Question about Kenmore Elite HE5t Washer
I keep getting the code F35 on my washing machine the troubleshooting phamplet does not mention this code at all, what is it?
  • Kenmore Master
  • 1,902 Answers
Hello
F35 error means that there is some sort of issue with the steamer electronic board and analog pressure sensor has gone bad. Check that the hose is firmly attached with the washer and is not blocked. You can also check the water level pressure switch operation. Please get back to me if you have any other questions.
Kevin
Posted on Nov 08, 2010
Keeps Stopping and saying UE
uE error code 79631512210 Kenmore Elite Washer - Sears ...
www.searspartsdirect.com > Ask an Expert
Jan 10, 2014 - uE error code 79631512210 Kenmore Elite Washer ' SearsPartsDirect. ... After unloading the washer completely, the machine attempts to rebalance the .... to ensure proper fit and to keep appliances running for years to come.
UE Error code on my front loading Kenmore washing machine
www.shopyourway.com > Manage My Life > Questions
Jun 13, 2011 - I have a Kenmore 3.5 cu. ft. front loading washing machine (model #4027) and it is 1 year old. ... what does the F35 error code on my kenmore elite front loading washing machine mean? F13 code on Kenmore Elite HE3 front loadingwashing machine.
Jan 21, 2016 | Kenmore Washing Machines
Washer keeps giving an error code F35
Look up you tube f35 code some info there on it
Dec 07, 2015 | Washing Machines
He5tsteam kenmore elite smartwash quietpak9 keeps flashing F35
Analog sensor failure. Replace that puppy using this VIDEO GUIDE
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Jun 18, 2012 | Kenmore HE5t Steam 4.0 cu. ft. Front-Load...
I have an "F35" message
The only Whirlpool washer with an F35 code that I know of is the Duet. For that washer, the code indicates a failure of the analog pressure sensor. Check if the pressure hose is connected properly. Check that the hose is not blocked. Finally check for a blockage in the airtrap. If the hose and airtrap are fine, then the sensor or the related circuitry is bad.
I hope this helps.
Jul 24, 2011 | Whirlpool Washing Machines
My washer keeps getting and F35 error code and stopping
Hope this helps.. The "F35" error code is indicating a problem with the analog pressure sensorswitch operation (key#20). There could be a blockage in the air dome or pressure switch hose. The pressure switch is located underneath the main top on the right hand side. The air dome is located on the back of the tub on theleft hand side. If the pressure switch hose and the air dome is clear of any blockages the likely failure is the water level pressure switch (key#20) part# W10156252. Replacing the pressure switch will likely resolve the "F35" issue.
Jun 20, 2011 | Maytag Washing Machines
I keep getting the error message F35. Can you tell me what that means?
The Central Control Unit detected a fault in the analog pressure switch but it could also indicate a draining problem. Check the link below to see what you can try to address the problem.
Troubleshooting Error Code F35 on Kenmore Elite and Whirlpool Duet Washers
Nov 03, 2010 | Washing Machines
My Kenmore HE5T washer - Why do I keep getting code F35 and the machine won't completely wash the clothes.
F35 is a water level error.
The water level switch (pressure switch) has malfunctioned.
If you remove the top panel, three screws in the back, you will have access to the pressure switch.
With the tub empty, remove the vinyl hose from the switch and blow backwards through the hose to clear any restrictions.
If the fault codes return after doing this, you will likely need to replace the pressure switch.
Also - please be sure to use He soap.
Thanks for using FixYa - a 4 THUMBS rating and POSITIVE TESTIMONIAL is appreciated for answering your FREE question.
Oct 07, 2010 | Kenmore Elite 45986 Front Load Washer
Keep getting f35 code on quiet pak 9 washer
F35,= SUDS
set a few washes without using any soap to flush the pump out.
Use less detergent and use a liquid rather than powder.
Aug 25, 2009 | Kenmore Washing Machines
Kenmore Elite Washing machine error codes
I am getting F35 error code. What is the problem?
Nov 23, 2008 | Kenmore Elite 45986 Front Load Washer
Whirlpool Duet Steam washer
HELLO.F35 IS A ERROR CODE WHICH NEEDS THE ASSISTANCE OF A WHILPOOL SERVICE AGENT.THE CONTROL BOARD MIGHT NEED TO BE REPROGRAMED BEFOR YOU CONSIDER REPLACING IT.GOODLUCK.MOHAMED
Sep 15, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Kenmore Elite HE5t Washer Logo
131 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
