Question about NEC MultiSync LCD4010 40 in. Television
Picture no sound
Sound ok no picture backlight~ok?
  • alanvee Mar 04, 2009
    Powers up, no image, no input ID comes up, backlight is on.
We have the same problem here too. Please email me if anyone has a fix action to this.
Posted on Sep 16, 2008
TCL LED LCD 55" - Backlight issues
Repair or replace the backlight.
Nov 24, 2013 | Televison & Video
When the tv set is put on, no picture shows but the sound is ok
Check If there is a backlight?
With Backlight, With sound....Main Board
No Backlight, With Sound.....Power supply (24V) or Inverter Board (Capacitor)....
Oct 27, 2013 | Toshiba Televison & Video
No picture
Sounds like you have a backlight problem. To verify this, turn on the set, dim the lights in the room, and shine a bright flashlight on the screen. If you see a faint picture you have a backlight fault. It could be as simple as a bad capacitor in the power supply, or a faulty inverter board, or in rare cases a bad backlamp.
May 04, 2013 | LG 32LD350 32 in. LCD TV
I HAVE LCD/TV LG M227WA the picture and sounds are there but no backlight.what's the solution?
A backlight will either not light because of no voltage or no control (not being switched on by the set).
Apr 03, 2012 | Televison & Video
Black screen with sound no picture
Hello
You haven't either given its Brand name or its Model number. Anyway, as it is an LCD TV, this is common fault to all brands. Check its backlight CCFL tubes, and the backlight inverter board.
Actually there is picture, but you cant see it as there is no backlight. OK.
Feb 07, 2012 | Televison & Video
What does it mean when the picture goes out?
Hello
There are so many reasons for picture to gets out. The first amoung them, is of its backlight itself. If the backlight CCFL tubes wont light up, there will be no backlight to illuminate the picture. If baclkight inverter board has damaged, backlight CCFL lamps won't light up. The most common fault with LCD TVs are backlight failure itself. The second one is of with its main video processor board. In short, main board itself. You have to check and make sure which one is faulty. You must ahve sound knoledge in electronics to proceed. OK.
Dec 18, 2011 | Hisense LHDN32V66AUS 32 in. LCD TV
Picture went out on p50hdm Vizio Plazma tv after loud POP
It's either the backlight lamp or backlight inverter is busted due to a power failure or fluctuation. Here's how to determine which is which:
  1. Grab a flashlight.
  2. Turn on the TV.
  3. Shine the flashlight onto the screen.
  4. If you cannot see any display even a faint one, the backlight inverter is dead, else the backlight lamps are busted.
  5. Replace which ever is the culprit.
Sep 26, 2009 | Vizio P50HDTV10A 50 in. Plasma HDTV
No picture on the screen it is totally black and i do get sound.
There will be a problem with the backlights not being switched on, you would need to check if you are getting the supply voltage to the Inverter board (24V). If not check the power supply, if it is present then check if the backlights are functioning with a backlight tester, if these are ok check the capacitors on the inverter board. If the backlights are faulty then a replacement screen would be required.
Aug 27, 2009 | LG 50PG30 Plasma HDTV
Toshiba 32HLC56 sound is ok but there is not picture.
backlight may be the problem 99% sure... call manufacture to either get it fixed or replaced
Sep 11, 2008 | Toshiba 32HLC56 32 in. HD-Ready LCD...
NEC MultiSync LCD4010 40 in. Television Logo
214 people viewed this question
Top NEC Televison & Video Experts
Computer Repairing
Computer Repairing
Are you a NEC Televison and Video Expert? Answer questions, earn points and help others
