Question about AEG Washing Machines
Today I did a load of washing and it worked fine. I then started a second one and when I looked at the machine, the timer showed the number 1 and the light was on prewash. the washing had not been done as the detergent gel was still there on the machine's drum. there was water in the bottom of the drum. I put the switch on reset, opened the door and removed the clothes. Then we tried the 'pump out' and the machine kept going to 1 and prewash and not functioning. after hitting reset for a while, we managed to do a pump out. thinking the machine was working we put the clothes back in and again it looked like it was going to work for 2 minutes and then went back to 1 and prewash light and not working. It seems to regularly do this now, we managed to do a short spin to remove the clothes from the machine. but it's not working fine. I have now turned it off at the mains, and will leave it to rest until tomorrow. Does anyone have any clues on what the problem is or what could be done before we have to call a plumber in? thanks
    An expert whose answer gotĀ voted for 100 times.
    Sniper:
  • 174 Answers
Hi I think the door lock is faulty it always shows 1 min until the door lock is unlocked. also will not start until it is locked. e40 is the error for starting the machine with door open but if if faulty will revert to the last minute. include product no and model if further info needed you can find this on a label in the door area.
Posted on Nov 09, 2010
I have a kenmore front load washing machine that water shuts off after 5 seconds. Timer continues to count down but nothing happens in the machine. Timer also takes about 3x longer to get to zero.
Troubleshooting Appliances: Washing Machine and Dryer ...
www.realestate.com > Realestate.com Blog > Articles
Sep 16, 2012 - If your washing machine or dryer seems ready to give up the ghost, follow ... When you start your washer, a solenoid-operated water inlet mixing valve ... Afront-loading washer lacks the agitator, instead using the tumbling ... Clothes Remain Wet After the Spin Cycle. 1. .... Bought washer/dryer second hand.
Oct 19, 2015 | Kenmore Washing Machines
Kenmore 417.43142200 final spin is slow
obviously the timers contacts are bad so replace the timer.
May 16, 2017 | Kenmore 43142 Front Load Washer
My Miele W1119 washer won't run. It was fine earlier today and I just completed a load of wash. When I started the next load on the Normal cycle, the timer lights to 58 minutes as always and the...
sounds like bushes mine done the same changed them now all good check it is not leaking water on to the bottom of machine this will activate the sensor to stop washing and drain water
Jun 04, 2017 | Miele Touchtronic W1119 Large Capacity...
My hoover washing machine top load won't start. I have checked the power from the wire going to the timer.The door latch switch is working and still it won't start.
my hoover washing machine do not stop they show 1 min left . i was try serval time the happend is same and inside few water as well
May 26, 2011 | Hoover HTC243 Top Load Washer
My washer gets stuck on wash cycle...
I would replace the timer . Pt # 3954071 . If the model number above your thread is correct .
Sep 06, 2009 | Whirlpool Ultimate Care II LSQ9564J Top...
Maytag MAV6000AWW washer will not run thru cycles consistently
yes it would be the timer but they also stop if it gets off balance if its just off balance u should be able to lift the lid rearrange then start it again if that doesnt work it is the timer
May 21, 2009 | Maytag Atlantis MAV6000 Top Load Washer
Timer programme
Drain pump may be obstructed or defective. You may have to call your engineer back. Maybe he disrupted something.
Nov 13, 2017 | AEG Lavamat 72640 Front Load Washer
Washer won't start cycle after door is closed
Try taking the top of the machine off and checking all of the electrical connections, including the one to the door lock. I have to do this about once a month with my machine and it seems to work.
Jan 20, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Just had an Affinity front loading washer delivered today. Did four loads without any issues, clothes are clean and smell great. After the washer was idle for about an hour, it started beeping, and the...
try disconnecting the power for at least 30 seconds which might reset control if this fails call service the control is faulty you have a 1 year full warrenty
Dec 21, 2008 | Frigidaire ATF6000ES Front Load Washer
Maytag Washer Getting stuckon wash cycle
the possibility of it being the timer is most likely..as the rest of the cycles remain ok.. if you require a timer,you can get one here at this link..(click the link here) http://www.easyapplianceparts.com/AdvancedModelSearch.aspx?ModelNum=HAV4657EWW&mfgModelNum=&fkMfgID=1
please be aware that you will need the machine serial number in order for them to issue you with the correct part/s you will require.. parts are cross referenced with the serial number.
these diagrams will also enlarge in order for you to maintain your machine by yourself at little but the cost of the parts required... but please DO NOT ATTEMPT ANY REPAIR YOURSELF if you think you may not have the technical know how to follow these technical drawings..hope this helps
Nov 06, 2007 | Maytag MAT13MN Top Load Washer
Washing Machines Logo
179 people viewed this question
Top AEG Washing Machines Experts
Gerry Harvey
Gerry Harvey
Einar Axel...
Einar Axel...
Level 1 Expert
Are you an AEG Washing Machine Expert? Answer questions, earn points and help others
