Question about Nokia 6120 classic Cellular Phone
Want to change the language - Nokia 6120 classic Cellular Phone
How do I change to English on a 1450
Setting the Languages
Touch : Tools> Settings> Language
Voice Language-change the language for voice prompts.
Text Language-change all on-screen text to the selected language.
Changing the text language does not change the language of user-entered data or map data, such as street names.
Keyboard-select the keyboard for your language. Touch Mode on any keyboard to change the keyboard language.
restore-restore the original language settings.
All this is on page 46 of the owner's manual online at Garmin.com ::
http://static.garmincdn.com/pumac/nuvi_1100_1200_1300_1400_OM.pdf
Feb 21, 2015 | Garmin nuvi 1450 GPS Receiver
Vmfusion emulation of windows 7 language change
How to change the Windows 7 Display Language:
1. Go to Start -> Control Panel -> Clock, Language, and Region / Change the display language
2. Switch the display language in the Choose a display language dropdown menu.
3. Click OK
4. Log off for the changes to take effect (This will affect only the user profile under which you are currently logged on).
May 05, 2012 | Apple iMac Computers & Internet
I want to change my asus 333 pc from chinese language to english
Which Operating System?
The display language is the language that Windows uses in wizards, dialog boxes, menus, Help and Support topics, and other items in the user interface. Some display languages are installed by default, and others require you to install additional language files. When you change the display language, it is changed for your user account and is not changed on the Welcome screen. If you want to set the display language for multiple users or the Welcome screen, see Apply regional and language settings to reserved accounts.
  1. Open Regional and Language Options by clicking the Start button 4f6cbd09-148c-4dd8-b1f2-48f232a2fd33_47.png, clicking Control Panel, clicking Clock, Language, and Region, and then clicking Regional and Language Options.
  2. Click the Keyboards and Languages tab.
  3. Under Display language, choose a language from the list, and then click OK.
Mar 26, 2012 | ASUS Eee 900 Notebook
How can I type Japanese o keybord?
Hai ! This is possible : )
Type in Chinese, Japanese, and other character-based languages
To type text on your computer in character-based languages, such as Chinese and Japanese, follow these steps:
[Source: http://windows.microsoft.com/en-us/windows-vista/Type-in-Chinese-Japanese-and-other-character-based-languages]
  1. Add the language as an input language. If you want to use an input method editor (IME), make sure you select it when you add the input language. For more information, see Add an input language.
    You can edit documents in multiple languages by changing the language (the input language) in which you type. Input languages are included with Windows, but you need to add them to your list of languages before you can use them.
    1. Open Regional and Language Options by clicking the Start button 4f6cbd09-148c-4dd8-b1f2-48f232a2fd33.png, clicking Control Panel, clicking Clock, Language, and Region, and then clicking Regional and Language Options.
    2. Click the Keyboards and Languages tab, and then click Change keyboards.
    3. Under Installed services, click Add.
    4. Double-click the language you want to add, double-click the text services you want to add, select the text services options you want to add, and then click OK.
  1. Change your input language to the language you installed. For more information, see Change your input language.
The input language is a setting in Windows that controls the language you use to type information on your computer. Before you can change an input language, you need to add that language to Windows. For more information, see Add an input language.
To change the input language
Click the Input language button on the Language bar, and then click the input language you want to use.
93d5c617-b1ec-4138-a1ff-973e71de80fe.pngLanguage bar gl_ico.png Note
If you don't see the Language bar, right-click the taskbar, point to Toolbars, and then click Language bar.
  1. Change your keyboard layout to the desired layout. For more information, see Change your keyboard layout.
You can customize your keyboard for a specific language or format by changing the keyboard layout. The layout controls which characters appear on the screen when you press the keys on your keyboard. Some input languages have several keyboard layouts; others have only one. For example, you can change your keyboard layout from the English QWERTY format to the English Dvorak format. After you change the layout, the characters on your screen might not correspond to the characters on your keyboard keys.
Before you can change the keyboard layout, you must add the input language and keyboard layout that you want to use to Windows. For more information, see Add an input language.
Hide all expcol_imgs.png To change the keyboard layout
  1. On the Language bar, click the Input language button, and then select an input language.
  2. Click the Keyboard layout button, and then select a keyboard layout.
gl_ico.png Note
expcol_imgs.png To change the keyboard layout on the Welcome screen
On the Welcome screen, click the Keyboard layout button 0c181420-8a93-48b6-82b1-b2dc25fc01b5.png, and then select a keyboard layout.
TIP:
After you are done you can switch between Japanese and English very easily by manually pressing the on screen buttons or using keyboard commands like SHIFT+ALT to switch between Japanese (???) and the Alphabet.
May 04, 2011 | Compaq Keyboard
Want to change language?
If your tom tom is in a wrong language, to set it back or change it to the normal language, all you need to do is to reset it. To reset it, hold down the power on/off button for about 15 seconds, it will restart the tom tom, that way the language will be restored back to its normal language.
If you are not requesting to change the language back to its normal language, then to change the language to any other foreign language, what you have to do is to go to the gps settings, then you select from the options where you find language, then you select your choice language, that way your language will be changed.
hope this helps.
Dec 23, 2010 | Tomtom One XL GPS Receiver
I bought a Garmin Nuvi 1350 GPS. How do I change the language into English?
. Setting the Languages Voice Language--change the language for voice prompts. Touch tools > Settings > Language.
text Language--change all onscreen text to the selected language. Changing the text language does not change the language of user-entered data or map data, such as street names. Keyboard--select the keyboard for your language.
Sep 02, 2010 | Garmin GPS
I have Windows Vista Home Premium in Italian. I want to change it to English. Is it possible?
Yes you need to install a language pack, he display language is the language that Windows uses in wizards, dialog boxes, menus, Help and Support topics, and other items in the user interface. Some display languages are installed by default, and others require you to install additional language files. When you change the display language, it is changed for your user account and is not changed on the Welcome screen. If you want to set the display language for multiple users or the Welcome screen, see Apply regional and language settings to reserved accounts.
  1. Open Regional and Language Options by clicking the Start button 4f6cbd09-148c-4dd8-b1f2-48f232a2fd33.png, clickingControl Panel, clicking Clock, Language, and Region, and then clicking Regional and Language Options.
gl_ico.png NoteIf you don't see the list of display languages, you need to install additional language files first. For more information, see Install a display language.
When you change the display language, the text in menus and dialog boxes for some programs might not be in the language that you want. This happens because the program might not support Unicode. For more information about changing the text in menus and dialog boxes for programs that do not support Unicode, see Change the system locale.
Feb 27, 2010 | ASUS Eee 4G Notebook
How do you change the language?
  1. Tap the screen to bring up the Main Menu.
  2. Tap Change preferences.
  3. Tap the arrow in the bottom right corner until you see the Change language button.
  4. Tap Change language.
  5. Tap a language to select it.
  6. Follow the instructions on the screen to confirm your language selection and choose a voice.
Apr 11, 2009 | GPS
Problems in changing he boot language
hmmm! go to the control panel and here is option for regional and language..... you have just change the language as you want.....
Apr 03, 2009 | Microsoft Windows XP Professional for PC
Language problem
for all android phones version 1,5 and later you can go to a free android market and download the programs 'MoreLocale' and 'Set Locale and Language' . you can change the language into any language u want.
Jan 17, 2009 | HTC Touch Dual Slider Smartphone
Nokia 6120 classic Cellular Phone Logo
187 people viewed this question
Top Nokia Cell Phones Experts
Computer Repairing
Computer Repairing
IT Solution
IT Solution
