Question about Mintek MDP-1815 Portable DVD Player
No picture appears on the screen when I play a DVD. I can see a flash of something when I first turn on the DVD player or if I push the small botton that turns off the player when you close it. What can I do to fix this
  • joeblaettler Nov 11, 2010
    I looked under a bright light as you suggested and can see a image of what is playing. The disc keeps turning, so perhaps it is the back light. How can I obtain a replacement or repair for this situation. I've only used this machine a few times, but it's been sitting around for a couple of years.
  • joeblaettler Nov 13, 2010
    Thank you I was afraid this was going to be the situation. I find it is usually cheaper to replace an item rather than repair it and I agreee that is unfortunate. Appriciate you feedback.
    Ralette Blaettler
  • 4,102 Answers
Hi, the problem you are having is very common with all types of devices such as dvd players,phones,laptops/netbooks, etc basically anything that flips or slides open, now what is causing the loss of feed to the screen is a damaged data ribbon.
this data ribbon is a thin piece of ribbon with several single strand copper wires running through it and what happens is over time when you keep opening and closing the screen this ribbon keeps bending so it keeps the connection between the screen and the circuit board in the bottom half of the player, now over time this ribbon becomes brittle and what then happens is one or more of the copper wires that run inside this ribbon become brittle and break this then causes loss of conection with the screen and you then get no picture or any sort of feed to the screen.
now if this was a phone that you had the problem with then it would be a very easy fix as most phone shops will stock the data ribbon and as its a common fault its cheap to get fixed, how ever as yours is a portable dvd player then this is a different story, you would need to take it to a electrical repair shop or tv repair shop and ask them if they can order and fit the part for you, but as its a Mintek one then the chances of repair are slim as parts are hard to come by as they are not made to be repaired, todays electronics are throw away items which i think is bad practice as most could be fixed for a few quid and would save them going to landfill, getting the part yourself would be pretty much impossible but if you take it to a tv repair shop they may be able to match the part up off something else and get it working for you.
you will need to ask about the price and then decide if its worth getting fixed compared to buying a new player, i would say if its more than 2 years old then i would scrap it as the laser unit will be the next part to fail, if its less than a year old i would try and get it fixed as you should be able to get at least another 12 months out of it if you can get the part and have it fitted.
let me know how you get on or if you need further assistance ok
Posted on Nov 13, 2010
  • Mintek Master
  • 13,433 Answers
take a close look at the screen, look at it under a bright light, if you see picture, but there is no backlight then most likely the screens backlights have gone out, or the inverter for the backlights.
I don't know about replacement parts if thats the problem, I did not see any available or being sold after a quick check around.
If that is not the problem and the screen goes entirely black while trying to play back a movie - is the disc still spinning or does the whole machine turn off?
If the disc still spins and the machine seems to be working but you don't have image, the issue is most likely the lcd, its backlight or inverter.
if the whole machine goes dark - it might not be getting enought power from the adapter - But if the battery has charge and it charges, then that can't be the issue. These are failry complex machines with multilayer circuitboards it will be difficult to repair if theres a fault aside from its display.
take a look at what I've suggested and post back your findings.
Posted on Nov 10, 2010
  • Ekse Nov 11, 2010
    Just checking, this is a mintek mdp-1815?
    Okay, its definitely either the screens backlights, or lamps, or then the inverter that supplies power to them. Sorry I haven't taken many of these apart and don't know what kind of backlight system it has. Probably the same as in laptop computers.
    If your handy with a screw driver could you take it apart and see if there are any part numbers on the display and do you see a small circuitboard that has 2-4 cables going into the lcd display?
    How to take it apart?
    remove the battery, remove the ac power.
    You can probably take the cover of the lcd display apart right now, but it will still be stuck on the base of the unit.
    So I'm guessing you should start by taking the base of the casing apart, unscrew all screws from the bottom, check under any soft objects and labels. Take note of what goes where.
