Showing F1 on display boiler makes a thudding noise then goes to F1 mode. Smell of gas.
    Genius:
  • 1,400 Answers
Hello
Sounds like a low water cutoff switch is stoping burner from lighting.
Check that you have at least 15psi of water pressure on the boiler guage.
Try to reset the cutoff switches.
Posted on Nov 08, 2010
My new viessman boiler is showing F1 after it made a humming that went on for half an hour
F1 means burner is at fault ,lack of pressure, best to call viessman or the installer back as if its a new boiler it has a five year warranty
Jun 07, 2015 | Water Water Heaters
I have a Protherm 80e boiler which keeps going to the F1 mode
google your boiler it comes up with a manual go to page 26 it gives you 5 reasons why it goes to f1
Aug 16, 2017 | Water Heaters
Hetline sargon boiler manuals
my heatline sargon 35kw boiler is showing f1 fault i have drained boiler and cleaned out relivant peaces but still no change any advice in sorting this out
Dec 20, 2010 | Heating & Cooling
My gloworm 30cx boiler keeps showing fault f1, what does it mean ?
Low gas pressure or flow: make sure you have gas to the unit.
Dec 19, 2010 | General Heating & Cooling
Hi my vaillant eco tec pro shut down last night showing fault f.28 and will not ignite today 08/01/2010 looked out side to see the condenser pipe was frozen i defrosted the pipe but boiler still wont...
Got exactly the same problem with mine. Manual says f28 = fault in gas supply, gas pressure too low. Boiler will ignite but goes out within minutes? HELP!
Jan 08, 2010 | KDS Valiant 6380iPTD-01 Notebook
Makes a clicking noise and humming when starts up
If your unit is fixed with a high speed compressor and in case you are not using a votage stablizer when ever there is a fluctuation in voltage there could be a click noise from the compressor. Do not frequently open your fridge and slowly the noise will vanish. It tells you that the unit is functioning just like our heart making thud thum thud noise when it functions and nothing to be worried about. It is normal.
Jul 06, 2009 | Refrigerators
Boiler wont work
you have a gas supply issue the baning is water hammer from the water heating
Jun 10, 2009 | Air Tools & Compressors
F1 display and alarm will not shut off
hi there,
can you tell me the model # on your stove please?
Sep 13, 2008 | Maytag CWG3100A Gas Single Oven
I have a Certikin Genie swimming pool boiler that is showing the word GAS and i can smell it. What should i do?
You could try resetting this as it could be caused by several factors (blown heat exchanger being one as Karl mentioned).
Hve you tried resetting from in Service Mode ?
To get to Servce mode you need to go ino User Setup Mode first (turn off the boiler via the panel switch - then hold the Lock/Reset button whilst turning back on). Once in User Setup Mode if you rotate the thermostats all the way clockwise (it should display the software version) Then press and hold the Lock/Reset button for 3 seconds.
This should put you into service mode and it is now possible to change/reset some of the control parameters.
If you try resetting the error.
This issue may be caused if the Flue or water stat is tripped (in which case reset the stat). If th Fan resistor remains open in the circuit then you will need tsomeone out to investigate as that may cause the GAS error too.
COuldalso be the Valve coils are faulty in wich case they need replacing (agians I would get an engineer outto confirm and do that).
I'm suyou probably tried all this but just in case...
If the roblem is solved can you advise what fixed it ?
Thanks
Jul 13, 2008 | Heating & Cooling
Heating & Cooling Logo
182 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
