Question about Acer Aspire AS5520-5912 Notebook
Loading issues Everytime i switch on my laptop my OS will not load. When i switch it on the acer screen shows up and then after a short loading bar. When it finishes loading my OS (which s Vista) will not load or open. What is wrong???????
  • 167 Answers
You need to install vista again whit full format not quick. And that will solved your problem!
good luck
Posted on Jun 16, 2008
Acer aspire one restore failed: wont start now
the reason its saying,,ntldr is missing is because its lost somthing from the hard drive that it needs to run,it would have lost that when it stopd loading your windows.try it again and if it gives you..repair windows ,,,then do that.and it should do it because it should fint the missing file that it needs to carry on loading.
May 04, 2014 | Acer Aspire One Netbook 8.9" Notebook
Hi. I have a acer aspire 5520. After Bios is loaded, show a black screen with a blinking cursor. And not make nothing anymore. Regards.
This is either an issue with the HDD or the OS
Turn the computer on and when you see Acer press ALT + F10 together.
You should see Windows is loading files and then load into the Acer eRecovery Manager.
If you don't then its a HDD fault.
Apr 26, 2011 | Computers & Internet
Not booting
Would you be able to get the Windows loading bar before it goes to a dark screen if yes we could reinstall the Windows wherein you would lose information on your computer and to do the reinstallation all that you would need to do is start tapping on Alt+F10 as soon as you turn on your computer untill we find Windows loading files on the screen and then you would get the Acer recovery management Windows from where you need to select completely restore system to factory defaults and then keep following the instructions on the screen clicking on a few next ok or yes buttons and it would complete the process in 30-45 minutes time;if you are unable to get the Windows loading bar or the Acer logo then you would haveto conatc technical support and set up a repair for a video card issue.
Jun 06, 2010 | Acer Aspire One PC Notebook
Boots to progress bar before loading windows
It seems that windows tries to check your Hard Disk for errors before loading the system files to memory. Do you hear some sounds from your hard disk? If you can successfully get to windows, open my computer => right click on drive C => Click on Properties => Click on TOOLS Tab and click CHECK NOW button.
Check the next 2 options and answer YES when windows ask you to schedule a thorough scan during next boot.
Regards!
Jul 21, 2009 | Acer Aspire 5100 Notebook
My Acer laptop will not load.
Try this, Acer told me to do this and it worked.
The other way before Vista starts up is to tap ALT + F10 (at the same time repeatedly) when the computer is first switched on.. The window of opportunity is very small, so this may take a few attempts
Once you have tapped both the ALT and F10 repeatedly, you may see a screen showing:
“Edit Boot options for Microsoft Windows Vista”
If you see this, unfortunately, you have missed the window of opportunity, and you need to restart, and try again.
If you see this:
“Edit Boot options for Windows Setup” OR “Edit Boot options for Acer eRecovery”
Then it indicates that you have tapped the ALT + F10 correctly, and all you now need to do is press “Enter” and the Recovery program should load on your screen after a short pause..
In some cases, you may need to remove the battery (for notebooks only) and run the machine directly from the mains.
The Disk2Disk recovery feature allows you to recover the system without recovery CDs.
This will return your system to factory settings and will delete everything stored on the machine.
If possible we strongly advise backing up anything important on your machine before starting the recovery process.
Jul 03, 2009 | Acer Aspire 5920-6727 Notebook
ACER Aspire 5100 powers down at will
When you turn the laptop on hit f8 until the menu comes up, try use the last good known configuration. If that does not work tap f8 goto safe mode and then to system restore and restore it to an earlier time. Let me know if it works.
Apr 15, 2009 | Acer Aspire 5100 Notebook
The word ''Acers'' apperas on the screen and its not loading
if you can find the motherboard battery, remove it and leave it out for around 2 mins, this should reset the CMOS (date,time, settings etc) make sure the laptop battery is out and its not plugged into the mains, the other way is to flash the bios by downloading the latest bios version for you machine providing that it boots to windows, the only other option is to flash via floppy with AC power on!!! NOT RECOMENDED as if it goes wrong your pc will be permanantly dead
good luck
Nov 13, 2008 | Acer Aspire 5610-4648 Notebook
Aspire 5610 stuck on initial Acer loading screen!
Time to re-install your OS.
Install Windows from Bootable CD.
May 27, 2008 | Acer Aspire 5610-4648 Notebook
Acer Aspire AS5520-5912 Notebook Logo
83 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
