Question about Stainless Garden Sun Steel Propane Patio Heater
The gas won't flow to enable the space heater to light. I've taken most of the heater apart but can't readily access the most top valve which "may" be plugged. Where do I go from here?
  • dconkright Nov 16, 2010
    Sorry I didn't get back sooner--I couldn't find your response until just now. The propane space heater is a "SA" model # RSS-A-SS. It looks just like the picture above. This heater is made in China. I found their web site which provided a link that permitted asking for technical help. The question could be provided in English and their response would be in English. I asked them a question a week ago, but have never heard from them. I have 5 of these heaters and four of them all exhibit the same problem. I would appreciate any suggestions.
    President:
  • 2,777 Answers
What is the brand / model of space heater you are referring to here? Is it the one like the picture shows, an outdoor style one with the big "lamp cover" style top?
Let me know and we can figure this out, just reply to my answer here and I can help...
Thanks
Tim
Posted on Nov 08, 2010
Pilot won't stay lit on mr heater vent-free propane heater
if it is direct vent chances are it has electronic pilot.. it does not have a standing pilo and match size upt. if in fact it did have a buning pilot there is a part called thermocoupling. it will look like a 1/8 in. copper wire coming out of the bottom of the gas valve and goes right to the pilot. anywhere from 10 in. to 20in.. unscreew nut at gas valve pull out from pilot area [ it just clips in at pilot] take it to any home center
Nov 25, 2012 | Kitchen Ranges
Why won't my Laars Lite 400000 heater light?
should be 24 volts ac tyo the brown and yellow wires to the gas valve at start up or when you hear click
Jun 20, 2012 | Teledyne Laars Laars Lite2 Heater 400000...
I am a new homeowner. I have an H400IDLunit that is a pool/spa combo. The code reads "00" in the heater window and does not change when the unit controlls are pressed. I have an aqualink...
I don't know if there is a pilot light, spark ignitor or thermal ignitor. I would determine by inspection what kind it has. If you open the front cover you will find a gas valve. It can be identified by following the gas pipe that enters the side of the heater and attaches to the gas valve. If the valve has a control knob on it that has an off, on and pilot position then it is a pilot type. If this control is not on the valve then the unit includes an automatic ignitor.
To light a pilot equipped system place the knob in the pilot position, push it down, and use a flame to light the pilot. If you hear gas flowing from the pilot but it won't light then there is air in the line and it needs to be purged. Holding the pilot lighting valve down long enough will purge it but may take a long time. Periodically you can check it by trying to light it. If it lights watch it for a while before trying to turn the heater on to make sure it is fully purged. Once the pilot is stable and the thermocouple is heated the pilot valve can be released and it should stay lit. If not, try again.
Don't get down and look into the burners while you are trying to start the system because it could flame out and burn your face. If you turn on the heater again then the gas valve should come on and the burner should light. You can usually hear a loud snap when the gas valve come on. You should then hear the gas flow to the burner. If the burner doesn't light you should be able to smell the gas. If it lights exhaust will be coming out of the vents in the top of the heater.
I am sure you will have more questions so please respond with them. I hope this helps.
Sep 04, 2011 | Hayward H-series Electronic Gas Pool...
I have a giordano heater that won't light. There is a narrow pipe that diverts gas to the igniter spark. The pipe is capped by a small metal regulator with what looks like a very small hole in it to...
Never drill or try to make the pilot hole larger, this will cause a large flame that cannot be controlled. Check the main parts, first see if you have a spark, next check for leaks, to see how to do a leakage test see patio heater problem solving page. If no leak try changing the thermocouple, these will wear out and can last up to 6 years. Also check the electromagnetic valve that sits inside the gas control valve and if fitted check the tilt switch works. The tilt switch can be shorted out to see if it works.
Aug 03, 2011 | Stainless Garden Sun Steel Propane Patio...
I have a Comfortglow ventless gas fireplace. Started out the pilot would not light, replaced the ODS, still would not light, replaced the gas control valve, still no light. Got gas to the unit. tried...
Take the pilot tube off at the gas valve and see if gas comes out there...my bet is that it will... if not then your problem is gas valve or before which it seems as thoguh you checked out fairly well...
I'm thinking that you have dirt in the pilot orifice...when the tubing going to the pilot is off then pull air back through the pilot with your mouth... or better yet take the pilot assembly apart and blow it all out and make sure that the pilot hole is open... it is VERY small and you may need to hold it up to the light to see through it...that is why a very small spec of dust can plug them up...
heatman101
Dec 10, 2010 | Desa International Unvented Gas Space...
Hi. I have an old LPG space heater, unknown make. (30-40 years old?) Has been working well up to last week. The problem is that while the fan comes on there is no gas flow or ignition. There is gas in the...
Check your regulator, this is an often overlooked culprit.
NO that Gap you have is meant to be that so that the spark will "Jump" that distance and draw enough current to make the spark hot enough and big enough to ignite the gas. You must check, if there is gas to the pilot light, and if so, why isn't the igniter igniting it, can it be ignited with an external source? if so, does it continue to run, if so, then it is most likely the igniter, if NOT then it is the gas delivery, or a safety feature activated, or a faulty controller.,
If you don't see a good blue spark, then either your igniter is broken, or the ignition circuit is, or perhaps a safety sensor, is inhibiting disabling it, or perhaps it could be the thermostat too. I have included a website below, that will step by step you through troubleshooting your system.
http://homerepair.about.com/od/heatingcoolingrepair/ss/gas_furn_trblsh.htm
Due to the possible safety ramifications however really one should get a professional in to attend to matters such as this, as any mistakes can be dire. Be safe.
I
Jun 23, 2010 | Heating & Cooling
We have an ALL PRO SPC-85 that worked fine but now the blower and spark plug work but it doesn't fire up when pushing the LPG button. One time I thought I could detect a faint LPG odor but still did not...
i have the same heater that had the same problem - today i found out you can't just pull the plug and stick a new one in, the gap has tp be 1/8" - I did just that and it worked and then shut itself down - finally found the book and saw the correct gap = it fired right up
Jan 22, 2010 | All-Pro Propane Garage Shop Heaters - All...
Fails to ignite,sparks but pilot will not ignite. have had problems with pilot going our for about three months. Thought attic air flow was the problem. closed off air vents in area of heater. problem...
Sometimes the pilot orrifice get plugged up and need to be taken apart and cleanned,,,,,, adjust the pilot flame on the gas valve, or check gas going to the unit to see if the in-line gas valve is opening and closing.
Dec 09, 2009 | Ruud Heating & Cooling
Pilot is lit for 30 secs but when I turn the knob for the big fla
You have a white scale buildup in the gas valve outlet blocking the main gas flow. Take the valve apart and clean it.
Jun 14, 2009 | Uniflame 200209 Open Flame Patio Heater
Wather heater will not ignite
You'll probably need to ignite the pilot light before it will allow gas to flow for the heater to ignite and warm the water.. Most controls have a Pilot position that you switch it to , than using a long match .. locate the pilot light in the access opening at the bottom and get the pilot light to stay lit.. Hope that helps...
Aug 16, 2008 | Heating & Cooling
Stainless Garden Sun  Steel Propane Patio Heater Logo
102 people viewed this question
Top Stainless Pool & Spa Experts
Merv Vickery
Merv Vickery
Gene Haynes
Will Townsen
Level 1 Expert
Are you a Stainless Pool and Spa Expert? Answer questions, earn points and help others
