Question about Fisher and Paykel Active Smart E522B Bottom Freezer Refrigerator
REFRIG E402BRE Hi, My refrigerator is warm. I think the refrigerator fan is broken. No cool air is being sucked up from the freezer to the refrigeration compartment. The freezer part is working well. How to I get at the fan to replace it? John
  • 2 more comments
  • Anonymous Nov 13, 2008
    The frezer is working but the fridge part is warm.
  • chris93 Dec 30, 2008
    I have the same problem, checked both fans are wokring (top & Bottom) but still the fridge comprtment is warm. Its really annoying as the unit was expensive. I have herad if you let it defrost for 2 days it sometime rectifies itself due to too much icing up?
  • nigel_braund Jan 05, 2009
    Tony I had exactly the same problem and came up with exactly the same solution, except that I used insulating tape after soldering the wires back together. this must be a common problem (it's the second broken wire for me - the (different) fan in the fridge also did this) makes you wonder if f&p deliberately designed it this way.
    to help with fridge - it's the same process take out all shelves then pull the centre section from the top down and you will find the fan at the bottom.
  • chris93 May 11, 2010
    Tony
    thx for the excellent document it really helped. unfortunatly checked both fans are wokring (top & Bottom) but still the fridge comprtment is warm. any other tips would be greatly apprecaited?
  • 4 Answers
My fridge (E440T but I believe the E522 is similar) has EXACTLY the same symptoms and the reason was a broken fan wire in the freezer compartment (behind the rear panel). The fridge compartment works by drawing air from the freezer and blowing it into the fridge compartment. If the fan in the freezer doesn't work, then your fridge won't get cold (there is another fan in the fridge compartment so it will stay a little cold but not enough).
If you're game, I created a document for others to follow if interested at http://mail.accentis.com.au/downloads/misc/How%20I%20fixed%20my%20Fisher%20and%20Paykel%20Fridge%20Active%20Smart%20Fridge.pdf
Thanks to all postings on this site - it really helped a lot, had me some fun and saved money!
Posted on Nov 17, 2008
  • 1 more comment
  • shaziz Oct 27, 2010
    I've had the same problem, didn't realise beeping was coming from fridge. I have now had a fridge repair guy in twice in 3 years at almost $300 a time to fix it and tonight it is beeping again, even though the doors are shut. Biggest Waste of money I've had in the last 10 years. Not sure I trust F
  • Peter Resch Nov 03, 2010
    My E406BRT had a similar problem, fridge and freezer not cold and not defrosting. The problem was an open circuit defrost heater. Not willing to pay $150 for a heater and who knows how much labour to replace it I got into it and found one of the thermal fuses in series with the heater was open circuit.
    The fuse was sealed in a silicone tube so a delicate operation was needed to replace it. A $3 thermal fuse from **** Smith, a lot of heat shrink tubing and silastic to seal it up got it all going again.
    Note: the heater is powered with 240V so unless you know what you are doing I don't recommend that you try this repaired yourself. The fuse *has* completely sealed to prevent the ingress of moisture.
  • jaydon111 May 01, 2011
    I think I have the same problem i.e. defrost heater not working. Could you tell me its location and how you get at it?
    John
Here is a pic showing the location of the fusible resistors and the visible part of the heater:
http://www.peterresch.com/images/freezer_element.jpg
Note, there are two fusible resistors in series with the heater, one on each side. In the pic they are connected with yellow wires.
The heater (a metal tube) wraps around the bottom of the heat exchanger and is partially hidden in the pic.
Again a warning, if you're not sure what you are doing don't attempt to do this. 240 volts in a difficult environment like this is *dangerous*. Everything must be secure and properly waterproofed.
Posted on May 01, 2011
Just pull the middle piece plastic out. It is not fixed with any screws or something, then it will reveal a cover at the bottom. Pull the cover out and the fan is under. Basically between the fridge and freezer. I have the same problem and will try replacing it myself.
Posted on Aug 02, 2008
    Make sure the freezer has completely defrosted before removing the plastic panel. If it's iced up you may break the securing lugs that hold the panel and heat exchanger in place and have trouble getting it to fit properly when the panel is replaced.
Vegetables in crisper are frozen, as well as liquids in bottom 1/2 of fridge door. The fridge & freezer temp controls won't adjust to our settings. Also, we're getting ice, but no water will dispense.
The freezer cools the refrigerator, so you actually get very cold air passing from the freezer to the refrig. The air from the freezer enters the refrig on the top and falls to the bottom where it is drawn back into the freezer. The temperature of the refrig is regulated by a thermostat and a fan that runs when the thermostat calls for cooling. If the refrig thermostat is faulty and causes the fan to run more than it should, there will be a freezing problem in the refrig at the bottom because cold air falls and warm air rises. If the refrig is thermostat is calling for cooling constantly, this will take more cold air from the freezer than is normal. Your freezer temp might be higher than normal and the refrig will be colder then desired. If the fan from the freezer is running constantly I would suspect a bad refrig thermostat.
May 06, 2015 | Refrigerators
My refrigerator upper is cool but lower is not cool, how fix it?
Check to make sure the the fan that either sucks the cold air from the freezer is working and not blocked. In some refrigerators the fan is in the freezer and some is in the refrigerator compartment.
Make sure it is operating AND that it isn't blocked.
Jun 07, 2011 | Refrigerators
Freezer is blowing and staying around 20 degrees and refrig is warm?
If you mean the rest of the refrigerator is warm, that means the fan that circulates the cool air from the cooling coils around the freezer compartment is broken, you'll need to send it in for repair.
Mar 06, 2011 | Refrigerators
Refrigerator compartment too warm
Check out these tips...they can help you figure out what is going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Nov 23, 2010 | Jenn-Air JCD2295HES Side by Side...
Fan in freezer runs and is cold. No air is coming
heatman101
Sep 17, 2010 | Amana ABB1927DE Bottom Freezer...
I have cleaned the coils this morning, but the refrigerator section does not appear to cool. The freezer seems fine. This is model eti18PKXGWI ser no. 042 9086 eemingly c. 10 years old.
Your freezer fan has probably quit. On most refrigerators the freezer is the only compartment actually cooled by the compressor and coils. The refrigerator compartment is feed cold air from the freezer compartment by way of a small fan. If you have you refrigerator turned all the way up and the door open you should here the fan running and be able to feel air moving somewere in the refrigerator compartment.
Sep 05, 2010 | Whirlpool Refrigerators
Fisher and Paykel Active Smart E522B Bottom Freezer Refrigerator Logo
3,619 people viewed this question
Top Fisher and Paykel Refrigerators Experts
Brian Coughlan
John Tripp
John Tripp
Colin Stickland
Colin Stickland
Are you a Fisher and Paykel Refrigerator Expert? Answer questions, earn points and help others
