Question about HP LaserJet 2420 Printer
Hp laserjet printer problem
When power on of printer it display on printer screen"10.10.00 supply memory error"
  • sobah Jul 23, 2008
    when power on of printer it display on printer screen"10.10.00 supply memory error"
  • 96 Answers
Try to reinstall your software, if it is show the error again replaced the memory and then try to power on the printer.
Posted on Jun 16, 2008
Supply memory error
There is a protective plastic clip over the cartridge chip. Remove the orange plastic and it will quit giving you the supply memory error. Refer to figure 6
Supply Memory Error' Message Displays on the Control Panel
Or Still having Problem Then follow Us For
HP Support
Apr 21, 2014 | HP Laserjet M1522nf All-in-one Laser...
Supply error
Just bought laserjet M1213nf MFP and installation done by the HP reseller engineer. From first use after power on every time this error is flashing
10.1000 Supply memory error
To accept press OK
After pressing OK this error keeps flashing at regular interval. The printing etc functions are OK, what can be the problem?
Apr 01, 2014 | HP LaserJet Pro 400 color M451dn - Printer...
Hp laserjet P3005n gives memory test error when powereds
I am assuming that the printer is giving a supplies memory test error in which case it is a faulty micro chip on the toner cartridge. If this is the case then you need to replace the toner cartridge.
If the printer is not displaying supplies memory error, but actual memory test error then the problem is in the memory on the Formatter Board. The formatter board in these printers are prone to faults.
If your board has an added memory stick, I suggest that you remove it after turning off the printer and then power on again and see if the error is still displayed.
Jun 10, 2011 | Office Equipment & Supplies
HP Colour Laserjet 5550dn. Once switched on it goes through memory check; display lights and hp logo on display screen. Then displays on screen "Initializing . . ." Doesn't go any farther - just...
i hope that the problem is not in some of your printer boards, but i have to tell you that you have to expect problems with POWER SUPPLY BOARD or FORMATER BOARD. Please call service for help
pifonski
Apr 19, 2011 | HP LaserJet 5550 Printer
MY PRINTER (HP LASERJET M1005 MFP) SCANNER ERROR 12 DISPLAY IN A SCREEN I CAN NOT SOLVE THIS PROBLEM NO SCANNING , NO PHOTO COPY IN MY PRINTER PLEASE HELP ME HOW TO SOLVE THIS PROBLEM
If you get ERROR 12 DISPLAY, check top cover and toner cartridge is seated correctly, dc power supply . If these are proper your printer will be fine.
Thank you
Jan 04, 2011 | HP LaserJet M1005 All-In-One Printer
Printer model HP Laserjet CP2025, at display panel appear 'supply memory error'. How to solve it. Thank you
This is a problem with the toner cartridge, check the code at the end of the error message and that will tell you which toner is defective.
Al
Aug 10, 2010 | HP Laserjet Cp2025n Printer
Hp laserjet m1522nf 10.0000 supply memory error
Are you using HP toner? Try reseating the cartridge. If it's still getting the error, replace the cartridge.
May 20, 2010 | HP Hewlett Packard LaserJet 3000dn Printer
SCANNER ERROR 20 of HP LASERJET M1120 MFP
PRINTER: HP DESKJET M1120 MFP DISPLAY SCREEN SAYS; "SCANNER ERROR 20"...
ANY IDEAS HOW TO FIX?
MANY THX!
Mar 10, 2010 | HP LaserJet M1120 MFP All-In-One Printer
10.10.00 supply memory error coming on HP Laserjet 5200 Printer.
Dear Sir,
I has change the printer cartridge. After changing the printer cartridge above mentation comming. When I am making printer power on the (10.10.00 supply memory error) display. Please tell me how to solve this problem. Best regards,
Thanking
Ajom Khan Hero
Mobil No.092 5192797.
Al Nahr Co.Ltd
Tripoli - Libya
Jun 17, 2009 | HP Hewlett Packard LaserJet 5200 Printer
HP Color LaserJet 4500 Printer
Here is your problem. Hope that this helps you.
54.1 PRINTER ERROR
Description:
Indicates that an internal power failure has
occurred.
Action:
1. Turn the printer off, and then turn the printer
back on.
2. Replace the high-voltage power supply.
3. Check the fuser to ensure jams have not
occurred.
Caution When clearing jams, the
thermistor can be damaged
causing this error.
4. Make sure there is not a fluctuation in the
power supply to the printer. Check that the
electrical specifications (see Chapter 1) are
met.
5. Replace the low-voltage power supply.
Apr 02, 2009 | HP Color LaserJet 4500 Printer
HP LaserJet 2420 Printer Logo
492 people viewed this question
Ben Johnson
