Question about Brother CS-8060 Computerized Sewing Machine
My Brother sewing machine CS 8060 keeps flashing the codes E4 and E5. How do I clear them and reset the machine? It isn't sewing at all now!
3 Suggested Answers
  • 300 Answers
SOURCE: trying to find optional extras for my brother
Go to your local Brother shop and buy the accessories you need.
Posted on Apr 08, 2010
mc1bean
  • 3053 Answers
SOURCE: brother computerised sewing machine cs 8060 makes
Hello, gwen
I am trying to help you out here. Maybe this will help some? I am known on Fixya as the cleanup expert pro. Which means I spend my own personal time to seek out customers that maybe have not had there problem yet solved. I do this on my own time for free. Think of me as a Specialized Trouble Shooter.
I have found out that it appears that lots of customers appreciate my efforts and help. So, I thought I would take some of my own personal time
to see if I can help you. Even though this Informational site may not have your exact model or brand, But this site will help you a lot. Here is the site link about everything you want to know about Sewing Machines and possibly yours, from repair to trouble shooting it.
http://home.howstuffworks.com/sewing-machine.htm
Please if this helped you at all, if you can find the time and in your heart to rate my help and some kind words written would be appreciated for my free help. It would make my time worth. Like I said I just try to help, If anything this is good information for future problems. If you felt that my free help was a waist of time for you, I'm sorry. I do not get paid to help people on the site, I do it cause I like to help and maybe make a smile on someones face.
Here is also my direct link to my own pages of other areas of my expertise for other problems you might have in Automotive, Appliance, and Electronics. Drop In anytime for my help.
http://beta.fixya.com/users/mc1bean
Thanks Mike
Posted on Oct 30, 2011
How can I set shuttle timing?
go google and type in ---singer sewing machine needle and hook timing procedure
yes it is a singer but the principle is the same for all makes of machines and the detail is good
If you like change the search from singer to brother and include the model number
Jan 23, 2016 | Brother CS-8060 Computerized Sewing...
I have a brother cs-8060 sewing machine but I don't have the manual for it. When I start to sew the machine makes a loud sound the and woont sew normally and then I get an E6 flashing on the machine.
An E6 error indicates a thread tangle. Combined with the noises you are hearing my guess would be that the tangle is around the take-up lever pivot and is seizing the machine (causing an overload - hence why it won't sew). The origin of this is often a further thread tangle between the tension disks, which has allowed the thread to fly loosely around the take-up. Your best bet will be to take it to your local sewing centre. This is the sort of issue we commonly address as a part of servicing. You will find a description of what you might try in the Service Centre section of our shop's website http://www.kornacraft.com.au/sewingcentre-under-the-covers/
Feb 06, 2015 | Brother CS-8060 Computerized Sewing...
Why does error F7 flash on my brother cs8060 sewing machine and how can I fix it?
Any "F" error message, F1 through F8, can indicate machine is malfunctioning and needs servicing. You can check with Brother.
Sep 02, 2014 | Brother CS-8060 Computerized Sewing...
E4
What type of machine is it? This is a code to tell you what problem there is and each machine is different. In your manual there should be this information to inform you of different codes like bobbin low or improper threading, etc. Tell me the machine type and I can probably tell you.
Apr 27, 2014 | Brother CS-8060 Computerized Sewing...
E1 flashes on the message window of my brother sewing machine
Brother Computer Codes
  • E1: Make sure the presser foot is lowered before sewing.
    E2: You chose a stitch other than a buttonhole stitch or a bar tack stitch and you tried to sew with the buttonhole lever in the lowered position. Raise the buttonhole lever.
    E3: If you selected the buttonhole or tack bar stitch and start to sew with the buttonhole lever raised, you will get the E3 code. Lower the buttonhole lever.
    E4: You hit the reverse button while the bobbin winder shaft was moved over to the right. Move the bobbin winder shaft to the left.
    E5: On automatic sewing machines, the start/stop button was pressed while the foot controller was plugged in. Unplug the foot controller if you are using the automatic function.
    E6: This code tells you that the motor locked up because the thread is tangled. Untangle the thread, make sure the machine is threaded properly and that the proper tension is set before continuing.
Oct 03, 2012 | Brother CS-6000
My computerized brother sewing machine displays an E6 problem
I read in the manual that the motor probably locked up because the thread is tangled. I would check the bobbin area and clean out. then shut the machine off and on again and see if that clears up the problem. Your tension maybe too tight.
Apr 07, 2009 | Brother CS-8060 Computerized Sewing...
Brother CS-8060
if you are looking at your machine there is a trio of "buttons" it the one on the right looks like an upside down u with an arrow pointing down on the right side... press that for reverse...
Aug 21, 2008 | Brother CS-8060 Computerized Sewing...
Brother CS-8060 Computerized Sewing Machine Logo
Top Brother Sewing Machines Experts
Tally Girl
Tally Girl
Irene Tulloch
Are you a Brother Sewing Machine Expert? Answer questions, earn points and help others
