Question about Dryers
Model number is 86673800 older kenmore dryer and tub stopped turning
Jimster
  • 240 Answers
SOURCE: Kenmore Dryer stopped running
This sounds like you may have blown the thermal fuse.  If you turn the dryer around facing the back, remove the screws holding the back panel on (be sure to unplug the pigtail from the wall!!!).  When you remove the back panel, down towards the bottom, you will see a plastic piece (could be long and square, or rounded type.  Do believe it will be the long type) with 2 wires going to it.  It has a screw that holds it it.  This fuse protecs the unit and motor from excess heat and electrical issues.
THERMAL FUSE
Part Number: 3392519
Posted on Oct 14, 2007
  • 94 Answers
SOURCE: kenmore gas dryer
That model does not have a pilot light.  It has an electronic ignitor.  If it is not igniting, either the igniter is not getting a signal to ignite, the igniter is burned out, or the gas solenoid is broken.  Probably the igniter is burned out.  It is item number 3018 at RepairClinic.com.
Posted on Oct 21, 2007
SOURCE: Need schematic for Sears Kenmore Dryer model number 11063032102
Thanks, I will try that.
Posted on Mar 28, 2008
jsrock516
  • 5911 Answers
SOURCE: kenmore, heavy duty dryer, 70 series extra capacity, not heating
The following link explains how to diagnose a dryer "no heat" problem:
http://www.fixya.com/support/r630242-dryer_runs_but_not_heat
If you require addtional assistance, please let me know. I hope this helps you diagnose your problem.
Posted on Aug 12, 2008
  • 4088 Answers
SOURCE: kenmore dryer model number 110.66912691 not heating.
Check the house electrical panel for tripped dryer-circuit breaker-pair. Push off, then on. If immediately re-trips, the dryer has a dead short circuit in it. If they hold, then retry the dryer. If it now works, ok! If not, recheck the breakers as above. If tripped again, there is a likely short in the dryer's heater assembly. The drum must be removed to access the heater.
Posted on Aug 24, 2009
11076812693 drum won't turn.
Kenmore Dryer Model 110.76812693 (11076812693) Drum ...
www.repairclinic.com/.../Model-11076812693-Kenmore-Dryer-Drum-T...
Kenmore Dryer Model 110.76812693 (11076812693) Drum & Tub Parts in stock. One million parts for 125 brands. Guaranteed same-day shipping. Call 7 days ...
Kenmore Dryer Model 110.76812693 (11076812693) Motor ...
www.repairclinic.com/.../Model-11076812693-Kenmore-Dryer-Motor-...
Includes pulley for dryer drum drive belt. Other shaft has reverse threads for blower wheel. Common symptoms of a bad drive motor are: -Dryer stops turning ...
Kenmore, Whirlpool Dryer Repair - Heats properly, drum will ...
? 6:29
https://www.youtube.com/watch?v=bOShDc4kLfk
Jul 10, 2013 - Uploaded by ApplianceVideo.com
Service a Kenmore Dryer with some of the following issues: Heats but ... Kenmore, Whirlpool Dryer Repair - Heats properly,drum will not turn - 11068202794 ..... Whirlpool Kenmore Maytag Amana Dryer Won't Start - Easy Fix ...
How To Fix Dryer That Won't Tumble ' Dryer Repair
www.partselect.com/Repair/Dryer/Will-Not-Tumble/
Feb 08, 2016 | Kenmore Dryers
Tub is not rotating but the belt is intact,it is an older model but dont know the model number
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Nov 24, 2010 | Maytag Dryers
Kenmore Dryer Model No. 110.64632300
If it is 6 years of age or older and have a lot of use in the past you will be better off replacing it. The cost to repair it will outweigh its age and cost to repair
May 20, 2010 | Magic Chef CYE4000AWW Electric Dryer
Spin cycle doen't work on control-water accumulates in tub-its a kenmore
I'm guessing that the mechanism for putting the tub in the spin cycle is worn out. These can be either electro-mechanical switches for older models, or electronic switches for newer models. At any rate if your tub is not spinning, you will have to have someone come out to look at the problem. BTW, I have a Sears washer and dryer, and had to have the dryer serviced once. They were very good and did not rip me off.
May 16, 2010 | Kenmore Washer Timer Control Knob 3362624...
Older dryer just stopped heating. Air still blows
Sound like you need to replace the heating elament you will need to take your model number and make to repair shop for replacement parts or have a repair person come out and fix it for you . thanx for using fixya
Jun 16, 2009 | Kenmore 64742 Electric Dryer
Kenmore dryer Model C110-8170091
This is most likely the door switch that has failed or come loose
Aug 27, 2008 | Kenmore 63932 Electric Dryer
Kenmore heavy duty dryer
You didn't mention if the motor runs or if it heats. If it does both of these, you'll need a new belt.
Mar 09, 2008 | Dryers
THERMAL FUSE
Oct 12, 2007 | Kenmore 63942 Dryer
Dryers Logo
91 people viewed this question
Top Dryers Experts
