the operation should be carried out by a certified technician for these machines. When the boiler is dismantled it is recommended that all o-rings and springs in the boiler be replaced as these are ware parts. When the boiler is apart this is also an opportune time to do some manual cleaning to the internal parts. This is an easy task but as I said before must be carried out by a certified technician. Special tools not readily available to homeowners are required to rebuild the boiler once dismantled. I am sure there are many repair facilities around but location wise I am not sure. I have heard that espressozone.com are nice and will do repairs. Perhaps try them. You may also try contacting a lavazza rep and they may be able to point you in the right direction.
Apr 09, 2011 | Lavazza Espresso Point Capsule Machine
Buttons don't work
Oct 25, 2009 | Lavazza Espresso Point Capsule Machine
Lavazza Expresso Point Machine - not able to steam the milk - that part of the machine has no steam capabilities
Oct 24, 2009 | Lavazza Espresso Point Capsule Machine
Lavazza expresso machine
Is the machine blowing fuses? Your electronic keypad, or circuit card may be damaged.
If you need service you can call 781-393-2929
we are an authorized lavazza distributor and repair center.
Jun 02, 2009 | Lavazza Espresso Point Capsule Machine
Lavazza espresso point machine will not turn on.
you will need ten amp, small bus fuses, they are hard to find, I could not find them at radio shack and autopart stores, your machine could have also blown the thermal fuses. if you need service you can call 781-393-2929. we are an authorized lavazza distributor and repair center.
May 14, 2009 | Lavazza Espresso Point Capsule Machine
Heating element on an lavazza expresso machine
1-866-526-6204
Apr 15, 2009 | Lavazza Espresso Point Capsule Machine
Lavazza Espresso Point Capsule Machine Logo
Top Lavazza Coffee Makers & Espresso Machines Experts
ray gallant
nikolay nikolov
Tom Chichester
Are you a Lavazza Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