    After you have got all the screws out from the base, the casing will most likely be held together with plastic clips you can release them possibly with your fingernails by going around the case or with a plastic stick or a flat head screw driver, but the flat head will leave marks on the plastic.
    our goal here is to remove the whole display and the cables that are connected to the base from the unit. After that you can take apart the lcd, it will be held together with plastic clips and screws on the front. There might also be double sided tape holding the casing together.
    With time, patience, and care you will get it apart
Dvd will not eject
Jammed.
Straighten one end of a Norwegian paper-clip.
Insert that end into the small hole in the face-plate.
Push until you feel resistance.
Firmly push another 5mm to "unlock" it.
Then, press OPEN.
Jan 01, 2014 | Sanyo DVW-6100 DVD Player/VCR
SDVD8732 7-Inch Dual Screen Portable DVD Player not displaying picture on screen
On one or both? Take a flash light and look close at the screen while playing something. If you can see the picture on the screens then it is a back light problem. They are not easy to repair.
Sep 05, 2013 | Sylvania SDVD8732 Player
My bauhn TV screen stopped working. DVD plays sound but no picture. Can the TV be reset or rebooted
You can try unplugging the units--no picture often means the DVD has a dirty or failed optical unit.
Aug 30, 2012 | Televison & Video
Player has sound of the movie but the screen is just white no picture
There is a small button on top when the screen closes it turns off the display. While the movie is playing press the small button with a small pointing object and see if the display shows something on the screen for a few second and then off (you can sometime see the movie playing but very dim). then there is a problem with the switch not switching the display back to normal. Hope this helps...
Jun 02, 2011 | kawasaki PVS-10921 Portable DVD Player
No picture
Lately I cannot get a picture when I turn on the DVD operation--the TV screen, as always, is on INPUT (Extension).....the unit show PLAY, but the picture does not appear--and the TV screen stays blue! The audio is on, but no video....
This is something rather recent. However, if I unplug the electric-power source for the DVD-player, then sometimes the picture does appear, though not always.
I have checked the manual but find no good answer there. Please let me know what to do....many thanks.
Aug 06, 2008 | GoVideo DV2150 DVD Player/VCR
Split screen
It appears that it has something to do with Progressive Scan been turned on. Progressive Scan is a feature built in your dvd player, wich by using it, it would give you a better picture//resolution on your tv, you need to use Component or HDMI cables to hook up the dvd to your tv if you want this settings, but if you are using composite RCA cables (Red,White & Yellow) and the Progressive funtion is turned on by accident, it may give you a split screen, black & white, or no picture problems. Also if you are using Component (Blue, Green & Red) cables, if one of them is unplug, the picture can be out of colors, or no picture. Check this things, if not, write back with more details about your set up.
Jun 23, 2008 | Panasonic DVD-RP56 DVD Player
AMW DVD Player
my dvd doesnot play ,power is on screen is ok.but the dvd did not play (no rotation of the disk)
Feb 14, 2008 | Amphion Mediaworks M-270 Portable DVD...
Black and white picture
turn off you dvd player... them click on "setup" button on your remote control! them click right botton to appear "tv sys" them click "enter"... choose your tv system, PAL or NTSC.
Jan 15, 2008 | Pioneer DV-360-S DVD Player
Black square on screen
Seems that you have to go into setup and look at the Closed Captioned screen set up.
Aug 27, 2006 | Panasonic DVD-F87 Multi-disc DVD Player
Dvd/vcr combo,vcr is fine ,but dvd no picture,or sound,disc reads.
Hi There is an I/P button on your player's remote control. Power your player on then press the I/P button on your remote control.
Aug 16, 2006 | Apex Digital ADV3800 DVD Player/VCR
Mintek MDP-1815 Portable DVD Player Logo
531 people viewed this question
Top Mintek Televison & Video Experts
Jaime Hernandez
Are you a Mintek Televison and Video Expert? Answer questions, earn points and help others
