Question about Vacuums
Belts I have a Hoover self-propelled windtunnel, purchased 6-04. It gets light use. I have replaced the v belt 3 times, once under warranty, and it must be replaced again. It appears to be in very good condition, but is stretched too big. When I purchased 2 v belts a year ago, one was already too stretched,but when my Dad took it back, the salesman put it on another model and said it was fine (Dad never mentioned this to me). Is there a way to adjust the vacuum to hold the belt tighter? Do they really just stretch out like that normally? The flat belt has never been replaced and is in great condition.
    President:
  • 1,673 Answers
It is the flat belt that gets stretched and should be replaced at least every 6 months. The V belt wears down so it won't it right in the brush roll V. Maybe the belt tensioner wheel has a problem, sometimes they get hook up and won't engage the V belt. Check the brush roll also, if where the V belt rides in is covered up with belt, replace it. There is no adjustment, doesn't need it if everything is working the way it should.
Posted on Jun 16, 2008
Why won't hoover wind tunnel self-propel?
Hi there! The self-propelled feature is controlled by a belt. Check the belts on your Hoover Windtunnel by following these quick steps.
1. Recline the handle. Lay the cleaner fat and flip it over to expose nozzle base.
2. Remove the screws attaching the nozzle.
3. Check that the belts are not broken, stretched or damaged.
Replace the belts if they are damaged. Hope this helps!
Jul 04, 2014 | Hoover Vacuums
How to stop the main belt from comming off the motor shaft on a hoover modle u6634-900/windtunnel
Hello there! If you have replaced the belt and it is still slipping off, you may be not have the right belt for your vacuum. This unit takes a flat belt and a v-belt. Make sure you are replacing the belts with Genuine Hoover Parts. I have included the links below where you may go to order the belts specific to your cleaner.
WindTunnel PowerDrive Belt 2 Pack
WindTunnel Self Propelled Belt
Hope this helps!
Jun 21, 2014 | Hoover Self-Propelled WindTunnel Bagless...
Hoover self-propelled windtunnel U6430-900 flat belt gets hot & becomes hard to push. It has a filter bag. Purchased 8/2/01. Took one plate off bottom. Used a compressor to blow out dirt & dust. ...
Belts get hot when fibers from carpet get wound arounf the belts mounting shaft. Best to take a razor and cut off any fibers so the belt doesn't get hot again
Aug 10, 2010 | Hoover Self-Propelled WindTunnel Bagless...
Self propulsion doesn't work on my upright. Vacuum works fine otherwise
You will need to look @ your owners manual to see where the self propell belt is located i am sure yours is broke and need to replace,- it will not be hard to replace-Lance
Oct 21, 2009 | Hoover Vacuums
Self Propel doesn't work on Hoover Wind Tunnel
Your self propel wire could be broken. Lean the vacuum back like you were using it. If you stand in front of the vacuum look down and to your left. When you move the selp propel button you should see a wire move. If not then it's broken.
Oct 06, 2009 | Hoover Self-Propelled WindTunnel Bagless...
Belt will not stay on hoover windtunnel s3765
The Hoover Windtunnel™ Self-Propelled models have two belts, a flat belt and the V-Belt. This V-Belt is the one that drives the Brush Roller. After about three months, most belts stretch out causing them to slip. This means the brushroll turns slower or not at all and the self-propelled becomes increasingly harder to push. It is recommended that both belts should be changed at the same time.
May 23, 2009 | Hoover S3765-040 WindTunnel Bagless...
Replace the belt
Once the bottom plate has been removed, the motor shaft is silver, but hard to see. hook the new belt on it first. then start rolling on the top of the large black pulley to install.
Jan 26, 2009 | Hoover Ultra U6430-900 WindTunnel Bagged...
No suction on Windtunnel 6630-900. All belts work, brush turns, it just won't pick up anything.
Sep 07, 2008 | Hoover Self-Propelled WindTunnel Bagless...
I have a Hoover self-propelled windtunnel, purchased 6-04. It gets light use. I have replaced the v belt 3 times, once under warranty, and it must be replaced again. It appears to be in very good...
http://geeksquad.fixya.com/ThreadView.aspx?prdid=0&thid=675093
Generic problem for all Vacuums
Posted by klsh on Jun 16, 2008
I have a Hoover self-propelled Windtunnel, purchased 6-04. It gets light use. I have replaced the v belt 3 times, once under warranty, and it must be replaced again. It appears to be in very good condition, but is stretched too big. When I purchased 2 v belts a year ago, one was already too stretched, but when my Dad took it back, the salesman put it on another model and said it was fine (Dad never mentioned this to me). Is there a way to adjust the vacuum to hold the belt tighter? Do they really just stretch out like that normally? The flat belt has never been replaced and is in great condition.
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure. It is a good idea to change your flat belt every 4 to 6 months as a rule and the V belts @ least once a year and always use the genuine Hoover belts, there are generic or replacement belts out there but they have a tendency to stretch faster then the genuine belts. What you mentioned is not unheard of and another tip is to store any extra belts in a Ziploc bags in the refrigerator. Feel free to contact your local vac dealer if you have questions or call Hoover factory and ask for tech support. So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
http://www.hoover.com Telephone
Contact our Customer Service Department at 1.330.499.9499
Monday through Friday
8 a.m. - 7 p.m. EST
Thanks, Don the Vac Man
Go Ahead. Use Us.
Jun 16, 2008 | Vacuums
I have 2 Hoover Wind Tunnel-self propelled bagged vacuums-U6433-900 model.The roller bar does not agitate, the self propelled feature does not work and, in general, the vacuum is not performing well. I...
The Hoover WindTunnel self propelled is a machine that we see in our retail stores (Vacuums Unlimited) constantly. The benefit of having a supposed "self-propelled" machine wears of quickly after the numerous time you will need to take this machine in for repair.
It's unfortunate you've had to spend so much money already on repairing this machine. I know you've said you've already replace the belts and filters, but if you want you can check out a video we made on repairing the Hoover Windtunnel.
http://www.youtube.com/watch?v=meX8lgZo7DY
If you are looking for a reliable upright, at GoVacuum we'd recommend the Sebo X4 upright (http://www.govacuum.com/seauxseupvac.html). The machine is incredibly reliable and easy to maintain. Thus far, we haven't had one warranty repairs come through our doors. The machine itself has a lifelong warranty on the belt because the machine automatically shuts off the motor if an obstruction is detected, preventing any undue stress on the motor or belt.
Jun 06, 2008 | Hoover Vacuums
Vacuums Logo
94 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
