Question about Acer Aspire 5050-3242 Notebook
Turning off Hibernation
On my Aspire 5051AWXMi laptop when I try to open Power Options in the Control Panel I get the following message.
Microsoft.NET Framework.
An unhandled exception occurred in your application. If you click Continue, the application will ignore this error and attempt to continue.
If you click Quit the application will shut down immediately.
Specified argument was out of the range of valid values.
Details Continue Quit
Then when I click on DETAILS I get a long list starting with the following
See the end of this message for details on invoking
just-in-time (JIT) debugging instead of this dialog box.
************** Exception Text **************
System.ArgumentOutOfRangeException: Specified argument was out of the range of valid values.
at Acer.Empowering.Windows.Forms.ComboBox.set_SelectedIndex(Int32 value)
at ePower_UI.ePowerMain_UserControl.SetProfileComboBoxActiveProfile()
But this system will not allow me to post the full list here.
But what do I do to fix the problem?
  • ceryac Jun 19, 2008
    Hell MerlinTech,
    I did a syou suggested and the problem was solved. Thank you for your help and expert advice.
    Regards,
    Ceryac
  • 197 Answers
You'll need to reinstall your operating system.that's an almost FATAL flaw you're dealing with.
Posted on Jun 16, 2008
Acer hibernation
Go to control panel and find power options and you make adjustments there.
Oct 29, 2012 | Acer Aspire One A150-1006 Notebook
Hi, i'm using windows xp on my latop, i used to have a hibernate option when i click the 'turn off computer', after reinstalling my windows, i can now only see shut down and restart. how do...
Hello and Welcome to FixYa!
Click Start >> Control Panel >> Power Options >> A dialog box will open, there will be a Hibernate Tab at the top of it >> Check the option there "Enable Hibernation".
When Done, click Start and Turn off computer, The three buttons you see one will be Stand By. Press and hold the Shift key. Stand By will become hibernate. Click it. You are done.
If you have any issues following it, do tell me.
Concerned, Nooh: Team FixYa!
Jul 11, 2011 | Computers & Internet
How do I get my computer out of hibernation
To disable hibernation in vista proceed as follows: 1. Click Start followed by All Programs and then Accessories
2. On the Accessories menu Right Click on the command prompt.
3. From the drop down menu, Click on the Run Administrator option
4. The Command Prompt window will now open
5. At the command prompt type: powercfg -H off
Disabling Hibernation In XP
The Hibernation feature can be somewhat of a resource hog in XP. If you don't plan to use it, you may as well disable it.
Here's how:
1. Go to Start> Settings> Control Panel.
2. Select the Power Options Icon
3. Click on the Hibernation icon
4. Uncheck Enable Hibernation
Sep 02, 2010 | Dell Inspiron 1525 Laptop
I accidently uninstalled acer screensaver on my acer aspire laptop and it removed my hibernation mode also i want it back, please
You can right click on any open area of the desktop to get display options. Find the screen saver tab and preview the screen savers until you find the one you lost. Once found apply it and click ok. Then go to start or windows icon in bottom left. Then select control panel wint he windows utility menu. Once there go to performance and maintenance. select power options and adjust acordingly. Good Luck
Nov 22, 2009 | Acer Aspire 5315 Notebook
Question
Hibernation is a power management feature. When you hibernate a laptop, you're essentially turning it off. So, unlike Stand By (Sleep) mode, a hibernated laptop isn't using any battery power at all - that laptop is off!
The secret behind hibernation is that before you turn off the laptop, everything you're doing with the computer is saved. (The contents of memory are saved to the hard disk.) When the computer is turned on again, it recovers from hibernating by reloading all the saved information and restoring your laptop to exactly the same condition it was in before it was hibernated.
Briefly, hibernation works like this:
1. You activate the hibernation feature.
Hibernation is activated differently depending on how it's set up.
2. The laptop hums as everything in memory is saved to disk.
3. The laptop turns itself off.
It's really and truly off: The battery isn't being used, and it's safe to store the laptop or put it away until you need to use it again.
To recover from Hibernation mode, just turn the laptop on. In some cases, the laptop may recover from hibernation when you press a key or touch the mouse pad. hibernated state for as long as you want.
Hibernation mode requires hard drive space. So you should be aware that when hard drive space runs low, it's possible that Hibernation mode won't work.
In Windows XP, you have to activate Hibernation mode before you can use it. Follow these steps to activate Hibernation:
1. Click the Start button.
2. From the Start menu, choose Control Panel.
3. Open the Power Options icon in the Control Panel.
4. In the Power Options Properties dialog box, look for and click on the Hibernation tab.
If you don't see a Hibernation tab, there's your answer: The laptop isn't capable of hibernating. Oh, well.
You might want to check the laptop's Setup program to see whether you can activate Hibernation there.
5. Select the Enable Hibernation option by clicking the check box to place a check mark in the box.
6. Review other options, if they're available.
7. Click OK to confirm the changes and close the Power Options Properties dialog box.
Optionally, close the Control Panel window, as well.
Some laptops may require you to restart Windows for this change to take effect.
Sep 09, 2009 | Computers & Internet
ToshibaHotkey
go to control panel,power options,
change your power settings
stop Hibernation,
" choose what to do when I hit the power button" etc....
Hibernation causes problems with startups
Don't use hibernation, use standby,sleep
or turn it off completly
should cure the problem
Regards
Richard.
Apr 19, 2009 | Toshiba Satellite 1415-S173 Notebook
I have IBM R40 Laptop
Try pressing the power button next time. That will help you to turn on from an Hibernation.
Alternative you can disable this feature (not recommended for laptops)
  1. Open Control Panel.
    • On the Windows XP default Start menu, click Control Panel.
    • On the Windows XP classic Start menu, point to Settings, and then click Control Panel.
  2. In Control Panel, open Power Options.
    • If the computer is in Category View, click Performance and Maintenance, and then click Power Options.
    • If the computer is in Classic View, double-click the Power Options icon.
  3. In the Power Options Properties dialog box, click the Hibernate tab.
  4. On the Hibernate tab, clear the Enable hibernatation check box, click Apply, and then click OK.
Jan 10, 2009 | IBM ThinkPad R40 2897 Notebook
Acer Aspire 3610 plugged in closes down
I would suggest you just plug it in and do not power on the laptop for a few hours. Then try. If it persists reboot into safe mode and disable hibernation then reboot
Dec 06, 2008 | Acer Aspire 3610 Notebook
Acer is in hibernation
navigate to control Panel>>power options>>Hibernate tab and uncheck the Enable Hibernate mode and restart the system and if it still does the same then please contact your system admin
Aug 04, 2008 | Acer Aspire 3680 Laptop
Inactive standby option
>I saved myself from a lot of these problems. I set the power button on the front
>of my computer to put my PC into hibernation.
>This is how you do it:
>1. Go to the Control Panel
>2. Open the Power Options window
>3. If Hibernation isn't on, go to the "Hibernate" tab and turn it on.
>4. Once you have hibernation on, go to the "Advanced" tab.
>5. If your computer supports it, there should be a dropdown menu in the "Power buttons"
>area. From there you can make your computer perform a lot of power management functions
>including Standby and Hibernate.
[Reply or follow-up to this message]
Jul 10, 2008 | Microsoft Windows XP Professional
Acer Aspire 5050-3242 Notebook Logo
110 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
