Question about Black & Decker Kitchen Appliances - Others
When i added the raisin on the top of the machine which is called fruit compartment (stainless steel version) i noticed that it did not mixed with the rest of the bread. it only appeared on the outer crust of the bread. make note that i choose the fruit bakign option which is # 4, quick rapid, light crust, 2 lbs, extra and then start. did i missed a step? please help.
    Genius:
  • Black & Decker Master
  • 1,280 Answers
I'm not familiar with your particular model but some machines instruct folks to just put raisins in at the beginning....If you do that I would try it first with about 1/2 the raisins it calls for and see what happens.... they will probably disperse better by puting them in at the beginning....if this works please let me know....
Posted on Nov 08, 2010
Raisin & nut Dispenser is not retracting after dispensing fruit etc
The trapdoor feature on bread machines often malfunction. Once it starts happening the best thing to do is just add your raisins, nuts, etc. yourself about halfway through the 2nd knead. If you have one of the machines that just has one long first knead then add them at 7 minutes before the end of the knead. daryl441@msn.com
May 11, 2014 | Panasonic SD-2501WXC Automatic Breadmaker...
When you are adding fruit in the bread machine after it beeps 3 time in 32 mins does it restart after you have put in fruit.
The fruit is mixed in about 5-10 minutes before the end of the 2nd knead on most machines. Then your dough will sit quietly for a while. Most machines do a short punch down knead after that. It lasts only a few seconds. Then the final rise begins. Then lastly the bake process begins.
Aug 03, 2013 | Kitchen Appliances - Others
Breadman ultra tr700 did not bake the bread
The whole process takes 3-4 hours to complete. Did you give it that much time? Next time note how many hours are on the readout just before you push "START" and let the machine countdown to 0:00 on the clock before you assume something is wrong. If you did that last time and the bread wasn't baked then your machine is broken.
Feb 10, 2013 | Breadman Kitchen Appliances - Others
Rust spots appearing on the front doors of my Bosch refrigerator
Stainless steel does rust - or at least that is the theory.
There is in fact two types of stainless steel; the original categorised austenitic which is instantly recognised due to it being unable to attract a magnet due to the absence of iron. Austenitic is relatively expensive and difficult to work but adding iron in various quantities to the alloy produces a cheaper, lighter metal that looks good and is easier to work while still providing some resistance to corrosion. The more iron that is added to the ferritic type of stainless, the lighter, cheaper and easier it is to work but the corrosion resistance is substantially reduced.
Cars have been fitted with stainless steel exhaust systems of the ferritic type for many years and although they last a long time they soon show surface rust and sometimes will rust through.
I expect your fridge wipes are either acid or alkaline that are suitable only for austenitic and good grades of ferritic and Bosch have used a particularly poor grade of stainless. I expect fridge magnets stick very well...
Mild discolouration could be removed with a mild abrasive cleaner though that would tend to ruin the brushed finish. Clearly future cleaning should be carried out with a neutral ph cleaner and the surface protected with a hard wax polish.
I suggest you check the cleaning instructions in the Bosch instruction book. If you feel you have done nothing wrong you might be able to claim from your household insurer as accidental damage. It would be a good idea to inform the manufacturer of the cleaning wipes...
May 27, 2017 | Bosch B26FT70SNS
I use my dough cycle to knead my bread....when should i add the raisins, nuts etc since i do not get a beep on this cycle....also what is the length of each process when making the dough.. i have...
Use the fruit bread cycle and remove your bread after it is done mixing it in since there is a beep on that cycle. You can let it rise on the counter then.
Mar 11, 2011 | Breadman TR555LC Bread Maker
I have a Regal Kitchen Pro breadmaker. Following the raisin bread recipe in their breadmaker guide and cookbook, the raisins do not become incorporated into the dough. They stay at the bottom of the...
You could experiment by adding them in the beginning during the very first mixing phase. Raisins are pretty tough so I hope they won't get pureed by putting them in so early but at least they won't fail to get mixed in. If they do get pureed try putting them in just before the first knead or just after it starts. It may take some experimenting to get it right.
Jan 09, 2011 | Regal Ware K6725 Kitchen Pro Bread Maker
How long do I cook the bread
Place the ingredients into the bread machine, liquid first, then flour and dry ingredients, make a little pit in the top of the flour and put the yeast in there. Then start the machine. You add fruit and nuts later, usually there is a beep for adding things.
Apr 10, 2009 | Regal Ware K6725 Kitchen Pro Bread Maker
Math
To remove msg from my que.
Mar 24, 2008 | GE Adora DSS25KSTSS Stainless Steel Side...
Stop running in the middle of juicing
well this is very common with this version, clean inside out, shredded fruits and veggies tend to stick and jam blades.
Jan 09, 2008 | Jack Lalanne Power Juicer (Stainless...
Kitchen Appliances - Others Logo
78 people viewed this question
Top Black & Decker Kitchen Appliances - Others Experts
Irene Tulloch
Gerry Harvey
Gerry Harvey
Are you a Black & Decker Kitchen Appliances - Other Expert? Answer questions, earn points and help others
