Question about Whirlpool Dryers
Where do I place the green wire on my whirlpool 8 cycle dryer? I do not know where the external ground is.
    President:
  • 1,218 Answers
Good day,
There is no specific place for a ground wire to be placed. However it must be attached to the main cabinet. If needed, you can even drill a small hole and attach it with a self threading screw.
Here is one example.
Posted on Nov 08, 2010
  • John Hall Nov 08, 2010
    The ground wire (green) is a safety wire used to protect a machine from shocking someone if the machine develops a short. It does not, nor is designed to carry current.
    On the other hand, the white wire although will normally be at ground potential, is a current carrying wire. If something should go wrong, the white wire can rise above ground potential and if severe can cause a shock.
    White and green wires perform totally different functions. In a perfect world connecting them together would never be an issue, but we dont. They should not be connected together.
  • Whirlpool Master
  • 1,344 Answers
If your talking about the green wire on the dryer plug, then you just put it on top of the white wire in the center of the block where the cord goes to the dryer, this is a nuetral/common ground connection.
We were never given an owner's manual for our
Hi wildspiritmo...
Go to the following webpage and see pictures and discription of how to change you 3 wire dryer into a 4 wire dryer.
Please take time to rate me thumbs up
http://www.selfhelpandmore.com/switch-outlet/dryer-circuit-wiring-and-hookup.php
Sep 14, 2011 | Kenmore Elite HE3 Steam 8674 Dryer
Just moved into an older home with a 3 prong dryer receptacle. My whirlpool duet dryer model: GEW9250PL1 currently has a 4 prong cord. I have purchased the 3 prong cord and am ready to install. Very...
Hi, White, green green/white striped they are all the same....only thing you really have to worry about is that you have the red and black in the proper places...
Here is a tip that will help you with changing your dryer plug. Dryer Cord and Wiring Dryer 3 Wire or 4 Wire
heatman101
Jul 13, 2011 | Dryers
Need to know about the wires to hook up electric cord there is a red,white,black and green cord but only room for everything but green...what do we do with it
Take any screw out of the metal on the frame of the washer and place the green wire under the screw...the green is a ground...
heatman101
Feb 11, 2011 | Whirlpool Cabrio 7.0 Cu. Ft. Super...
If you are installing a new power cord on a whirlpool dryer and you have a power cord with one green wire one black wire one white wire and one red wire where do you connect the wires when the terminals on...
Good day,
The green is screwed to any convenient place on the cabinet. It's a safety ground wire.
The white goes in the middle of the block. The red and black go on either end. Doesn't matter which.
Feb 27, 2010 | Whirlpool GEW9250 Electric Dryer
How do I connect a 4 wire cord to a whirlpool dryer - there is no grounding strap. There is a green grounding wire connected on the bulkhead. Can I connect the green wire from the 4 wire cord to this green...
Yes, infact you can connect the green wire anywhere to the body of the dryer. That is a safety ground that will or is supposed to, take away the risk of getting shocked if one of the hot wires would short tothe body of the dryer anywhere.
Nov 14, 2009 | Whirlpool GEW9250P Electric Dryer
I need to change my eltric cor from a four wire to
The following link explains how to install a power cord for your appliance:
http://www.fixya.com/support/r793520-3_prong_4_prong_power_cord_conversion
Refer to the section that discusses converting from a 4-prong to a 3-prong power cord.
If you have questions, let me know. I hope this helps you.
PS The GREEN wire is ground and gets grounded to the appliance frame.
Jul 06, 2009 | Whirlpool LER4634J Electric Dryer
Wire 3 prong cord
Electric Dryer How To Hook Up Cord pixel_trans.gifFor Three Prong Cords
the Center cord wire goes on the center terminal,
the left on the left ,
and the right on the right.
Note: There should be a ground strap or wire that runs from the center terminal to the dryer case.
For Four Prong Cords
the White cord wire goes in the center,
the Red on the Right,
the Black on the Left.
The green cord wire goes to the case or the external ground screw.
Note: Be sure to disconnect the ground wire or strap that runs from the center terminal to the case. In this Photo (A Whirlpool Dryer) I have ran the wire that runs from the center terminal, the Light Green wire, back to itself rather than cutting it off, just incase I need to put a 3 prong cord back on it some day. The whole purpose of this 3 prong / 4 prong thing is it separates the neutral from the ground. pixel_trans.gif pixel_trans.gif3 Prong Cord Whirlpool Dryer Example terminalblock.jpg 4 Prong Cord Whirlpool Dryer Example 4prongcord_small.jpg
Jul 02, 2009 | Maytag Neptune MDE5500AY Electric Dryer
DRYER CORD
white wire to middle of terminal block black and red wire 1 on each side,green wire gets grounded to the cabinet,your done-mike
Mar 31, 2009 | Whirlpool GEW9250 Electric Dryer
Whirlpool LE5795XPNO 3-wire to 4-wire
The following link explains how to convert your dryer from 3-wire to 4-wire:
If you have questions, or require further assistance, please let me know. I hope this helps you.
Jan 11, 2009 | Whirlpool LER5636P Electric Dryer
I purchase a 4 ring dryer plug replacement
the red to red.. black to black (outside screws) or vise versa doesn't really matter.. white to center screw green to cabinet..the green wire already attached to green screw should to taken off and either cut off or taped off it can be just connected back to center screw for future use
Sep 07, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Dryers Logo
83 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal DeAngelo
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
